查看: 217|回复: 2
欧姆龙增量编码器Z相测速遇到速度不连续的问题
发表于 2022-7-7 10:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
欧姆龙编码器(型号E6B2-CWZ3E)接的msp430f149的IO  P2.5引脚利用中断测速度8 t- o! A1 I- M% O
脚本如下:请教各位大神,中断应该如何修改,最终打印结果如下:
" x% R+ q  G, S8 h8 t& x' F( K9 [
8 g) ~( k! z% k3 |) P4 z; |#include "config.h"
# r2 m% r0 p# {. \5 t- j% h
1 P. J! [1 N7 t' I5 R( D% x0 v#define   keyin (P1IN & 0x0f)
: M& a5 }" C/ t' z4 N#define   Num_of_Results   32
4 ~; _5 n: B1 ^: `3 Z- A#define   cir_radius       305 A) r, z0 g  y. m# a! h- M. H
#define uchar unsigned char
  A: g2 w1 d$ C% a8 J# |! y2 H#define tiMER_CNT_NUM   50* p8 ^# A& `3 C* {$ m9 W; k; d, m
#define SPEED_CNT_NUM    200
$ [3 A8 i5 J5 D/ s#define SPEED_IN    P2IN) t) @& g+ ?' i5 I
#define SPEED_IO    BIT5! G' f3 B; [" N5 F3 j4 M3 ?, {
#define SPEED_DIR   P2DIR
, l. l5 n+ M7 a# T' F#define SPEED_OUT   P2OUT
1 Z' F* y4 y1 b7 C5 H3 ^/ Muint16_t results[Num_of_Results];    //保存ADC转换结果的数组3 F0 R9 w, y  `9 D& S
uint32_t average;
+ C  Q" g0 H: ?5 D* `4 Z; T+ juint8_t tcnt = 0;     //ADC计数
' u7 ~7 e& N" w9 X, R% Q3 u- ^) P. puint8_t tcnt_ta=0;    //TimerA计数. O2 N- _  e, x7 E4 f7 Y
uint32_t circle_speed=0;  //后轮转速
& Q( b1 W% W% [* u$ u" |$ r5 cuint16_t angle;
; }  Y' W  k' L3 ~( p9 {uint16_t start,end,T,sum;
3 E! t1 ~3 N* L$ C! x5 H) juint8_t oveRFlow;5 d' c9 k9 L& t, F0 O$ W% {
uint8_t ta_cnt=0;         //脉冲计数
9 ~  Q( E7 h; F& D$ Quint32_t temp_cnt=0;    //临时计数4 _$ ^# I4 |$ \
uint32_t down_temp_cnt=0;    //低电平计数6 s- W& w2 [( a
uint32_t up_temp_cnt=0;      //高电平计数
" u3 O  L  Y* q9 m1 wuint8_t down_cnt_flag =1;, Z$ W7 \# y  J$ \2 ]# O; e
5 {9 X& L6 O. X8 G4 t8 E  ]6 a  Z5 h& `  x5 G
" G  j: S8 ]- G; n' t0 `
" ]$ z# C" w9 Y4 h
void PutStr(uchar *str);  Z. {( v9 P+ `) a0 B* f8 h
void PutChar(uchar txdata);7 i) t8 |* D" B4 d+ V/ T
void printf( uint8_t *Data,...);
3 }! K* V& u0 I8 \8 Y. V4 iint fputc(int ch,FILE *f);7 a7 \* q3 j, g
void InitUART(void);
% n, m0 R2 R; ]6 t' m. r4 @void delay2s(void);
" i3 M6 O# n& vchar *itoa(int value, char *string, int radix);
