COMP_DEVICE_TYPE | COMP_VALUE | REFDES |
CAP NP_0306_0.1UF | 0.1UF | C76 |
CAP NP_0306_0.47UF | 0.47UF | C99;C101 |
CAP NP_0402_0.1UF | 0.1UF | C11;C37;C38;C39;C41;C42;C52;C53;C54;C55;C56;C59;C77;C86;C87;C115;C120;C135;C138;C254;
/ @3 ]+ B& h- EC255;C256;C257;C263;C273;C275;C281;C309;C311;C314 |
CAP NP_0402_1000PF | 1000PF | C22;C24;C25;C134;C168;C218;C219;C220;C332 |
CAP NP_0402_100PF | 100PF | C102 |
CAP NP_0402_750PF | 750PF | C103;C105;C112;C114 |
CAP NP_0402_390PF | 390PF | C104;C113 |
CAP NP_0402_27PF | 27PF | C106 |
CAP NP_0402_47PF | 47PF | C107 |
CAP NP_0402_30PF | 30PF | C108 |
CAP NP_0402_4.7PF_2% | 4.7PF | C185;C286 |
CAP NP_0402_470PF | 470PF | C223 |
CAP NP_0402_0.01UF | 0.01UF | C316 |
INDUCTOR_0402_60 OHM | 60 Ohm | L13;L35;L36;L37;L46;L47;L53 |
INDUCTOR_0402_820NH | 820nH | L22;L23;L32;L33 |
RES_0402_49.9 | 49.9 | R14;R15;R16;R17 |
RES_0402_10K | 10K | R21;R22;R23;R24;R320;R325;R326 |
RES_0402_130 | 130 | R48;R50;R56 |
RES_0402_3.3K | 3.3K | R61;R129;R131;R136;R328;R329 |
RES_0402_100 | 100 | R62;R212;R213;R327 |
RES_0402_24.9 | 24.9 | R63;R70 |
RES_0402_10.0K | 10.0K | R150;R153 |
RES_0402_16.9K | 16.9K | R151 |
RES_0402_68 | 68 | R152 |
RES_0402_1K | 1K | R158 |
RES_0402_18 | 18 | R175 |
RES_0402_47 | 47 | R228 |
RES_0402_470 | 470 | R229 |
RES_0402_332.0 | 332 | R311 |
RES_0402_2.49K | 2.49K | R321 |
RES_0402_39K | 39K | R323 |
RES_0402_10 | 10 | R356 |
RES_0402_0 | 0 | R357;R360 |
RES_0402_100.0K | 100.0K | R359;R361 |
CAP NP_0603_4.7UF | 4.7UF | C60 |
CAP NP_0603_1.0UF | 1.0UF | C303;C305;C313 |
CAP NP_0603_10UF | 10UF | C334 |
INDUCTOR_0603_12UH | 12uH | L28;L29 |
RES_0603_220 | 220 | R210 |
RES_0603_6.19K | 6.19K | R313 |
RES_0603_0 | 0 | R358 |
CAP NP_0805_1000PF | 1000PF | C14;C15;C222;C224 |
CAP NP_0805_22UF | 22UF | C44;C58;C110;C123;C167;C188;C308;C310;C315 |
CAP NP_0805_0.22UF | 0.22UF | C225 |
CAP NP_0805_10UF | 10UF | C231 |
CAP NP_0805_1.0UF | 1.0UF | C317 |
CAP NP_0805_330PF | 330PF | C335 |
INDUCTOR_0805_60 OHM | 60 Ohm | L7 |
INDUCTOR_0805_300 OHM | 300 Ohm | L24 |
RES_0805_4.7 | 4.7 | R5;R6 |
RES_0805_1K | 1K | R8 |
RES_0805_820K | 820K | R10 |
