Feature List | AM3352(T I) | AM6548(T I) | A33(全志) | RK3399 PRO | RK3568 | RK3588 | A311D(晶晨) | SM8250(高通)骁龙865 5G | MT6853(MTK) 5G | MT6873(MTK) 5G |
CPU | | 1*A8 | 4*A53+2*Arm Cortex-R5F | 4*A7 | 2*A72+4*A53 | 4*A55 | 4*A76+4*A55 | 4*A73+2*A53 | Kryo 585 (1*A77,3.1872GH z+3*A77,2.419GH z+4*A55,1.805GH z) | 2*A76+6*A55 | 4*A76+4*A55 |
CPU时钟频率(MHz) | 1GHz | 1.1GHz | 1.2GHz | 1.8GHz | 2.0GHz | 2.4GHz | 2.2GHz | 3.1872GHz | 2.2GHz | 2.0GHz |
Process |
2 Q, ]% O9 T9 C |
( p0 V$ N3 f% m1 _ | 28nm | 28nm | 28nm | 28nm | 12nm | 7nm | 12nm | 12nm |
一级缓存 | 32KB+32KB | 32KB+32KB | 256KB | 48KB+32KB | (32KB+32KB)*4 | (64KB+32KB)*2 | 48KB+32KB |
3 b4 ?% [7 e1 Y# | | 64KB+64KB | 64KB+64KB |
二级缓存 | 256KB | 512KB | 512KB | 1MB+512KB |
1 N1 ]0 W" w3 l2 V1 y | 2MB+512KB | 1MB+512KB | 512KB | 256KB+128KB | 256KB+128KB |
三级缓存 |
6 l0 {; W( e/ V |
: B& S3 l2 ?! T. [$ ` | 9 V/ G( G' `/ q* _
| ( z3 @7 v( z# V& R7 m7 @
( {' D3 Y2 O" x8 }! O% y$ O | - J) M0 c* d' y
4 c: R7 v: T& e* E | 4MB | 1MB | 1MB |
GPU型号及最大主频 | powerVR SGX530 | PowerVR SGX544-MP1 | Mali 400 MP2 | Mali T860MP4 720MHz | ARM G52 2EE | Mali-G610 MP4 | ARM G52 MP4(6EE) 720MHz | Adreno 650 587/670MHz | Mali-Matt GPU 970MHz | Mali-Matt GPU 970MHz |
NPU |
5 }0 P% H9 | s9 W" ?: k6 _ | & ^( z0 b% w5 k1 S6 h
| - ^. `% ^( g2 ^" P, L. f
| 3Tops | 0.8Tops | 6Tops | 5Tops |
' X9 Y0 J" ?' q- z5 V" z4 F |
6 I. r) I* ^4 B+ m* [ |
" D# S' a: f8 q' d' w% n |
内部集成RAM | 64KB | 2MB | ! S8 N$ e. A- d% o3 n
| 100KB | U* y& a; m' ]" }1 x/ M3 k
| 64KB | 100KB |
& v& _+ F( v2 f5 @ |
) e( F# G: t$ q |
1 J0 T9 R4 M* P) J: r* C |
内部集成ROM | 176KB | ; k* U- h! D3 i; L5 r
| # a9 k, J- V" Y; e$ s+ K2 C6 W& D
| 20KB | 4 X7 O F$ T# O: J. z
| 1MB | 20KB | 5 ?/ Z2 q+ D8 Z/ v9 V# P
| & z+ Z8 h6 E6 }
| , c) V: ]9 P" G* W6 U/ D, K
Package | Dimension尺寸 | 15.0mm*15.0mm/13.0mm *13.0mm | 23.0 mm*23.0mm | 14.0mm *14.0mm | 27mm*27mm | 19mm*19mm | 23mm*23mm | 16.1mm*14.3mm | 12.4mm*14mm*0 .56mm(LPDDR5) | 12.05mm*11.35mm | 11.7mm*11.7mm |