8 P% D- ?2 |8 P7 s" m( Dvoid delay(void);
: m$ |8 B  s, rvoid clock_Init();4 `' D6 M+ Z6 [$ }. G- b/ @, S5 x
void TimerA_Init();
" E$ c1 n6 p9 x4 r/ ^$ [9 K) ]4 s: H2 b* v9 m& d
+ L( b5 l' E) x+ Z' Y* B
void TimerA_Init(){
# n! C* h8 {( L1 _' P) G( ~0 A7 {/ X" j1 U  ~4 \/ ^
1 E9 a; c7 o5 U1 I8 N5 g& o        //TACTL = TASSEL0+TACLR; //SMCLK, 计数器清除
/ c+ I1 K1 M) |1 B3 t2 A- o        CCTL0 = CCIE;
: f2 s$ r" }. `. F3 ^- T        CCR0= TIMER_CNT_NUM*1000;                 //配置定时值* `! I/ m9 V7 N/ w
        TACTL = TASSEL_2 + MC_1; ; P. q8 |  H! `* b% ~  g6 f" S
2 h! x* p# _" R4 U1 L$ B* B6 j- n: t  R- s  T# {$ o! v3 l. P
void Clock_Init()+ |  |6 W4 @+ o" H6 U0 m
% E, v4 |0 l$ E        uint8_t i;
( N  D* w$ A' Z, C        BCSCTL1&=~XT2OFF; //打开XT2振荡器
* ^" P" J5 o7 e  Q) O8 ?        BCSCTL2|=SELM1+SELS; //MCLK为8MHZ,SMCLK为8MHZ3 I4 X, x. ~" e, }
        do{! @0 |+ T- g, M
                IFG1&=~OFIFG; //清楚振荡器错误标志
2 \# t! Z! C) R7 `                for(i=0;i<100;i++)9 E3 V# w  i5 l7 x& v
                _NOP();- _' {6 Y3 I: Y4 @1 j2 t; m& Q
( F- R' g8 L/ S7 i        while((IFG1&OFIFG)!=0); //如果标志位1,则继续循环等待
7 d3 L/ t- E8 E        IFG1&=~OFIFG;
  C& A4 p8 G' ?7 U8 G* A; a}
, W2 _% \/ G5 P' l- a; b8 @# f" `1 N! r1 m0 o) C
- ?1 M: U8 F+ x' ]& W6 z4 |$ \" t) h$ i/ a* F. A
# C7 T! \3 ~% I# p4 e7 d- s& n4 v" k
+ G/ V2 ~  w1 b0 X1 C0 \/ p# o1 s8 c9 ^; i/ m2 S: S
#pragma vector=TIMERA0_VECTOR
; V. j' ^- h  x. W5 y0 k9 W8 Q. z__interrupt void timer_a0()
& {; D; F7 v; N{2 ]- X! t9 t; z( q: t0 {. K+ D
        CCR0 += TIMER_CNT_NUM*1000;: P. d) ?; W  [% G8 d
        temp_cnt++;9 C, z# O( H' O0 E( n
        if(temp_cnt>SPEED_CNT_NUM){
% m2 K8 Y% g+ `# A3 i          temp_cnt=0;
1 e% O& M% A; J6 ~1 f+ u! ?9 S# C' [          down_temp_cnt=0;
2 \8 J6 d' ]1 F: P, S6 g% S" ?        }* m+ o% P& D! |: c) `# X
        if(!(SPEED_IN & SPEED_IO)){
3 P7 K  t$ j5 k+ ^            down_temp_cnt++;
" S+ G% ]+ k' r! i; L+ I2 N  [
. B4 N* o+ `; C! q4 ?: D4 q  C        }else if(SPEED_IN & SPEED_IO){  m% |$ l$ A  J+ V* f# A
