查看: 418|回复: 1
SLB628 高效率1.2MHz 2A升压转换器
    慵懒
    2022-10-12 15:59
  • 签到天数: 58 天
    [LV.5]常住居民I
    发表于 2022-7-25 14:52 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
    描述* P* I. \6 G* {. T; I
    The SLB628 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The SLB628 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height. Internal soft-start results in small inrush current and extends battery life.+ s9 J$ }/ \3 e6 k- X
    The SLB628 features automatic shifting to pulse frequency modulation mode at light loads. The SLB628 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The SLB628 is available in a small 6-pin SOT-23 package.
    - A; v/ g, m/ i- b! E1 }4 n  r: p9 \$ G" S& l. y
    特性* Y6 g* Z3 w% G' l% a
    • Integrated 80mΩ Power MOSFET
    ) f/ N8 Y# S* p! x4 w6 ~- K9 B$ C: _• 2V to 24V Input Voltage' [# j$ U9 @1 U6 J! T& A
    • 1.2MHz Fixed switching Frequency
    # v) n! L" d, p! w• Internal 4A Switch Current Limit
    % @9 m4 k1 ?% C6 h( V' S2 S4 J& y4 r• Adjustable Output Voltage' @& _, p6 u. b0 k
    • Internal Compensation2 l, u5 c. M, w; G3 B
    • Up to 28V Output Voltage
    6 z& v  K4 `+ Z7 H• Automatic Pulse Frequency Modulation
      b/ L9 c" V1 F9 V  R+ u( M2 ?Mode at Light Loads
    & F7 e0 `, L( |7 u, K( H• up to 96% Efficiency
    - t3 S" @. i+ U& B• Available in a 6-Pin SOT23-6 Package
    6 a4 o, K$ w3 W; m" w6 A/ i6 o) ?- R- c
    应用$ n$ f3 `) n2 I
    • Battery-Powered Equipment& N9 s7 L6 v( {! ?
    • Set-Top Boxed
    3 f# }5 N) i3 M7 f8 e, _• LCD Bais Supply
    / l% {* U  b: s& A• DSL and Cable modems and Routers
    ' _3 q" T9 T0 W0 w+ @• Networking cards powered from PCI
    8 l. J0 }8 G0 U/ m$ r8 Bor PCI express slots" B) K5 J* v+ U, ]' [7 s+ j
    * v! [5 T2 g* I原理图
    ' `7 t% A$ h' k! x3 e5 Z, \% q
    * z- b0 y$ E* }9 A+ {
    慵懒
    2022-10-12 15:59
  • 签到天数: 58 天
    [LV.5]常住居民I
     楼主| 发表于 2022-7-25 14:59 | 只看该作者
    欢迎围观
    % g/ {0 y( ?1 }% w5 ? ; H3 P, @6 t8 {: w6 T: H6 Z
    GMT+8, 2025-10-27 18:43 , Processed in 0.171875 second(s), 27 queries , Gzip On.
