查看: 169|回复: 2
单片机练习小程序 数码管从左向右显示
发表于 2022-6-28 10:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这是我单片机学习项目& K) r+ n  @& e/ v) {& ^' j
可以当作学习单片机的小练习9 B0 j& n$ z" T3 f- F# K) b' V
半个小时完成的,附上代码
: y* l) Y2 z5 B9 |欢迎大家一起来交流学习" }6 ]1 \% |  F2 J$ [1 @, E8 {
" n( Y6 U# g. S/ R8 P' T6 O
单片机源程序如下:
1 A2 i+ A! K. @3 r0 }! r' q
  • #include <REGX52.H>
  • #define N 50
  • #define Fosc 11059200L
  • #define INT_PERIOD 5
  • #define OveRFreq (1000/INT_PERIOD)
  • #define ClockPeriod (0x10000-Fosc/12/OverFreq)
  • unsigned char code DispSeg[] = {
  •         0x00,
  •         0x06,0x5b,0x4f,0x66,0x6d,
  •         0x7d,0x27,0x7f,0x6f,0x3f,
  •         0x08
  • void Delay(unsigned int xms)
  •         unsigned char i, j;
  •         while(xms--){
  •                 i = 2;
  •                 j = 199;
  •                 do
  •                         while (--j);
  •                 } while (--i);
  • unsigned char Buffer[]={0,0,0,0,0,1,7,2,11,3,5};
  • unsigned char show[6];
  • unsigned char j=0;
  • unsigned char timecnt;
  • sbit K1 = P2^0;
  • void timer0_init(void)
  •         TMOD &= 0xF0;
  •         TMOD |= 0x01;
  •         TH0 = ClockPeriod >> 8;
  •         TL0 = ClockPeriod & 0xFF;
  •         ET0 = 1;
  •         EA = 1;
  •         TR0 = 1;
  • void change()
  •         unsigned char i;
  •         for(i=0;i<6;i++)
  •                 show=Buffer[i+j];
  • void Display()
  •         unsigned char i=0x80;
  •         unsigned char *ptr=show;
  •         while(i!=0x02)
  •                 P0=DispSeg[*ptr++];
  •                 P1=i;
  •                 Delay(1);
  •                 i=i>>1;
  • void state1(void)
  •         unsigned char tim,i;
  •         for(i=0;i<6;i++)
  •                 tim=N;
  •                 change();
  •                 while(tim--)
  •                         Display();
  •                 j++;
  • void state3()
  •         unsigned char i;
  •         P0=0x7f;
  •         i = 0x80;
  •         while(i!=0x02)
  •                 P1=i;
  •                 Delay(500);
  •                 i=i>>1;
  • void state4()
  •         unsigned char temp,i;
  •         temp = 0x01;
  •         P1 = 0x00;
  •         P1 = 0x02;
  •         for(i=0;i<7;i++)
  •             P0 = temp;
  •                 if(temp == 0x80)
  •                         temp = 0x01;
  •                 else
  •                         temp <<= 1;
  •                 Delay(500);
  • void keypre()
  •         if( K1 == 0 )
  •                 Display();
  •                 if( K1 == 0 )
  •                         timer0_init();
  •                         P0 = 0x00;
  •                         Delay(1000);
  •                         TR0 = 0;
  •                         while( K1 == 0 );
  •                         while(1)
  •                                 state3();
  •                                 state4();
  • void main()
  •         state1();
  •         while(1)
  •                 j=5;
  •                 change();
  •                 Display();
  •                 keypre();
  • void Time0Interrupt( void ) interrupt 1
  •         timecnt++;
  •         P1 ^= 1;
    6 h3 {* M/ r9 h: N
6 ]* d2 M& o9 Z, _, o! g/ M* [3 D
7 K; a. u% g: w8 ^& O
发表于 2022-6-28 11:21 | 只看该作者
看看,(*^▽^*)
发表于 2022-6-28 13:21 | 只看该作者
分析一下,学习学习
GMT+8, 2025-10-8 18:29 , Processed in 0.125000 second(s), 23 queries , Gzip On.
