查看: 167|回复: 2
51单片机控制+MAX7219+DS1302 电子钟
发表于 2022-7-6 10:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/*************************************************** t$ K8 k' f# h+ t- I9 Y
*程序名称:  MAX7219 C语言控制程序                            {; d6 @  K; e6 e7 |
*程序功能: 3线串行控制8位共阴数码管
* z$ D# D% v. l2 J( q& ` *3线定义IN 串行数据输入                                                  + ]3 w9 r& S% u) Q! P3 `/ m
*                 LOAD  数据锁存                                                          & @* S+ F3 o3 w3 {# k+ G* Z( x
*                 CLK   时钟输入                                                          $ R9 i3 V- t0 C5 I
***************************************************/, F. P3 p# n/ T) P7 m/ f, \. P
#include <reg52.h>2 W4 h3 H+ T0 C# {5 ^
#include <intrins.h>
' n% O3 l/ u) y& n#define uchar unsigned char
1 C0 d) J( d! U#define uint unsigned int
/ T. ]* S; t; [3 k# Y
& l( M, q2 N! O& B; J) j" lsbit sclk=P1^0;6 b+ F, g! g! K) g; d0 d; T
sbit io=P1^1;9 b$ V# F$ E8 x7 H9 K. W
sbit ce=P1^2;
$ p* @; v+ T, C8 L! h$ Vuchar time_data[]={13,6,4,17,21,51,30};//? ? ? ? ? ? ?' z- n6 }5 Z& S# \, p
uchar write_add[]={0x8c,0x8a,0x88,0x86,0x84,0x82,0x80};
) N- U/ J" `; Ruchar read_add[]={0x8d,0x8b,0x89,0x87,0x85,0x83,0x81};  ^. o/ }7 c+ N7 Y2 z$ K
sbit pinDIN=P1^3;                        //串行数据输入端% _4 \  y8 U+ i. v" p+ H+ }
sbit pinLOAD=P1^4;                        //数据锁存端
8 j, U3 m2 \1 ~/ w8 S3 usbit pinCLK=P1^5;                        //时钟输入端
. E* O# j& O$ ]( l. }#define uchar unsigned char
& |8 ^0 c7 R; ^1 }+ s) h, Kuchar p=0,num;/ _, F. r+ u! ^/ _2 |% ?
uchar disp[6];
4 J/ O# O! @4 _9 U! Z uchar code LEDcode[]=
8 C( ?( V+ Y5 t) ~; T) c' K {0x7e,0x30,0x6d,0x79,0x33,0x5b,0x5f,0x70,0x7f,0x7b,0x00,0x01     /*0,1,2,3,4,5,6,7,8,9,全灭*/+ c- B* l4 R, X% P
/* 0x77,0x1f,0x4e,0x3d,0x4f,0x47,0x67,0x3e,0xff, */  };    /*A,B,C,D,E,F,P,U,全亮*/
0 a' `8 k! D+ @+ S- X3 x
; s( f/ X; z( y5 o& }$ y9 J3 Ddelay(uchar x)
0 ?) u0 h1 `* }9 s) o4 ~& @{2 ?- q$ E: \* u
        uchar a,b;
, l2 c" L% q( V- g        for(a=x;a>0;a--)
! t# F8 I0 V- h0 [                for(b=200;b>0;b--);
' B% o6 w* a  n) Z* d( r}
1 o* w( W+ B) }7 X
, D) j5 ?. g' Y$ _' D' [) _) n/**************************************************$ C1 {! L- _; h/ N$ Y
*         向MAX7219写入字节(8位)函数                      *
/ S6 Y% w1 W& B9 g5 X ***************************************************/9 q- b; N/ [# \& S
2 ]( R$ c, n: P- j" |/ Bvoid sendbyte (uchar dat)
; e& y$ q3 `) X0 F {
+ H  U* r% C) Q% C$ S! o; B         uchar i,temp;% B# M. \' P, e& `/ G* |8 Q2 a
         _nop_();
+ m' q) v2 V1 k- x+ p         for (i=0;i<8;i++)
! v/ W: @/ b6 H9 n0 M    {
; D9 l/ n1 a9 J. [8 ]! |        temp=dat&0x80;, d) H4 F9 a! w. Z1 x, U; z; ]- e( u
        dat=dat<<1;0 n2 p' N( S+ o/ l/ M
        if(temp)3 M- o/ @  H1 J+ |) ]
            pinDIN=1;: n- _5 c# s5 N) i2 `' a! s1 Q  R
        else0 c" E' e7 t9 u