: U1 v& D6 g5 r1 l0 c- d
        }7 ]& }) z0 O+ e3 ~2 }, l
% _$ T" K: \$ J( c5 t. D
) Q" V  z8 z' ^4 A: c+ R5 S& [/ S2 p
9 {2 U6 B/ d5 v4 w# L/*
, @9 b* L, @2 }* L* [#pragma vector=TIMERA1_VECTOR //定时器A中断处理
; U8 v7 Z& P, S) a5 R__interrupt void timer_a(void)
* `4 R4 @4 m1 E- v1 t3 S{1 p% j4 _+ U' z; S/ A
0 c( `# B8 q2 p# Y2 @  B
; y% z+ A# c2 C5 @1 n, G1 h3 u7 o8 Z
        switch(TAIV) //向量查询
# A+ g! N( j' ]! F# _3 |0 _        { case 2: //捕获中断# J7 U* G, d. [9 Q1 Q
                if(CCTL1&CM0) //上升沿
2 P! ?: H1 m0 o! v' ^; l                {
/ O3 Q% K% Z" Z. V! B3 }                        ta_cnt++;* Z1 Q+ D* \8 B
                        P2OUT ^= BIT1;
. Y& U2 Q2 ^0 F$ _0 f* V  h                        Printf("%dtcnt\r\n",tcnt);9 w+ k/ I) h' ~4 ?: P
                }" G8 Q! q6 f3 e; I6 g
                else if (CCTL1&CM1) //下降沿
" F0 L- _7 F$ [3 S, v                {
0 e3 D& W2 Z/ B( K4 M9 H6 S, \( N
6 R  v9 `( M, S7 f                break;
& {) D8 R# g  Z: B        case 10: //定时器溢出中断4 b8 ]2 E2 r& [% q! A% W! I& K
                P2OUT ^= BIT1;+ A) T: M* E9 N1 [$ t8 J5 ^2 ]
                break; //溢出计数加14 j. I8 K/ o3 K! t9 h
        default:break;; c7 I# u: N$ W5 R0 Z* T
+ ?  D+ u" N- |        tcnt_ta++;4 \6 P/ R+ B1 l) `2 S1 k2 x
        if(tcnt_ta==200)* M; Z# I9 d; B$ F9 ~2 D  A
        {9 E; L0 p- t- i1 U3 A% j+ b( A
                tcnt_ta=0;! S2 ?( I7 c/ n4 Y( ]1 [0 x
                circle_speed=(2*314*cir_radius*ta_cnt*36);
2 U$ u$ u1 c; y- G( u; h# S2 a5 \                ta_cnt=0;
9 r' A1 o/ l* d( {        }
$ `7 ^' y" f  G3 ^
& i/ d( n- Z: O) x, s4 }- B}
2 N1 X/ {" v8 h6 R8 Z/ u" L$ g3 u*/# o; q3 k- r8 ~' G7 ^. g
/ g8 ?& h$ L0 x* g4 R5 S$ p, h  p% ~# p" P. E+ v8 A8 k. l3 d
) z; Y8 g4 O# J( G  ~4 p函数名称:ADC12ISR6 p6 o/ t2 n8 g- V9 X9 p
功    能:ADC中断服务函数,在这里用多次平均的' W8 E5 ]$ {5 B9 F% |; s
          计算P6.0口的模拟电压数值8 j2 X$ I. |8 x3 f7 L
参    数:无
# @9 K/ I3 R2 W返回值  :无
9 v: B* L0 `; ^" I. S. B. f" R: c********************************************/3 m# v( ]. c* b- _- ]0 _: ?
