7 W" P$ p0 }9 e0 \& L
(一)" \. ?+ u6 q: v% b) y2 L
+ z: Y \7 C d ~
灰度的线性变换。
a) O8 { ] g/ R3 E* C
6 d" k5 b5 u# V- |' S3 J 改变图像的对比度是对直方图的缩放与平移。改变图像的亮度是平移直方图,反向是将直方图镜像。; c( S7 E+ G3 O8 T
' D* M( v7 W% y- I = imread('coins.png'); % 读入原图像 I = im2double(I); % 转换数据类型为double [M,N] = size(I); % 计算图像面积 figure(1); % 打开新窗口 imshow(I); % 显示原图像 title('原图像'); figure(2); % 打开新窗口 [H,x] = imhist(I, 64); % 计算64个小区间的灰度直方图 stem(x, (H/M/N), '.'); % 显示原图像的直方图 title('原图像'); % 增加对比度 Fa = 2; Fb = -55; O = Fa .* I + Fb/255; figure(3); subplot(2,2,1); imshow(O); title('Fa = 2 Fb = -55 增加对比度'); figure(4); subplot(2,2,1); [H,x] = imhist(O, 64); stem(x, (H/M/N), '.'); title('Fa = 2 Fb = -55 增加对比度'); % 减小对比度 Fa = 0.5; Fb = -55; O = Fa .* I + Fb/255; figure(3); subplot(2,2,2); imshow(O); title('Fa = 0.5 Fb = -55 减小对比度'); figure(4); subplot(2,2,2); [H,x] = imhist(O, 64); stem(x, (H/M/N), '.'); title('Fa = 0.5 Fb = -55 减小对比度'); % 线性增加亮度 Fa = 1; Fb = 55; O = Fa .* I + Fb/255; figure(3); subplot(2,2,3); imshow(O); title('Fa = 1 Fb = 55 线性平移增加亮度'); figure(4); subplot(2,2,3); [H,x] = imhist(O, 64); stem(x, (H/M/N), '.'); title('Fa = 1 Fb = 55 线性平移增加亮度'); % 反相显示 Fa = -1; Fb = 255; O = Fa .* I + Fb/255; figure(3); subplot(2,2,4); imshow(O); title('Fa = -1 Fb = 255 反相显示'); figure(4); subplot(2,2,4); [H,x] = imhist(O, 64); stem(x, (H/M/N), '.'); title('Fa = -1 Fb = 255 反相显示');
, {" B' e, L3 e8 k9 N# K
. O b" C9 V0 C' b8 Y* J
) O$ t5 e3 c2 z# o8 l$ T! k, m, x2 ^5 [3 _
/ d& H, x) d! `6 b! w$ l2 g
(二)
4 _- G) f5 p! B' c% y6 a4 ~ ?; o1 w( E) N, h2 _; J: v- X
伽马变换/指数变换/幂次变换/灰度非线性变换1 c# P0 p( _4 U+ I+ N7 m% I
( Y* u# X: D+ X7 { 不仅改变图像的对比度,还能够增强细节。
1 y& u1 p# m" q1 O2 {- `% Y5 L( X/ v& y1 j3 }
- I = imread('pout.tif'); %读入原图像 % Gamma取0.75 subplot(1,3,1); imshow(imadjust(I, [ ], [ ], 0.75)); title('Gamma 0.75'); % Gamma取1 subplot(1,3,2); imshow(imadjust(I, [ ], [ ], 1)); title('Gamma 1'); % Gamma取1.5 subplot(1,3,3); imshow(imadjust(I, [ ], [ ], 1.5)); title('Gamma 1.5'); figure; % Gamma取0.75 subplot(1,3,1); imhist(imadjust(I, [ ], [ ], 0.75)); title('Gamma 0.75'); % Gamma取1 subplot(1,3,2); imhist(imadjust(I, [ ], [ ], 1)); title('Gamma 1'); % Gamma取1.5 subplot(1,3,3); imhist(imadjust(I, [ ], [ ], 1.5)); title('Gamma 1.5');# v. h! _' k6 c& R2 U
8 ` N* |1 I4 R, K2 J. Q. k
4 n" s' g! l' b) `& v
) H" [8 F9 Z! m8 c+ i, m
0 D0 ?3 G! t: c, n2 W (三)4 c: q, g- b4 J' ~% J
- t1 g0 F& t% d+ j7 J
阈值灰度变换
' ^7 [1 A3 b/ v, v7 Q. ?$ F/ }% h3 ?
