查看: 281|回复: 3
请教C语言return用法
发表于 2021-11-19 09:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
void main()
9 p( M# }5 z: }{+ B7 z( R% n  j4 u# F
while(1)! \: j  M6 z% N  m! }8 O" b
" C# P, f6 D5 iif(clok_HOT)
9 p  S: z4 P; T6 u                {
$ J7 L7 b8 D# m" H. F                        if(clok_HOT_tmie)
- c9 g+ W' F, d# i# D( V  M                                {
8 Y2 e( F* o% Y: P- t( g7 a1 z                                        clok_HOT_tmie=~clok_HOT_tmie;+ A( [0 H/ n6 }, H4 g6 d! V/ _
                                        clok_HOT_tmie_Counter++;2 X( @" e0 h! r5 b( A4 C
* j( b# D% l. l) p3 N                                if(clok_HOT_tmie_Counter>=10000)2 k' ?+ R9 s, a& ]" H* H
6 x4 h0 `: k* V* S                                                clok_HOT_tmie_Counter=0;
" L) m4 _: D) `1 ~6 J0 T, [                                                cold_HOT_DADT11=CMPCR1^0x01;  J! S* J/ \8 s& m& |# C0 V! `
                                                cold_HOT_DADT11 &= 0x01;                                //ζè±è½Ï£¬′yDT¸Ä
& p1 D! l3 t$ @5 o; D                                                if(cold_HOT_DADT11&&clok_HOT_ion&&!clok_mode)   //à䱨¾ˉ$ Q, c% z& k0 l
' B8 D! C* o% x/ @        clok_lock=0;! o& P' A, q) U# W" x4 h8 y, ?
        clok_OUT=0;7 e) H: p# [. F! l; F
        clok_HOT_ion=~clok_HOT_ion;8 t6 Q% e) d. o6 |
        send_string(cold_HOT,12);; I  G* F2 d4 p+ l
        send_string(Buzzert2,7);
' c. L9 F/ h& u0 O6 f% P& j4 e        return;
9 \- g9 ?! O% \                                                }+ N  {+ l0 S2 C; R1 Z, ?* P
                                                else if(!clok_HOT_ion&&!clok_mode)
$ e) F( ?8 d( Q                                                {! j1 }+ j  ?& e, [
                                                        clok_lock=1;
: E# V, ~9 a3 }" d& r' C) m- S                                                        clok_OUT=1;
0 `. T: q/ g* ~0 z/ L( ?$ ?                                                        clok_HOT_ion=~clok_HOT_ion;  Y7 ^" r# ~0 z
                                                        send_string(cold_cold,12);
4 L, ~# _. e8 D                                                        return;
0 x6 Z3 d; J( o7 ?, j( c1 Y                                                }
  a& q  P. }8 L' j, ]                                                if(cold_HOT_DADT11&&clok_HOT_ion&&clok_mode)        //èèí£Ö1
" H1 x3 U9 x6 h                                                {
9 H" o* n7 D' l        clok_lock=0;. i. E! Y9 ~/ Y5 K1 X
        clok_OUT=0;
* Y2 S2 H$ i$ ]* F1 P5 d  g        clok_HOT_ion=~clok_HOT_ion;  G# L. i# B( ]! o
        return;
3 ~8 n4 M& H1 t& d6 j9 v                                                }% `& v6 j4 R, O6 G2 z
                                                else if(!clok_HOT_ion&&clok_mode), g  f: Y: T7 J+ @
                                                {( N" v9 [0 e. [9 T  G- R
                                                        clok_lock=1;7 r3 i3 y; N0 W4 _! x4 l. I
                                                        clok_OUT=1;( Y5 Y9 i* U$ |* H9 {5 C" }
                                                        clok_HOT_ion=~clok_HOT_ion;$ T$ F! Z+ M) S$ i( \
                                                        return;
/ G' @/ \3 o8 z2 I) K+ z) C4 \                                                }
/ a3 G7 \4 y, e% [                                        }
  ~1 Q' h: A+ k: Q                                }& D+ R1 v/ R1 {/ r/ r# C) q9 o
2 L3 b* m7 c# F8 g# P1 R$ k  S" g
/ n# L) U, V/ ^$ s* A# }          N9 p0 O7 p1 j. J" q" |
}  K" V% k' s& g
}5 i$ W1 K5 f3 @- A& L8 e
0 e3 P$ n! G$ s- v- |
我这部分代码没有建函数,return;返回到while(1)?