& }" J; M7 s$ g' b) c+ j  l% v2 E#pragma vector=ADC_VECTOR
" O! M0 M) ?( Q! A5 K# w__interrupt void ADC12ISR (void)
# A) n0 o$ Q; u4 u3 d{/ N+ u( s/ n; e. z
    static uint8_t index = 0;
! T1 M% P$ N+ D& p/ z" x    results[index++] = ADC12MEM0;               // Move results5 T- t" h# d( h+ [# \, z
    if(index == Num_of_Results)% D8 I  g" O" w% G8 A
    {6 y1 X$ f7 i; N- g! E( t  I
* ?2 p9 Z; f4 a* c- x7 i      if(keyin != 0x0f)1 ]% c9 C$ t4 k. V- }
        {3 r4 H4 U/ J; Q! K; Y: k
          delay();. N# ^5 r1 L- `) f: ^2 }
          if(keyin != 0x0f)
$ e) S- \( |/ V- t          {. n5 J# W# Z5 A; j6 p# M5 O
              while(keyin != 0x0f);* m  }9 [- }9 C3 T) {$ B
              P2OUT ^= BIT0;
0 [$ B1 _: e# U9 Z! o+ }                                  //uart0发送ON+ @$ W. c1 x& D  u; L6 b
              sendString("ON");
$ S5 T7 ^- j8 E# _, s6 M          }                % D. R) |3 j) E' ?0 p
  R- T& V  [" l6 \9 _. ?        */* {+ l( f6 c# e# X0 R$ _6 O
      delay();! U3 v# A# h$ n( r
        uint8_t i;5 l. n% n( [( j( E, r5 ]/ p2 f! }
        average = 0;
, N$ J1 Y8 Y4 x! X3 b6 O' C# p& n        for(i = 0; i < Num_of_Results; i++)1 P' U2 J. C7 _5 g8 P. S
        {, @5 |( }. t: J0 z: C" `& q
            average += results;
$ S# Q5 Y  k/ }  l3 d        }1 Q6 \" _/ b' q& ]6 X# L
        average >>= 5;                            //除以323 k; s* t/ h5 a
        index = 0;
0 N& R8 n: E" M" j* H" X" e6 C" [0 b                tcnt++;
/ K6 b) h. z; v5 W" e1 ^        if(tcnt == 200)      //主要是控制串口发送速度
% m; j7 ?4 t1 z, a        {
; F/ T( \1 X* ~8 _1 H; m7 r% |$ F4 m            LPM1_EXIT;
8 H0 a8 e% S4 p3 C) W* P# W            tcnt = 0;( D3 N4 o* k' u2 w
        }8 y' |/ [0 Z/ u3 F  Y, [& Z
& H4 s, g* l4 |9 X3 Y2 l& P}! m: w6 X9 i& ?: `) W
8 [' g$ T$ S5 ]  M
void main()1 s3 J3 m/ F" N; T7 ~9 f% M6 W
{* A7 S8 B8 X1 x$ s# n! X- t
  WDTCTL = WDTPW + WDTHOLD;7 T* X9 V6 ~9 p
  P2DIR |= BIT0;3 S/ ~5 q* H0 S7 B
  P2OUT |= BIT0;   //L8输出,熄灭   为1熄灭,为0点亮
* R+ z/ s# H! e7 \0 Y  P2DIR |= BIT1;9 d8 k) {" y6 d  X$ B. l
  P2OUT |= BIT1;& y. q$ P3 Y; v$ x0 n
  Clock_Init();
, l9 U& q* O9 ?  v+ T9 g  TimerA_Init();8 J: r5 H9 L4 i. X2 N" n
  InitUART(); //调用初始化函数
2 |' b5 l! W) h  H; e3 l- r+ e  Init_ADC();
- V$ d5 X5 ]2 d6 Y5 P1 U  _EINT();- `4 E9 n7 O6 x! F$ e" f9 F
  while(1)
, p/ I1 G* w6 x  {# `4 K* s( ?6 `3 }
        LPM1;9 n$ v0 [) E( O  W
        circle_speed=2*3.14*3.6*cir_radius*down_temp_cnt;
+ Y9 M# V' c! f/ u5 T! A        angle=(360*average)/3300;0 w, ?% s: r6 l/ d
        Printf("%dkm/h",circle_speed);
" n( Y8 l0 {* Y! y& s        delay();
+ E4 J8 S- H# U* X' e+ s        Printf("|%d\r\n",angle);
6 C. u# s! s) x; w* H7 o& N$ q' v  }# ^* {- d. `  B/ M; Z
}) S" J  M/ H, K# @" I# E
发表于 2022-7-7 11:21 | 只看该作者
欧姆龙是鼠标里面的东西
发表于 2022-7-7 16:35 | 只看该作者
太能折腾了,好好用鼠标,不行吗?" b8 h2 l3 B- B' l7 d% S4 M7 r
GMT+8, 2025-10-9 14:43 , Processed in 0.156250 second(s), 24 queries , Gzip On.
