查看: 1272|回复: 1
Qusrtus2 11.0 时序仿真第1次出现错误
发表于 2011-7-27 21:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在QUARYUS2 ->TOOL->RUN EDA SIMULATION TOOL 后 运行ModelSim 6.5出现如下报错。希望高手指教。Q385157936
6 ^' P; g+ ]* y, d( Q7 {5 a3 EFor example, ModelSim may display the following error message:
' E+ _7 T1 m! x; j( d" d* v8 V* j# ** Error: (vsim-19) Failed to access library 'work' at "work".6 S5 R3 q' F# t8 z
这个问题在网上收了下, 按照官网的说法如下:1 X6 O6 q% M6 K) N; V* I* `6 P$ c
To find the cause of and resolution to this error, use the following verror command at the ModelSim command prompt:verror 19;ModelSim returns the following message:# common Message # 19:
( }# v. E: h; p: a& J0 Q# The specified library could not be accessed at the specified location.
% M3 U9 ^  `, H2 d9 i5 H# Verify that the directory exists, that it contains the ModelSim library,( s. n$ o6 ]+ ]2 g$ l
# and that you have the correct permissions for accessing it. % O3 Y, w8 ^) {3 k) o3 |# E" i
# Also make sure that the _info file in the library has the correct2 K- l; g9 A; g: P8 q4 b
# access permissions.
- S( d$ x  v) R. j$ l; f# This message might be followed by another message that gives more information ) x* a7 |2 d1 f; B$ p+ s
# about the problem.( h% j% w3 T' E5 Z/ ~& i
# / R. |$ G* h  N& r
# The vlib command creates ModelSim libraries. The vmap command maps
+ k& m6 }) g4 D5 O4 d# logical library names to physical library locations. Use the vmap
; V3 [) u+ s1 u' m$ G2 a# command without arguments to find out how all of your libraries are
% B& o, U. X/ I. l* [) L. S# mapped.3 A4 n( U' y6 Z! T
# 7 k6 ^" v, d& M7 [- W5 ~, `% A
# One way this problem can occur is if the mapping for the library in4 H3 `" m6 w7 H0 K% y9 r) Y
# your modelsim.ini file contains an environment variable that is not set
6 ]; x, T6 q& }9 R, R# in your environment.还是不懂如何解决。
; {* _3 S' p7 H# T) z; Z' ~
 楼主| 发表于 2011-7-27 23:02 | 只看该作者
已经解决问题,大家注意,安装QUARTUS10.0版本后,路径千万不要带空格和中文!避免出现一些意外。
GMT+8, 2025-10-31 18:30 , Processed in 0.125000 second(s), 24 queries , Gzip On.
