刚接触DSP28335,CCS5.3编程环境,XDS100v2下载器,同样的程序和配置连接下载一个老板没有问题,现在项目需要用了一个新板,但是连接测试错误,错误信息如下,求高手指教。) j H6 f- Q- c6 t E
[Start]
4 H2 ?* k3 z( ]/ r) Q
1 U. G( F! t u7 k0 X4 @9 G3 i9 FExecute the command:9 m6 U$ n: q; N9 _) u
. ~* f+ i( K7 H%ccs_base%/common/uscif/dbgjtag -f %boarddatafile% -rv -o -F inform,logfile=yes -S pathlength -S integrity7 H# A3 Q) m0 ~, I
( m$ I! S' Z4 D6 E: Q
[Result]
% Y+ w: F% f, Z4 E* k T; f: b. Q$ K6 ]. j* j3 G' i, X! _1 R' P
2 c2 @1 ]$ A+ [, \ P
-----[Print the board config pathname(s)]------------------------------------
* O1 f. G; k( C) H* M& {' l9 P/ o# s0 v9 Z9 e/ ]' T. P
C:\Users\ADMINI~1\AppData\Local\.ti\4084209646\0 |7 p* ]8 ~. J0 ^
0\0\BrdDat\testBoard.dat' g7 }: |3 E! Q# }
- I% v! ]$ A7 n9 {8 _2 t" E' A; l-----[Print the reset-command software log-file]-----------------------------3 L3 j+ X* u- R
$ i- [2 C$ `3 _- TThis utility has selected a 100- or 510-class product.
4 _. ?. ?/ H& L$ H: `* s2 }! KThis utility will load the adapter 'jioserdesusb.dll'.! @0 r9 G5 M: \7 Y2 y% T
The library build date was 'Oct 3 2012'.3 F# T k0 k# @ x
The library build time was '21:58:41'.
/ H. i: i( h- Q0 z. Z( J' j( qThe library package version is '5.0.872.0'.
6 Y8 s2 z& z+ ?0 C# YThe library component version is '35.34.40.0'. e9 l8 G) m( ?( g0 ?$ I. p9 I
The controller does not use a programmable FPGA.
: R( w1 I2 Y0 X3 D* e n1 R/ }! SThe controller has a version number of '4' (0x00000004).
0 y: q& e& q b m" R/ O/ Q- }The controller has an insertion length of '0' (0x00000000).* }7 p; t9 u7 n
This utility will attempt to reset the controller. b, O; ]/ S' q# u o/ K5 n% c
This utility has successfully reset the controller.& `$ W1 \% f5 y+ L
3 `- s$ J7 g& f% l% F
-----[Print the reset-command hardware log-file]-----------------------------
, o: I' m7 w# z# l1 i) Y5 e% O& y! T) [2 G- h4 f3 O7 A+ K
The scan-path will be reset by toggling the JTAG TRST signal.
. j; r1 G, d9 ZThe controller is the FTDI FT2232 with USB inteRFace.
, S }* b$ q6 q" q4 w* ^/ wThe link from controller to target is direct (without cable).
" l0 \4 k+ ^9 r- `6 F, SThe software is configured for FTDI FT2232 features.9 J$ B$ A* E* e) w. S0 I
The controller cannot monitor the value on the EMU[0] pin.9 O3 Q: r6 |8 x
The controller cannot monitor the value on the EMU[1] pin.$ Q8 G J2 w: C
The controller cannot control the timing on output pins.
0 c U2 e5 J) SThe controller cannot control the timing on input pins. n# }& q' i! Y$ H# D% Q! e
The scan-path link-delay has been set to exactly '0' (0x0000).
