#include "reg52.h" # Z3 v( U4 | n2 H d7 d
6 g5 f& y+ l# m- q8 x3 v# _* ^
typedef unsigned int u16; z6 i; [1 j: x q3 ~7 Z0 G
typedef unsigned char u8;7 d2 p- A. P% o' ]3 G2 T" O* S
sbit ROTARY_MUTE=P3^1; //按键! @% C Q' S7 P5 O6 [
% r8 m: y P n+ B) z w8 S* U+ }: g; Q% ]
void keypros()
5 `; W) L& h) N/ K( O{
2 s" _7 m8 X3 e3 c, L0 q- x+ F' m6 Q% X static bit key_down=0; //按键按下标志位
) G+ I4 r) t$ q static key_down_num=0;- k( O. [$ @. h3 m6 q% M
static u8 count1=0;
" T$ p8 k% t3 _$ i; S7 B% | static u16 count2=0;3 ]: c0 M3 z6 y- o: G3 j* Q) V
if(key_down==1) * t& @ |4 h+ }/ f. w+ ?: e
1 q# \" E* p4 S9 j count2++;
4 X& u5 e: p9 x% M; g" a- _$ q if(count2>20000)
3 F' u. ]8 E- R" g. [& V {) N9 I9 k* b' F: ?+ A' f+ D
count2=0; 3 X; q: M% T/ V: y7 O8 g7 a
if(key_down_num==1)
) w: \' e+ r0 v8 V6 d w% Z {
: [2 p) l: R0 P& \% t key_down_num=0;3 i3 Z; f) Q1 S# d9 x$ S
P2=0X01;# }/ x& p+ `' V4 y# _: s
key_down=0;
z( T K3 Q) \0 H9 o& w6 O }2 w/ z n: q4 T% ^6 B3 i
if(key_down_num==2): z3 i- k1 t6 f: W" |5 `( ^4 q
{1 E3 d: V% a J
key_down_num=0; h4 x0 u0 s `+ E7 A
P2=0x00;9 P$ T. V: z* m ^
key_down=0;# b' [1 m; g% H2 l# D4 l o
, T& W& b, \7 K. ?5 ~4 w8 L }
9 Y; M& \) l* k if(ROTARY_MUTE==1)
5 A" w1 m6 A' {1 F- o {% X% ?( \! j c2 B6 O7 ^
if(ROTARY_MUTE==0) 6 l# @8 s9 {5 p' e
, a4 P0 L$ X" M. N S) v; ` key_down_num++;
$ {! u, c7 c1 K0 b }3 b$ C5 |- H5 h: }4 l# h) ?
0 d$ K/ h9 L4 {: \ }
, x2 e# X: `0 `5 b2 D
9 X% z: W$ Z6 ?6 k else
; D, J3 L/ N" n0 |6 z# ~: U1 H {
H4 U3 |1 X9 x/ U5 K- X if(ROTARY_MUTE==0)
* B; K7 t2 C9 x- N J/ H7 x6 n {! ~6 a8 u% Z M6 i- P; B; [" {, j
count1++;
+ f, W3 f7 v7 w+ x# |. S' h if(count1>100) - H- }. d$ Z0 m- ?
{8 \ g! c& v- o
count1=0;
" E8 o' X0 R; J$ x1 J* P if(ROTARY_MUTE==0) " C, D2 p# z& i
{3 j/ `# o# x+ R# |( P( ]
key_down=1;
" t5 Y2 K- g( E; g key_down_num++;
! ?9 r. \7 q* f' M$ @$ Y }9 R+ x! F, _4 E( a( ?* N4 h- K
}! A0 W9 o H& M: d
4 {6 h5 p" b8 E* l0 n else0 |! X G v G X) R" d7 j
{. } p: k! z2 w4 l& z' f" |8 q
count1=0;
3 F8 I1 z, F/ B7 ~ }; C" ^, u- ?! r. Q6 `" q
}8 q$ c, X1 M: p, L8 f) d Z9 q7 b
$ s$ E0 w1 d% w/ @% U
% d+ I+ S4 ?2 m5 a; x/ l1 n. {* {}: E: n$ M/ e! Y1 e5 Y0 ]: e
1 Z1 i V! ?2 G0 y6 ^' d# Z. o2 t, Y) T7 n- R% B
void main()
1 }2 a8 t0 Y4 e6 _0 i{ 9 F, U( f4 x9 N. r! D: \4 N
while(1); M. { V/ q5 u: g
( N) d' O" a3 j" y. `) G! I. p+ { keypros(); //按键处理函数 + ^. p3 K! C$ T7 @
} 0 V# K0 R3 }8 b+ r% w2 o
! S3 v9 Q$ b% D0 S2 j/ _: Z. z# k2 m, w w% Z