: C& ?4 x/ t: ]) [. @" M! a( t7 l下面这个能直接退出中断?6 G# L" Q. K& C) ]) O
void TM0_Isr() interrupt 1                                        //¶¨ê±Æ÷0ÖD¶Ï( V! \: b; h+ G- E6 E* X
{. r2 `+ K$ C' l3 [) X- |; O; o( U
               4 C7 B) o1 I  F2 S' H
                if(SK_lock)        // 2ùμ¶ÆμÂê
* }/ {/ [5 M* F6 {6 a0 V                {) n( g, E+ _. R( b4 e7 w6 {1 _
                        P0^=0x03;
' V! V: x- R( p! H                        return;
5 H; @* \, N* [9 ?9 @. U! y                }2 ], t$ I  N# L# }
                        if (clok_lock)        //àä
4 m1 I) l5 _; K! t                        {
4 U+ T) o8 W3 m1 v( l                                clok_satar=~clok_satar;
: q: E0 X" m/ e$ F                        }& f' d: Q7 ~& a, `& v+ E
                        if(clok_HOT)' O7 l2 T! E6 c2 R: l) g; n! s
                        {        % b0 }5 O+ v7 \
/ N2 \( I  s( v2 z& J& R) K! F5 G: G: B                        }
" Z  d' w+ c7 L& Z. P+ ~; x                                                if(ul_1_lock|ul_2_lock)                                                //3¬éù
+ J" q# N% n0 l( g/ c6 r' I                                                {* V: {/ h3 A' X, Z
                                                        ul_satar=~ul_satar;
3 r4 G4 Y4 |9 @4 y$ n3 U: f                                                        return;: t; P8 _# a0 N8 k! Z, s% r
                                                }9 l0 A! u$ q( ^& o+ A- h) J/ }
                                                        if(ion_1_lock)        //΢μç1+ r+ R% I4 J# K
                                                        {' D. z6 m3 G8 S( C& n- A6 T6 ^6 L
        ion1_satar=~ion1_satar;$ M" [7 I$ C9 C) U) P5 U  y
        return;
$ d1 C* Q# [; }* ]& X4 m                                                        }! _" e, T1 _# Y% E  X0 ]. D9 n
        if(ion_2_lock)                                                        //΢μç21 i& Q+ N: W! F$ \
) Y+ G  R& b" E. `        ion2_satar=~ion2_satar;0 O! n+ j& g0 N$ B! i, a: C, [
        return;
- O! Z: Z% x2 g0 p/ b5 o, }+ m        }, _' u% L* D7 G6 j+ N
}( D8 P4 z+ n4 f9 `) P; b& ^2 ~
发表于 2021-11-19 10:36 | 只看该作者
return;返回到while(1)?
' N; i0 r: P- A9 p6 {9 w, ?return 是退出整个函数。break 是退出循环。
发表于 2021-11-19 10:50 | 只看该作者
& c9 d" I  `# c
# r* F7 D! U* e在主函数中使用了return,就是让程序中“飞”起来了,,,,,,,
发表于 2021-11-21 07:05 | 只看该作者
在 main 函数中不能用 return4 M3 o2 x( T# O
' O4 |$ Y* e  M- a2 U退出while 用 break,
: I, t/ ]' S8 n或者考虑 用 continue, 这是当前循环终止,进入下一轮循环(没有退出while循环)
GMT+8, 2025-10-9 17:47 , Processed in 0.140625 second(s), 24 queries , Gzip On.