, x: y) v6 G6 v" B: S
: v" R G: m5 q-----[The log-file for the JTAG TCLK output generated from the PLL]----------0 H' H# U4 i" v8 I# o
, p; Q# K# ~ |% H7 \
There is no hardware for programming the JTAG TCLK frequency.1 B& k' }1 Z5 ]: i9 |9 |
8 {+ Y, U! h8 ]-----[Measure the source and frequency of the final JTAG TCLKR input]--------! ?: [" v5 X; S& K5 I
+ D2 b" m4 m& a6 V+ J8 F3 xThere is no hardware for measuring the JTAG TCLK frequency.2 H) @* a" p" n; x1 m
+ n& R% r: ]+ V" N# ?+ C0 F3 t
-----[Perform the standard path-length test on the JTAG IR and DR]-----------
" D- A: `* i7 F8 H( t# N+ s4 R9 y3 d* I% Z! f! w( e
This path-length test uses blocks of 512 32-bit words.
, n7 w: L0 s8 T( s+ _, |
5 p, _' y, X# ~1 v5 M+ lThe test for the JTAG IR instruction path-length faiLED.( y! L) U. v" m- B
The many-ones then many-zeros tested length was 6 bits.5 H. s U S4 t9 v. A$ q; f
The many-zeros then many-ones tested length was -16352 bits.1 O8 {: w" s8 q {: y% |- ~
! ^9 x6 x2 i8 J( d& qThe test for the JTAG DR bypass path-length failed.
/ u: P- U1 ~: ~5 IThe many-ones then many-zeros tested length was 8 bits.
3 U0 L0 K! }" b) k& gThe many-zeros then many-ones tested length was -16352 bits.
, I5 {3 T0 H+ `1 j" y5 w8 n. j% N# Z: h1 {$ K/ B* L
-----[Perform the Integrity scan-test on the JTAG IR]------------------------
4 H# [7 ?2 A0 g" j3 ?% d- o
+ l/ Z6 C* F, z, M. j9 RThis test will use blocks of 512 32-bit words.' \$ m& s X! u# I& n/ _; q6 Y; k
This test will be applied just once.$ W) b7 h7 _# U$ a* I
0 y0 z3 Z" N; |6 s2 [# A" vDo a test using 0xFFFFFFFF.
) q" o, L! x6 _/ c: }% }Scan tests: 1, skipped: 0, failed: 0/ I( M! D9 `1 Q
Do a test using 0x00000000.
) N" ^, `/ r9 |% c& @7 ]( K1 ^& mTest 2 Word 0: scanned out 0x00000000 and scanned in 0x000000FF./ T/ }& D, ]6 }$ p
Scan tests: 2, skipped: 0, failed: 13 c7 M2 t! y: R) }' c
Do a test using 0xFE03E0E2./ g$ E1 B+ E& s# c4 O
Test 3 Word 0: scanned out 0xFE03E0E2 and scanned in 0xFC1FE7FF.
: U7 O! X: `5 i( U" O0 [% G, gTest 3 Word 1: scanned out 0xFE03E0E2 and scanned in 0xFC1FC7FF.
7 _+ M% r1 x1 l# yTest 3 Word 2: scanned out 0xFE03E0E2 and scanned in 0xFC1FE7FF.
- w n/ I% \. R2 LTest 3 Word 3: scanned out 0xFE03E0E2 and scanned in 0xFC1FE7EF.7 C! m1 M; @* w% a
Test 3 Word 4: scanned out 0xFE03E0E2 and scanned in 0xFC1FC7FF.6 X0 t4 I" Q5 `* c' Q& E
Test 3 Word 5: scanned out 0xFE03E0E2 and scanned in 0xFC1FC3FF.
. ~7 i7 H$ ^- hTest 3 Word 6: scanned out 0xFE03E0E2 and scanned in 0xFC0FE7FF./ A- m' g& U8 Z5 z
The details of the first 8 errors have been provided.
