请各位解释一下以这几个键值怎么的出来的
/ X" s: _6 D: h( q以下是部分程序:" K3 a* E7 j/ Z4 v$ E+ y
---; c, Y% ?; e( U ?( O! `6 b
#define uchar unsigned char
3 J/ F5 ]+ t$ N& H( W7 w$ O; f" G#define uint unsigned int! Q- H; ~$ c8 g) j: z
#define key P1 ; a' s3 p9 Y2 I. |" X
#define dataout P3( \* D; a$ F3 a1 g' `
uchar data keyword;
3 h( S) k/ q7 X4 c8 O---
0 M2 ~# `4 a& bvoid keyscan() //键盘扫描函数4 N1 T: L! m% j2 b* V) u, R5 G
{ ) h. u3 g3 u- J S/ ~
keyword=key&0x3f; 3 X- m+ X0 _" {" n% c( i
if(keyword!=0x3f) * O! L9 D+ J7 n* q8 |% \+ O! J: C5 F
{ . x6 a4 l% ~3 y$ @. l
while((key&0x3f)!=0x3f); //等待按键松开 ) D6 ~9 Y' N, g3 k. ^ s* M
switch(keyword) ' e( a& C1 G8 Q( b* j% a5 B8 M
{+ W5 c h2 d! n5 Y
case 62: {;}
( u9 K: Y6 ~; `7 c3 ~) ?- i case 61: {;}
6 c) Z9 p3 j( R1 n+ Q8 V; b- L# q# z1 O+ |$ J
case 59: {;}
2 ~4 P* \4 d5 `+ U/ M5 \ case 55: {;}& H ^3 e! g1 F2 f
case 47: {;}
: u7 m5 T. }7 b, ?7 ~5 r6 Y. t, ] case 31: {;}
0 X0 K* H" N/ u+ |. K}
& v/ m! p4 G. e5 g) l8 Z* A8 b}
1 G2 ?7 H6 }7 I, \$ U& H |6 H}. Y0 R \3 Z- [
' E3 g( l: e ^1 m
提问:
* h" q5 k( M c1 u( G3 n(1)键值62,61,59,55,47,31怎么得出来的;
/ f8 M5 i T N4 W8 _6 m8 y5 K(2) 代表哪几个按键或对应引脚。
9 x7 z+ H; B" F7 D/ d
6 f6 v; m2 E* k Y) r5 ^# o9 _ |
