查看: 1445|回复: 1
[HyperLynx] 编辑.IBS时报错
发表于 2011-7-22 11:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
编辑.IBS时报错:at line 1 in file  : File MAX3738ETG.IBS does not have .ibs, .asc, .tch, .mmf, .agn, or .ebd extension.3 t# _, A$ M/ p" \
模型里的语句:[IBIS Ver]       3.22 T- R1 Z- }* k# ?& E- T
                         [File Name]      max3738etg.ibs
7 W- o' B- [2 [. \/ E: S                          [File Rev]       0.1
. X# f6 q, m; X                         [Date]           February 13, 2006; I0 c' B% P) Y( C2 B& z& o
                          [Source]         Data Sheet
: _8 G2 [$ s6 N                           [Notes]          Laser Driver output I/O models are not provided due to lack. l) u& G2 Y& K- U( x9 N- m, g
                                               of optoelectronic models and limitations with IBIS for
* \# K$ U) Q/ V# h) d                                               deterministic jitter.
6 Q. f0 J: V1 |' ~3 `                                                The user must supply the correct differential
0 {8 Y% f0 S/ m                                                 input termination.
! `2 T1 q  X0 d0 L2 _) c( K  j哪位大侠帮忙看看,谢了先  t+ c4 w' U% S) s
    郁闷
    2025-4-28 15:02
  • 签到天数: 13 天
    [LV.3]偶尔看看II
    发表于 2011-7-22 14:01 | 只看该作者
    随便找个大厂的ibis模型看一下,看看他们的v3.2版本的语法结构,然后看看会不会报错,不会的话,在和你写的对比一下,是否有区别。
    GMT+8, 2025-7-26 16:40 , Processed in 0.093750 second(s), 24 queries , Gzip On.
