TA的每日心情 | 开心 2023-2-9 15:41 |
签到天数: 89 天 [LV.6]常住居民II
Version 21.8.1 (Update 8)! j/ g0 l, ]/ N$ I* u( t
Build: 53 Date: 21 October 2021! F- I2 R5 n% k0 d U, j9 Y
$ @6 b7 r& u7 G* P) Q1 X0 \0 n4 Q
Schematic$ }6 L9 |+ Z( A# ^" h7 J' O i
41224 The Port Actions > Toggle Selected Ports IO Type command did not function correctly.; F& \2 n, B5 b6 x
42660 The page tiling and scaling in the Print Preview dialog was incorrect if the paper size is smaller than the schematic sheet size with the scale set to 1 (BC:15727).
. u! n- J/ E% {* m5 h3 F9 L46253 Some footprints that were generated from the database library could not be found in the Footprint Manager.
9 `$ p( J. p$ h/ }46281 Footprints could not be found for mechanical parts after certain libraries were compiled.
/ W6 |( Y, V: [7 E4 c0 @) D46324 An error occurred when running the Tools > Signal Integrity command for a particular project that had a large model description.
4 W T0 ]- ~! J: E: F9 P* G' b3 q, P46433 Pin designators were far from pad numbers at some custom pin configurations when pins are mapped to multiple pads.: N1 U* ]9 l+ j& w' X I% C$ M
46482 Dark objects were unreadable when viewed in the Snippets panel.
% O/ H* i {$ C46566 Crash occurred when reloading a schematic document modified externally.
% g/ b- t- `* @7 c8 |% p46725 Formulas with scientific notations were not interpreted correctly.2 @0 a, q" P+ f3 k0 _
46726 The 'ABS' and 'ROUND' System Query Arithmetic functions did not function correctly.6 W9 A6 ^7 U) u2 S
47079 The print preview only displayed the active document instead of all schematic documents in the project.2 i, c4 G- a9 }4 o
47092 Some graphical images were stretched in the software and Web Viewer. (BC:17163)
! Q/ ^& D6 F- l0 L9 }# R47111 A list of text copied from Excel was pasted as bitmaps rather than net labels after enabling the 'Paste as Net Labels' option in the Smart Paste dialog. (BC:17212)
* R `$ E) l2 Y3 rPCB( [ ?6 o7 Z3 l) @2 I
44660 The system was not responding while pushing a design through MCAD CoDesigner.
. f+ f6 ]5 c: a% o |45188 An error occurred when saving a PCB to the PCB 4.0 Binary File format. (BC:16203)
- M, [0 P0 g* I# M45432 An extra Board Layer Stack entry was displayed under the Component Layer Pairs group in the View Configuration panel.
& D+ O4 w% {7 L" W) v45583 The cursor was no longer large when 'Large 90' was selected as the Cursor Type on the PCB Editor - General page of the Preferences dialog. (BC:15913)
9 b5 n& p' P, v2 L& x: Y45816 Pullbacks were not shown and an incorrect number of split planes were created on a specific PCB design.
3 ~8 k! A0 s- H, Z: ]/ U% I45945 Vias without a drill pair assigned were not listed in the Hole Size Editor mode of the PCB panel. (BC:16225)
; `6 M e/ g" v; L( l- Y% E* J& Z46178 Selection made with the Enter or spacebar keys caused data from the Properties panel of an object to be deleted.
* R& Z/ _- H( F% C0 ^- y46638 Incorrect un-routed net violations appeared after running the DRC.
, M K# M1 C' }$ F. [8 g46685 A delay in the Properties panel setup results in an invalid multi-line width text box for Interactive Routing.' Y* A- t1 S, X9 R8 ~2 s9 n
46688 Error occurs when the last Placement > Room Definition rule is deleted.
# Y+ o$ P" M; K" T9 R% ^46691 Project Releaser failed for an output job with PCB 3D Print through Folder Structure container. (BC:16725)
t9 a; r, f; P: \& `7 D46754 Layer Drawing Order settings were not saved to preferences files. (BC:13983)
7 {- A# `' V- o! a7 u9 n9 L2 Q46759 After copying a footprint, mechanical layers were not correct.: `: z* t5 {5 w5 |8 }# M
47069 An error occurred when opening the composite drawing output for some PCB documents in an Outjob. (BC:17193)6 F* n9 T" w, F Z G
Draftsman
( _6 Z: O( R( A2 J3 N7 ^45881 The approximation of a board outline that includes an arc of a large radius was rough.1 Q+ a8 ~ U8 w2 h
45907 Some objects are missing in an exported PDF file. (BC:15122)
( V) M+ h. Y3 e' T) U; z46231 Error occurs when a generated PDF tries to open." T0 s8 O' t. ~# c5 [0 ?/ G# o
Platform! Y& Q* t: Y2 a& `4 T( G
46199 The Updates tab of the Extensions & Updates page has been improved to always show the most current version at the top of the list.
* T) y1 }1 ]. D46272 Panels were grouped in fractal mode regardless of the UI.DisableFractalMode advanced setting.( u5 n7 x9 Q5 k; Z
46729 An error message appeared after granting access to a project.9 Y/ ^- B" @0 q. m4 M
Data Management
& { w% m! V/ P' T; V% v) A45269 After modifying more than one footprint in a component, update of components using the same footprints was incorrect.
$ H$ s" L) P. r. Y46383 A error occurred when reverting a revision of a project document through the Storage Manager panel if this document has been renamed.: i( q6 R# A$ T) |! s1 f, V; t+ x
46425 The 'Custom Data Synchronization' overwrites the PartId during synchronization.3 Y3 K* y8 i* {% N( G
46544 When the '+' button to add a comment was clicked, the software never went past "loading comments"./ I1 A; T* ^+ O& }+ ?: v9 s
46764 Added a BOM item to the Projects panel., j6 J# z$ Q" u$ T
47130 The private server license did not release the license when the software was closed. (BC:16547)
, a" e- N& i' c' eImport/Export7 l7 y' _5 J @( f6 ?9 M
44330 Pads and vias were converted into hatches after exporting using the Export to AutoCAD dialog.
, w( F. B" J4 @% V! |9 L47150 Comment export was not possible when connecting to an on-site Workspace.; d9 V5 f3 t/ k
Simulation
5 ]+ b& D8 b% k4 J45937 Added 'Format X Axis' to the Plot menu to allow independent zooming for separate plots./ q* R9 r, p/ a, w5 |! m: {5 ^5 b/ z
45985 Added the ability to set the X-axis expression in the Add Output Expression dialog.
0 C0 g L% u! j7 c/ X46536 The option to zoom plots separately is now provided in the Document Options dialog.
4 ]" m& L$ M! t: ^8 p6 W46720 Added smart pin mapping to the Sim Model dialog. |