            pinDIN=0;3 Y" n& T6 J$ z, C
        pinCLK=0;6 _+ L7 ^2 e1 F" C. C
        _nop_();- ?+ G1 s* R+ Z7 A& ?/ p
        pinCLK=1;
/ n9 P& \2 _1 j: ~; u+ i" N    }
3 _! e% t4 ~0 M+ L( I. f# Z) m }) C* S8 f; F; W# g& {
/**************************************************$ G, {# `# K/ H" R
*        向MAX7219写入地址和控制字(16位)                  *, W  h! q% w* E1 C5 E, C
***************************************************/" ]0 o2 a0 p- c6 U7 M0 n
void sendword (uchar addr,uchar dat)
" Z3 i+ ]5 g8 Z0 { {% w# L, s6 @. O5 F" }1 @
         pinLOAD=0;5 J% ]# B2 R4 ]3 k  j" F! Q# {3 S
         _nop_();9 R) L7 }8 y5 E5 C. W! A5 I
         sendbyte (addr);' h: `: \/ L: X7 h
         _nop_();
9 K& H1 o  @$ J1 k0 R0 w, R         sendbyte (dat);) P# _, |3 y  E% V$ w0 U8 \6 C
         _nop_();/ }7 T) e7 G7 C4 `  o+ ~
         pinLOAD=1; //第16个上升沿之后,第17个上升沿之前必须把pinCLK置高,否则数据丢失
( n# y5 G1 x% f. e% U0 i. s}9 ~7 ]' r4 X. a) N# S4 B' S
/**************************************************( r0 S$ `. |# Y+ P! }
*                MAX7219初始化                                          *
! A5 _% O: u# h' Y ***************************************************/
0 i0 h3 c2 R4 S0 ]: B. Y7 A; Gvoid init7219 (void). F$ J* D3 H4 |
    {& K4 D( r. c* j
             sendword (0x0c,0x01);     /*  设置电源工作模式      */   : G# w/ g" V0 s- s
             sendword (0x0a,0x03);     /*   设置亮度  19/32      */  $ u9 M$ f# H8 ~4 p
             sendword (0x0b,0x07);     /*  设置扫描界限          */, l6 E$ ~$ Q4 D# b' E% j: ?" f( e
             sendword (0x09,0x00);     /*   设置译码模式         */# ]6 S$ I. _) L0 W4 |+ K& }* j9 E- u
                 sendword (0x0f,0x00);     /*显示测试 00为正常工作状态*/+ B8 B, _& C% v' F
0 i- i5 z' M( W /**************************************************
: A8 Y& I5 y" a9 r8 d! G2 i *                MAX7219清除显示                                  *6 K9 _9 H) i3 U6 t. s( o" s
! l! |5 n  f% W& x& v$ j7 G5 qvoid clear7219(void)
% g) O( {3 Z' ?7 D9 k7 x9 H {, T, W" A" O3 A, f) D' j
         uchar i;
' M4 p+ }9 Q, A/ H         for(i=8;i>0;i--)
9 a2 h5 b( e' B8 e, j( K' @         {
* B% ?! C9 Y( C& u; g3 [                 sendword(i,0x00);
% Q$ L' ?$ J( S! B         }
. D* Q1 u& j; }/ p! m% n9 I/ i# o }
! S7 U1 Y/ Y: q2 j, r3 M/ d  d: R/ n0 `* }0 Q/ z  R8 `
, \. a( E, Q. I7 g; V- e+ |
8 G1 c, C6 a1 _/ v9 ]* rvoid write_ds1302_byte(uchar add)6 I" l5 R& W0 M- h9 i* `& ?& o2 n
; ^7 G4 g6 p# e  G        uchar i;
! s) Q" z8 L4 {3 d0 ^4 z        for(i=0;i<8;i++)
, _4 @1 X& ?" b        {
& P4 N, Y/ j$ n; _: Q                sclk=0;: C" l1 R$ Z) x9 P) g
                io=add&0x01;: f. m* H. W8 `9 K1 ~& m
                add=add>>1;; j: f% s( k1 J
                sclk=1;
6 W7 @6 D0 S( P$ }7 C# C        }
- k  ?/ E/ j% V9 z  X* m}& ]  l6 @: s' ?" [4 m
0 w- A2 Z8 t, Lvoid write_ds1302(uchar add,uchar dat)
4 m: n5 {' a  K% B{$ _! z, k* @" V, Z& P( n- k7 T