RES_0805_200K | 200K | R223 |
RES_0805_1.0M | 1.0M | R230;R231 |
RES_0805_1.5 | 1.5 | R232 |
CAP NP_1206_4700PF | 4700PF | C190;C333 |
CAP NP_1206_150PF | 150PF | C318 |
RES_1206_SMALL_220 | 220 | R132;R133 |
CAP NP_1210_4700PF | 4700PF | C16 |
LYNX-COUPLING-1PRI-2SEC_5345-XF | 10005345 | T2 |
PWR-SKT_AC-ASOKA1_ACIN (pads) | ACIN (PADS) | J1 |
SPST_B3U-1000B_B3U-1000P-B | B3U-1000P-B | SW1 |
DIODE ZENER_CASE403A_1SMB5915BT | 1SMB5915BT3G | D12 |
TP_E-PT-25_15TH | 15TH | TP10;TP30;TP31;TP32;TP33;TP34;TP35;TP36;TP37;TP38;TP39;TP40;TP41 |
ERZ-V0D471_ERZ-VD_S07K320E2 | S07K320E2 | MOV1 |
INDUCTOR_IND-ELLV-3X3MM_3.3UH | 3.3uH | L49 |
INDUCTOR_IND-MI1206_600 OHM | 600 Ohm | L15 |
INDUCTOR_IND-NR4018_10UH | 10uH | L2;L31 |
INDUCTOR_IND-NR4018_100UH | 100uH | L8 |
LED-AC_LED-0603-SML41_SML-410MW | SML-410MWT86 | D15 |
LED_DUAL_ALT_LED-DUAL-0603_QSMF | QSMF-C16K | D9 |
BRIDGE_2_MINI-BRIDGE_HD06-T | HD06-T | D2 |
CAP NP_PFCAP-10X5LS7_5_0.033UF | 0.033UF | C7 |
QCA6410_QFN68-8X8_QCA6410 | QCA6410 | U8 |
CAP POL_RC200LS100P65_220UF | 220UF | C73 |
CAP POL_RC320LS140P60_1000UF | 1000UF | C10 |
CAP NP_RC320LS140P60_3.3UF | 3.3UF | C12 |
J0026D01NL_RJ45-J0026_J0026D01N | J0026D01NL | J2 |
RM4-2FLY_0_RM4-2FL-SHIELDED_RM4 | RM4-2FLY | T3 |
FUSIBLE-RES_RV200BD170P100D50_0 | 0.5 OHM - 2W | FR1 |
DIODE SCHOTTKY_SBR1U150_SK34A-L | SK34A-LTP | D3 |
OPTO-ISOLATOR_SMD-4_HMHA281 | HMHA281 | U3;U15 |
GBLC05C_SOD323-GBLC-BIDI_GBLC08 | GBLC08C | D43 |
DIODE SCHOTTKY_SOD-123_1N5819HW | 1N5819HW-7-F | D8;D10;D14;D23 |
DIODE_SOD-123FL_SM4007PL-TP | SM4007PL-TP | D6;D20 |
DIODE_SOD-123FL_BAV21W-7-F | BAV21W-7-F | D27 |
DIODE_SOD-523_1N4148WT-7 | 1N4148WT-7 | D17 |
TLV431CLP_SOT23-3-TLV431_TLV431 | TLV431AIDBZR | D4 |
NCP1529A_SOT23-5_NCP1529A | NCP1529A | U16 |
DIODE DUAL SCHOTTKY_SOT-23DF3_B | BAT54SFILM | D18;D19 |
FAN6862_SSOT-6_FAN6862R | FAN6862R | U9 |
CAP NP_TDK-X1Y1-250V_1000PF-Y1 | 1000PF-Y1 | C1 |
6N60_TO-251AA_NDD04N60Z-1G | NDD04N60Z-1G | Q1 |
M25P16-VMWP6TP_UFDFPN-8_M25P16- | M25P16-VMC6TG | U7 |
COMMON MODE_UTB01385_20MH | 20mH | L3 |
INDUCTOR_VLF4014ST_2.2UH | 2.2uH | L54 |
XTAL-3.2X2.5_XTAL-3_2X2_5_25.0M | 25.0MHz | Y2 |