2 {. m" a* b' y8 C6 yThe utility will now report only the count of failed tests.& r+ P) ~: M% B
Scan tests: 3, skipped: 0, failed: 2
1 R$ n2 @2 u2 rDo a test using 0x01FC1F1D.
; ` v: k$ U. HScan tests: 4, skipped: 0, failed: 3
0 v. {; n0 a5 J$ E gDo a test using 0x5533CCAA.. a0 K* V9 p6 o7 P" B3 z! C
Scan tests: 5, skipped: 0, failed: 4
4 X2 C9 N0 [+ U1 v5 X |Do a test using 0xAACC3355.
0 ]& q4 Z0 i: R7 O) E1 u! oScan tests: 6, skipped: 0, failed: 5
# M( m$ P3 l# c- }/ r! [, E# E% N/ uSome of the values were corrupted - 66.7 percent.; V: n5 l' Y5 Q; P, u8 |
: t( Z: f6 M3 s: p M. \The JTAG IR Integrity scan-test has failed.& ~' g3 a, L5 Y8 d+ t
! v* f( H) b; a6 w* @: ^
-----[Perform the Integrity scan-test on the JTAG DR]------------------------$ M5 d* k% k' t1 ~/ \8 a8 d
2 u7 I! I3 c, b5 J: qThis test will use blocks of 512 32-bit words.7 k9 H3 ^6 |, z
! ?$ A. |" m/ w$ u0 ^7 A/ d. @0 {$ i. F; T2 F/ t1 L: m6 h: o
Do a test using 0xFFFFFFFF.7 t* b5 m ^0 v
% v; X8 s4 w5 `$ ODo a test using 0x00000000.
6 Y- J5 w' M! _/ {Test 2 Word 0: scanned out 0x00000000 and scanned in 0x0000007F.
3 X# o! J6 ]" O6 X% j' Z$ X* WScan tests: 2, skipped: 0, failed: 1
- k& ]. ^7 [: w1 _. \Do a test using 0xFE03E0E2.
" q, Z- h" x# a4 x3 z( xTest 3 Word 0: scanned out 0xFE03E0E2 and scanned in 0xFC1FE7FF.
3 m2 I) f) z6 p5 i6 TTest 3 Word 1: scanned out 0xFE03E0E2 and scanned in 0xFC3FE7FF.; _: n6 [2 B; N
Test 3 Word 2: scanned out 0xFE03E0E2 and scanned in 0xFC0FE7FF.
2 P! @7 C- c" K% i/ V+ A0 CTest 3 Word 3: scanned out 0xFE03E0E2 and scanned in 0xFC3FE7FF.
4 r, i: s& y6 l7 Y; ?Test 3 Word 4: scanned out 0xFE03E0E2 and scanned in 0xFC1FC7FF.
1 W% _) W/ c3 T& l0 T. pTest 3 Word 5: scanned out 0xFE03E0E2 and scanned in 0xFE1FE7FF., n9 ^7 D4 f7 c9 R4 e3 D" Z
Test 3 Word 6: scanned out 0xFE03E0E2 and scanned in 0xFC1FE7FF.
2 T3 s% n+ K0 ~0 h7 l' }. O! eThe details of the first 8 errors have been provided.
& y, i) i, A1 i1 |& SThe utility will now report only the count of failed tests.
" U8 l2 n. V+ E$ v! Q/ @ ]Scan tests: 3, skipped: 0, failed: 2
: Q$ y8 Y. S8 `9 Q; R3 r* HDo a test using 0x01FC1F1D.4 }* E& N5 P) K6 G7 P8 l
0 J& b; R- V& HDo a test using 0x5533CCAA.
; U; ~% }- j% g; T/ I4 qScan tests: 5, skipped: 0, failed: 4
" }" C: v! f7 z% J: Q8 J6 |4 mDo a test using 0xAACC3355.
d' Z% t$ ^8 A% G ?) P% ~Scan tests: 6, skipped: 0, failed: 5# r9 [3 \2 o7 v1 h2 d% ]5 b
' b) z7 \5 K _$ y
: w! `& }6 k0 f, ]3 d8 X8 o& u/ AThe JTAG DR Integrity scan-test has failed.
. t* `6 J; } B2 c5 |- X5 U& i" \+ ]- ?) o' k