        ce=0;
3 y2 b8 i9 ], R  e# n        sclk=0;
( }4 A8 `( m& U8 K5 E# [& x        ce=1;
) H1 w2 d4 A0 ]; E' y        _nop_();- w8 f4 y  w, W) E) t" Z
        write_ds1302_byte(add);% s, m/ K# G* w& r
        write_ds1302_byte(dat);- f% g: t- Z1 X. f. g
        ce=0;: J2 L( w( X3 ?2 l/ `* g
        _nop_();/ I0 i7 e3 O. e/ Z" h6 r
        io=1;
' K  }2 [6 l+ f* Y* n* @+ |! q        sclk=1;
3 m. y+ r, t$ b! }}% W, W* T& a/ `7 l* {- d
; \+ h6 j, B* Y, fuchar read_ds1302(uchar add)
, A3 _! G/ x. x8 G: o, r  ^{2 w7 C. a! d6 n+ n" {
        uchar i,value;
1 Z* A, p6 c) U7 q9 S7 f        ce=0;, s3 w$ z: i7 ^% K
        sclk=0;5 u8 R/ P2 P5 b: X, R* p  @$ w
        ce=1;
6 r+ `! Z$ t* R        _nop_();  F, s' O' B. d7 `' P# Q( v" l; K
        write_ds1302_byte(add);. r7 z; c/ A( ]) p0 `
        for(i=0;i<8;i++)
% w: @" N" T. A+ ^# O! U        {( z( J4 `6 Z/ N5 S
                value=value>>1;
+ v( @+ \8 s/ D5 W                sclk=0;9 A; x5 U& ?* m4 d' Y- r! B3 D5 {  |$ O
                if(io)
2 F" N9 h7 o: W" J: L6 u                {
, m" K! M* [& H                        value=value|0x80;        6 r4 h: l" b3 k$ C, N
" Z0 r, x, H7 Y% k2 N                sclk=1;
, b: \* L3 T. R/ y' t        }) t+ W: `- u+ h1 P# |. K; q' B
        ce=0;
/ x  q; U% b& A        _nop_();
" K5 w/ O. C$ y        sclk=0;0 M$ T/ N# `2 }% k5 Q
        _nop_();
9 `" S: A0 @1 l0 q0 E1 K$ I        sclk=1;1 T" L- e( Q) L- E$ Z8 ]& F
        io=1;
4 ]$ j# \% h2 r/ g9 b! p* _' M        return value;9 A/ n6 ?5 H) \' z( q
}9 S3 X6 j0 h9 t, f
6 t6 A. m' ?+ ?8 K% A
void set_rtc()
" q) t* o9 I/ n; Q: }+ H{
3 {& `; k  ^! L& @        uchar i,j,k;
0 t, {, D! b, e9 t- F        for(i=0;i<7;i++)5 s5 T& S% \# j/ @
        {0 l2 L2 T$ Q8 U$ b
                j=time_data[i]/10;0 D% ?# U1 p7 ?" T# D( U6 J, `+ W$ w
                k=time_data[i]%10;# ?/ h3 I- Q# L9 {; ]
                time_data[i]=k+j*16;6 I% J  s* i& w# _
        }. H+ l/ _" G, |3 a# j9 h( C
        write_ds1302(0x8e,0x00);//?????0 B. D% D" ^, j5 L7 u# _
        for(i=0;i<7;i++)
7 M0 L  S" M) x+ `        {
3 f  v1 F0 t& e                write_ds1302(write_add[i],time_data[i]);
( Y! {* V. ]' C4 Q        }
8 _$ Y$ U" @+ Z6 G6 e        write_ds1302(0x8e,0x80);//????
6 H" w* |6 O$ K# s9 {}' S1 g% \! \: V9 y
' q! j! Q& T3 V+ H1 S2 w7 k! lvoid read_rtc()
% G& l6 W! F8 ]0 x8 J8 S1 N{2 m) z1 P. d0 z, ^; `& b
        uchar i;
, X! `% P9 C2 E7 y        for(i=0;i<7;i++)
9 g7 H* d% f1 G/ K9 \. Z        {
' Z# |8 O. d* G5 a# h                time_data[i]=read_ds1302(read_add[i]);
- @7 g! Q9 A1 u4 {; f% m* {        }
; }  _1 o0 G, H. v8 b0 o. C}
" M* `- p% a3 c: \4 L! B3 @+ ?
2 F/ \  q; _1 `* i
发表于 2022-7-6 11:19 | 只看该作者
#define uchar unsigned char声明了两次
发表于 2022-7-6 13:12 | 只看该作者
学习了,谢谢分享,如果能加入按键控制就更完美了
GMT+8, 2025-10-8 18:28 , Processed in 0.140625 second(s), 23 queries , Gzip On.
