建议存缓存,然后统一判断, 如果非要收一个判断一个的话, 接收的时候啥事都干不了了。
b$ F: h6 a- y0 I+ l2 p, Q; F! j& U1 u
# O4 b( C. p" j3 w5 F接收时判断如下:& Q5 X3 @0 C$ q
. N* i7 s( Q1 F5 O+ z0 X# Jvoid UARTInterrupt(void) interrupt 42 G$ ]2 ^. N& W% V9 I) E( G* K
{: F$ `( w$ {+ O( \0 b# L
u8 i;9 g, T7 X; N! P
if(RI)
+ j4 F6 s1 \3 {* \5 c" E { ( ^7 n( T3 `* ?1 [
RI=0; 1 D" h$ h, v/ N' V
Receive=SBUF; - ^! }1 M; U0 V" Z5 y5 Y
if(Receive=='1') //如果第一个字节吻合'1'
4 h6 b, [$ f4 x { ' O# L, A0 g( s9 _% V
i = 255;
; C, h! L6 W' W9 `# J6 p while((--i > 0) && (!RI));% ?! L) ^7 J3 J; e+ a
if(RI)
# }- m3 x* ]# W, s2 G, T {# q" T' w+ u( q v! u
RI=0; / c1 f b8 ?7 A) [2 I
Receive=SBUF;
y+ Y8 }) z9 G$ ^9 _# b8 ]3 R if(Receive=='2') //如果第二个字节吻合'2'
/ Y& ~. f4 i0 }; u( m" ^8 E$ S {
2 ~% S' u! ]" X/ q: U i = 255;
1 `+ r( _ p0 V( v1 O while((--i > 0) && (!RI));
' W" ]9 o) I) P0 l3 S if(RI)% h, V8 u2 g1 w. R+ E9 Q
7 `0 a+ V5 G2 G' u* z( m( D. R, x RI=0; . b6 A- @* T- R* J! V$ i! E8 z% |
Receive=SBUF; 4 L: |2 V# f$ L$ {/ S0 r
if(Receive=='3') //如果第三个字节吻合'3'
; a3 }" d' V$ t, a) [( n {
8 t3 o j, m. Y i = 255;
" N( b' d5 Q c1 A while((--i > 0) && (!RI)); c. {9 z, r1 l# m+ m) s5 z; }( p# r
if(RI)# K @2 D' Q& q7 s2 }
{+ Y3 q; v: X" F3 ?( e
RI=0;
1 {; E" A- {, s ?) e, p; f Receive=SBUF; 0 X7 ^! n" n# @$ N: h# e7 l
if(Receive=='4') //如果第四个字节吻合'4'* U- }5 U [- @( M' D; j0 }
{0 R8 u' I& n) w/ C1 I/ {
i = 255;& k, z4 h2 n0 Q+ }8 ?
" z7 K- F2 A7 j' V if(RI)
+ r: c, |0 _2 y2 Q3 E% d9 d {0 N2 s u; A& n2 I
RI=0; : E: q7 J: W+ `2 d. y9 @# g5 v+ z: Z
Receive=SBUF; & a) I! d# v& B$ A# S m
if(Receive=='5') //如果第五个字节吻合'5'
3 e) u, F5 v% ]$ X N4 [5 v {
! S% v* P* S# q! } i = 255;& x: c: x6 V6 C" l
while((--i > 0) && (!RI));8 _+ E# }( [, k; Z' G# k9 a3 F$ W
if(RI)
/ P& i7 P3 ^ \$ W: K3 _ {+ y5 _+ V) O$ d) v' r; A+ z
RI=0; 7 S. u; L5 B2 R, `% d# @1 ~: e
My_Buf=SBUF; //保存第六个字节到缓存并返回9 `% W: F6 W/ L! r
Recive_Ok = 1;
9 p% Q8 b5 F1 `5 `7 {* n( N3 r }
/ v$ z! p; {; c7 P }% D, _. r! d7 _7 @
}3 z8 s' i" n$ N: U; ^
0 n* Q. k+ `; A h }
: E7 r* J# E# J: e" X5 e' l4 H }
# ?$ c' {8 X8 h1 D" B& |0 R }1 a" P. |1 J) F/ M
}3 `1 [) L. N. `, T& j3 L
# N. R+ z" p+ e7 j' b6 P; p' d' x }
/ R6 Q. X+ r# y8 u; s4 K6 F }
! V. A+ M, p9 E. H: ~ else
6 G& w/ }) I( _& M7 H. U, V TI = 0;
7 h; n: h) v4 K7 c" V- u7 L}
) B. O% o! O& Y
$ Z0 y) j9 E! X1 ? [. F) i( {" `4 @" R3 ^# n$ _7 `5 B
再你代码的基础上写的,i用来判断超时, i 的值取决于你的波特率,波特率越高i可以越小,反之i 可能需要增大。, ]. a1 I# I- W: P4 h# d
8 o* n: z& X" M6 ~. Y
最后,这种方法非常不建议。可能的话,还是推荐用缓冲池方式。2 P5 G6 T; Z# s7 e) d2 h/ v2 v
回复 |
