查看: 249|回复: 3
DSP28335数据类型
发表于 2021-12-6 11:15 | 显示全部楼层 |阅读模式
       最近在用DSP28335时,发现数据类型与ARM体系的数据类型有些差异,做了以下测试,来确定DSP28335上数据类型的大小。" O3 a' A- q' J; O9 A
% A% N7 T2 |  L5 f
( U2 `& l6 M( c5 h) i, @" H
      28335单位中长度为是16bit.
1 X; P: L5 s* A  F" T: y  e7 p% k5 {- W6 |8 n9 n0 ~  \) f
1 ~, x9 ^4 H" ^  {; Z* I& J
  count = sizeof(char);
/ W9 r4 L( \. n; H) v  count = sizeof(int);* T3 X7 b; [0 ?! w
  count =  sizeof(double);
6 v; L2 ]& ]; n* X% J  count =  (sizeof(long)
0 U0 y8 T) J0 D7 u; O. S0 h
. m6 i6 j) O4 Y% Q# `% P, e" J
  L7 \& q4 u7 g$ O; [* _! |5 P
   count =  (sizeof(short), v. |# B# _6 Y  V4 B9 `
/ y+ m9 P9 F: {! T: g
: j: K( H5 W1 T& O
count =  (sizeof(float);" B" Z. m7 l2 L" U3 o$ @
通过查看寄存器发现:; N% p' j9 T7 b+ o; q4 F
# Z# S2 I" j5 k8 z5 y' C% ^/ T/ [
0 @. a  k9 I, H
char : 1  (16bit)
2 Y. O% l& a# I3 h9 Z5 {+ X. D! N+ Vint     : 1  (16bit)
, r1 y& c- z" Q% N) b0 k; idouble: 2  (32bit)& K' M+ M$ q8 g
long: 2  (32bit)
+ p9 K( V0 a, N1 yshort: 1  (16bit)( J+ `  K3 X& b; V3 [
float: 2  (32bit)( W! r! A; L3 Z3 w# P; u
long long: 4  (64bit)
, f, ^! J9 h# Y3 X$ u5 x. ]. o7 m: X9 n9 t; U+ Q1 h
* }8 z" r/ `' J) e2 C
----------------------------------------------------------------------------------------------8 Y& X( ~$ i% I! _  I1 b
6 [/ q" ]7 {9 D8 T& `1 R
$ g( U# x) [4 e- u4 v6 Q
struct SDATA_BIT{
1 U3 z0 z$ V* Q3 r! ~! B' d3 } unsigned int  D1     : 16;/ D/ J, s0 ^) J8 q4 z" T
# w% o* t% {: b& H, l
$ K# F) a9 I) g, o- Z
unsigned int  D2      : 16; ; G. Z6 Q1 q/ u- R& k: P
5 g$ w( @( Y% ^
$ T; a# z+ I5 B8 z9 n2 {
unsigned int  D3      : 4 ; % K  ?6 Z+ [, a5 B# B3 b
2 F' ]+ ?2 R1 q0 `
/ V- U3 q9 U+ A3 Z+ S
unsigned int  D4      : 1 ;  t4 W' J# A, i' _+ h
' X/ Y) z5 q1 U$ R# R+ D
3 v! _2 S  A  s5 n7 h: k unsigned int  D5      : 1 ;   G: f. A; T% f) j) f0 [
6 ?) z" a' V. G9 ~' L2 v
! p3 d) H' h9 g; J/ a9 g4 { unsigned int  D6      : 1 ;
1 J# O; t; C' v! N) a8 `0 s
" J* e$ O( G/ t2 h0 h& d) x
) ~. @0 u$ A& A% I7 ~3 Z
unsigned int  D7     : 1 ;
# ^6 T! v# C7 {8 Z  F! g2 ^1 X# p9 `9 w* n5 C( w
6 v8 b- l, @7 \3 W0 M, F; O};
7 z- u6 E' g4 O( m0 J% k( F% l& P3 z& J' n& e
8 }, l' [" V0 C! xsizeof(struct SDATA_BIT  sBIT) = 3; //7 D* L8 F3 S4 X: h  Z& h0 n
& p: W, @* ~0 Y; U% J2 ^
3 ?7 V' r  M  G& r
由于DSP28335上的数据类型与ARM的不同,因此在做通信协议时,尤其是用到联合体、数组、结构体来存放数据时,要注意!!!. P$ U2 |6 f+ n1 a$ N
5 Z) A% H' ~$ J' O/ ?, ^. P
3 B' x5 k4 y+ S9 [7 {. O, Z$ p+ l
发表于 2021-12-6 13:07 | 显示全部楼层
28335单位中长度为是16bit
发表于 2021-12-6 13:08 | 显示全部楼层
发表于 2021-12-6 13:09 | 显示全部楼层
用到结构体时要区分
GMT+8, 2025-10-13 03:59 , Processed in 0.125000 second(s), 24 queries , Gzip On.
