分享最新版altium designer 10.651.22821下载地址!
0 }5 L* t. s6 Y A3 J' v
1 M4 _ R# ]5 }& T$ d追逐Altium公司的脚步,分享最新版Altium下载地址!!
! F$ ?3 b% `/ O# n, y! a: W
$ A4 A. [# n( o% T: z* i
+ e' U0 c9 {0 g! {http://dl.dbank.com/c0xszn9n0h
2 E- u M, P( H4 }( Z& b6 ^* ~. ]% J: Q! |$ X; i
' t' t( j0 o7 E, y
更新太快。
. m# c* ]' j' K7 Q/ _+ N( ~
1 m. s% c1 m7 M3 n7 b" w5 O( e
Updated plug-ins from release 10.600.22648 to 10.651.228214 o4 R7 \! S, H5 w& H
Date: 15 September 2011
9 M& ?( H1 k* ]# Y e% |" }! p. X6 H# K0 \
9 S* e0 b0 I$ O4 F0 V
3 R/ y9 q" ^. B1 _, ]
' t! N" N' r1 sSystem Components: Altium Designer Base
( V) ]9 m% S) a" ~2 d1 Q1 I/ v5294 Display the license Subscription Status and date.
" Q) z) U k0 `$ a) P3 USystem Components: Altium Designer Installation System/ e: \, ]6 j) n4 `. ]# r
5294 Display the license Subscription Status and date.$ [( j1 x/ b. d/ U
System Components: Altium Designer Localization: N6 {' \& ^+ r2 x( P0 L9 c' v1 w$ K
5041 Japanese localization of Altium Designer updated. View BugCrunch report #898.
3 o* I# I' A% m: f' B( H+ f5056 Simplified Chinese localization of Altium Designer updated.5 F; U b1 A! v H; s# I' _
5057 Korean localization of Altium Designer updated.
3 S5 V$ ^% d5 M" q, s, z5365 Traditional Chinese localization of Altium Designer updated.* |& f5 W# A% w+ u8 c% A$ e& |
5376 French and German localization of Altium Designer updated.7 b0 t0 v$ w# \ |
System Components: PCB System
% u- `' i" c3 h" d% |% `4846 When creating a PDF in the OutJob from a 3d Print job, the PCB editor no longer keeps the board flipped. View BugCrunch report #387.
) m2 x" a' o3 A- x5 d2 [3 T5258 Streamline the operation of "Configure Physical Nets" batch dialogue so it allows multi-selection & update of multiple rows & also speed-up the display of the RMB pop-up for design with more then 500 nets.% n) S* e8 F# z# Y/ Z
5298 A crash that used to happen while resizing split planes by moving track vertices will no longer occur.
/ U; A' O! E% b- m& d& MImporters and Exporters: Importer - allegro
+ b8 m$ D1 d& l' \+ W+ g" H9 W* P5268 Allegro Importer - A recent modification to correct import of differing Top-Mid-Bottom pad shapes impaired proper creation of some single-layer SMD pads. Single-layer SMD pads are now imported correctly.5 T2 q/ ^0 ~4 @; s. P# Y6 U/ N8 W
Importers and Exporters: Importer - PADS
. {2 a5 a' h7 s3 E4862 PADS Importer - Pad and via test points are now detected and properly processed during import of PCB designs.' ~& C* j( P. N d( V3 w! r
4926 PADS Importer - Zero sized pads are now discarded during import of pcb designs and libraries, with messages to the log file.
. _' G- r$ S% Y1 b d5052 PADS Importer - When importing PADS pcb designs and libraries, mapping every layer is no longer mandatory.
1 E" Z1 ?) b4 h/ S& c5188 PADS Importer - Differential pair rules are now more reliably imported from PADS pcb designs.
6 B3 }& x1 |0 Y5 i3 |Output Generators: Output - AdvPcb3DPrint
8 K: A8 A8 X1 k' J% Q, l8 J* a4846 When creating a PDF in the OutJob from a 3d Print job, the PCB editor no longer keeps the board flipped. View BugCrunch report #387.# S1 f2 Q' [* P, O, M/ t
Output Generators: Output - Gerber
% Y/ k$ u9 N) D7 e- I5118 An error when generating ODB++ from PCB designs that have components with invalid 3D Body Snap Point count has been fixed.
/ p$ a- m3 D4 |' \5283 An access violation that used to happen when generating ODB++ for PCB designs containing Embedded Board Arrays (EBA) that used mechanical layers > than Mechanical Layer 16 will no longer occur.
3 [) |6 j$ ]6 I" @0 G! Y. z5302 ODB++ Output now correctly exports components that have the reference point different from any of the pads (e.g. component centre).
+ m# @2 R4 [& a+ N& s/ F pOutput Generators: Output - ODB0 K9 {& p3 O1 D( Z1 P: f- g: C
' J" o1 }) H, ^5283 An access violation that used to happen when generating ODB++ for PCB designs containing Embedded Board Arrays (EBA) that used mechanical layers > than Mechanical Layer 16 will no longer occur.
& t6 [# P9 Z; N7 n( ?6 ^. q+ m5302 ODB++ Output now correctly exports components that have the reference point different from any of the pads (e.g. component centre).
9 S: a$ p7 C8 y6 O5316 ODB++ output no longer generates incorrect image & eda package data for offset rounded pads. View BugCrunch report #734. |
