查看: 1407|回复: 3
[Ansys仿真] ITRL&DE-EMBEDDING SOFTWARE两种去嵌软件
发表于 2021-10-25 14:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
8 k4 q3 d' x5 p- |8 O2 r' ]
' D6 E+ B6 {* n- P. b2 F国外软件,有兴趣可以查看附件,附件是两个软件的介绍AICC DE-EMBEDDING UTILITY
In addition to iTRL, Amphenol is providing de-embedding software that uses 2x-thru and impedance corrected 2x-thru algorithms. The 2x-thru algorithm is fast, robust, and provides the same accuracy as TRL with only one input standard. Like iTRL, the impedance corrected 2x-thru algorithm corrects for differences between the test fixture and the 2x-thru to ensure causal de-embedded S-parameters. However, this utility only needs a 2x-thru instead of three line measurements. The software can de-embed single-ended and differential test fixtures, and also compares test fixture 2x-thru S-parameters to the IEEE P370 Fixture Electrical Requirements.
; [0 T+ m# c6 S4 G0 ]
4 g! D) Z0 R7 ]7 \3 E. n. j, G3 YITRL DE-EMBEDDING SOFTWARE
As a public service to the global signal integrity community, Amphenol ICC is making available their improved TRL (iTRL) de-embedding software. The iTRL method overcomes many of the limitations of standard TRL. With standard TRL, the accuracy of the de-embedded results depends on the equivalence between the calibration trace used for de-embedding and the actual traces on the test boards. Variations in impedance between the traces and launches of the calibration board and those of the test boards, can result in non-causalities in the de-embedded model. By making much more accurate models of the test board traces, the iTRL method overcomes the problems with TRL and yields cleanly de-embedded models of DUTs such as a connector with its PCB footprints.
/ Q1 `* V1 v3 s3 Q2 h( V
Matlab Deembedding软件介绍.pdf
856.57 KB, 下载次数: 22, 下载积分: 威望 -5
iTRL_Manual_v1.pdf
5.28 MB, 下载次数: 13, 下载积分: 威望 -5
发表于 2021-10-25 17:30 | 只看该作者
集成的3D设计及分析环境使PCB设计团队能够在Sigrity工具中实现PCB和IC封装高速互连的优化,然后在Allegro PCB、Allegro Package Designer或Allegro SiP Layout中自动执行已优化的PCB和IC封装互连,无需进行重新绘制。
发表于 2022-3-4 13:02 | 只看该作者
感謝大大無私分享
发表于 2023-3-10 11:02 | 只看该作者
是否有源码 可分享呢
GMT+8, 2025-10-29 06:44 , Processed in 0.171875 second(s), 27 queries , Gzip On.