Ball | 324/298 | 784 | 282 | 1372 | 636 | 1088 | 454 | 1099+496 | 824 | 854 |
Ball Pitch | 0.8mm/0.65mm | 0.8mm | 0.8mm | 0.65mm | 0.65mm | 0.65mm | 0.6mm | 0.4mm | 0.35mm | 0.35mm |
memory | SDRAM(DDR2, DDR3,DDR3L,LPDD R2,LPDDR3等)
. Q) A; a# }; w | DDR2/DDR3/DDR 3L | DDR4 up to 8GB | DDR3/DDR3L | DDR3/DDR3L/LPDDR 3/LPDDR4 up to 4GB
# F* q1 T; e0 |# m( Y( a3 e | LPDDR4/LPDDR4X/D DR4/DDR3/DDR3L/LP DDR3, ECC up to 4GB | LPDDR4/LPDDR4X/LP DDR5 up to 32GB
5 A5 m4 a5 {3 T6 D3 H4 D2 @ | DDR3/DDR3L/LPDDR3/LP DDR4 up to 4GB
. w8 q+ `; z, t; J; D! Z | LPDDR5 up to 16GB ; EMMC5.1/UFS3.0 | LPDDR4X up to 16 GB ; eMMC5.1/UFS2.1 | LPDDR4X up to 16 GB ; eMMC5.1/UFS2.1 |
NAND FLASH | 支持 | 支持 | 支持8 bit NAND | / | / | / | / | / | / | / |
SPI FLASH |
' v) e3 Z8 Q( {# @# Q |
9 S" W& m) y9 m |
# @0 Q3 t& n, l+ ~5 U9 e0 Q |
4 V" q: ?; _- [ |
/ W( l$ `; ^7 V- X3 K; } | 7 {' B, @8 R) F5 w1 v J
' W/ R u8 M- e0 k- H; x | / | / | / |
EMMC | 支持 | 支持 | 支持 | 支持 | 支持 | 支持 | 支持 | / | / | / |
| / | / | / | / | / | / | / | 支持 | 支持 | 支持 |
MMC | TF卡 | 2路 | 2路 | 1路 | 1路 | 1路 | 1路 | 1路 | 1路 | 1路 | 1路 |
显示LCD | LCM分辨率 | 1366*768 | 1280*800 | 1280*800 | 4K 3840*2160 | 4K 3840*2160 | 8K 8192*4320 | 1920*1080 | 4K Ultra HD 5040* 2160 | FHD+2520*1080 | FHD+2520*1080 |
LCD接口 (CPU,RGB,mipi,LVD S,EDP)
- V+ q* ]# a+ u. i. m" H | RGB | 1x MIPI-DPI, 1x OLDI (LVDS) | RGB/CPU/LVDS/ MIPI | 2路 4 lanes MIPI/EDP | 4 lanes MIPI/RGB/LVDS | 2路4 lanes MIPI/EDP | 2路 4 lanes MIPI/EDP | 2路MIPI DSI 4- lane | MIPI DSI 8-lane | MIPI DSI 8-lane |
(后)摄像头 1 camera | 像素(万) |
( }2 Q3 O" d. Z& j4 v | 13M | 8M | 13M | 13M | 48M | 13M | 32M或16M+16M | 32MP | 32MP |
接口方式(并口,MIPI) | - q0 m( u8 J- ]
| 4-lane MIPI_CSI | 并口 | 2路 4-lane MIPI_CSI | 4-lane MIPI_CSI | 4-lane MIPI_CSI | 2路 4-lane MIPI_CSI | 2路4-lane MIPI_CSI | 3路4-lane MIPI_CSI | 3路4-lane MIPI_CSI |
(前)摄像头 2 Camera | 像素(万) | / | / | / | / | / | / | / | 24M | 16M | 16M |
接口方式(并口,MIPI) | / | / | / | / | / | / | / | 4 Lanes MIPI | 4 Lanes MIPI | 4 Lanes MIPI |