阈值化,二值化,从复杂的背景中提取感兴趣的部分。
+ m9 D1 u$ d6 O: M8 }: I. B6 j
' u( H% A( f7 f1 A. q$ J2 x- Q5 J6 l) ]% X. s8 e# e7 X
(四)
1 w5 ^* f- ?) V: P e9 q8 Q& Q1 s; o* v0 |8 \
分段线性变换
( i7 m$ J( E% e- m2 X$ m8 R- E2 l" \
, g6 [ N" ]. a: H) L3 z- function out = imgrayscaling(varargin) % IMGRAYSCALING 执行灰度拉伸功能 % 语法: % out = imgrayscaling(I, [x1,x2], [y1,y2]); % out = imgrayscaling(X, map, [x1,x2], [y1,y2]); % out = imgrayscaling(RGB, [x1,x2], [y1,y2]); % 这个函数提供灰度拉伸功能,输入图像应当是灰度图像,但如果提供的不是灰度 % 图像的话,函数会自动将图像转化为灰度形式。x1,x2,y1,y2应当使用双精度 % 类型存储,图像矩阵可以使用任何MATLAB支持的类型存储。 [A, map, x1 , x2, y1, y2] = parse_inputs(varargin{:}); % 计算输入图像A中数据类型对应的取值范围 range = getrangefromclass(A); range = range(2); % 如果输入图像不是灰度图,则需要执行转换 if ndims(A)==3,% A矩阵为3维,RGB图像 A = rgb2gray(A); elseif ~isempty(map),% MAP变量为非空,索引图像 A = ind2gray(A,map); end % 对灰度图像则不需要转换 % 读取原始图像的大小并初始化输出图像 [M,N] = size(A); I = im2double(A); % 将输入图像转换为双精度类型 out = zeros(M,N); % 主体部分,双级嵌套循环和选择结构 for i=1:M for j=1:N if I(i,j)<x1 out(i,j) = y1 * I(i,j) / x1; elseif I(i,j)>x2 out(i,j) = (I(i,j)-x2)*(range-y2)/(range-x2) + y2; else out(i,j) = (I(i,j)-x1)*(y2-y1)/(x2-x1) + y1; end end end % 将输出图像的格式转化为与输入图像相同 if isa(A, 'uint8') % uint8 out = im2uint8(out); elseif isa(A, 'uint16') out = im2uint16(out); % 其它情况,输出双精度类型的图像 end % 输出: if nargout==0 % 如果没有提供参数接受返回值 imshow(out); return; end %----------------------------------------------------------------------------- function [A, map, x1, x2, y1, y2] = parse_inputs(varargin); % 这就是用来分析输入参数个数和有效性的函数parse_inputs % A 输入图像,RGB图 (3D), 灰度图 (2D), 或者索引图 (X) % map 索引图调色板 (:,3) % [x1,x2] 参数组 1,曲线中两个转折点的横坐标 % [y1,y2] 参数组 2,曲线中两个转折点的纵坐标 % 首先建立一个空的map变量,以免后面调用isempty(map)时出错 map = []; % IPTCHECKNARGIN(LOW,HIGH,NUM_INPUTS,FUNC_NAME) 检查输入参数的个数是否 % 符合要求,即NUM_INPUTS中包含的输入变量个数是否在LOW和HIGH所指定的范围 % 内。如果不在范围内,则此函数给出一个格式化的错误信息。 iptchecknargin(3,4,nargin,mfilename); % IPTCHECKINPUT(A,CLASSES,ATTRIBUTES,FUNC_NAME,VAR_NAME, ARG_POS) 检查给定 % 矩阵A中的元素是否属于给定的类型列表。如果存在元素不属于给定的类型,则给出 % 一个格式化的错误信息。 iptcheckinput(varargin{1},... {'uint8','uint16','int16','double'}, ... {'real', 'nonsparse'},mfilename,'I, X or RGB',1); switch nargin case 3 % 可能是imgrayscaling(I, [x1,x2], [y1,y2]) 或 imgrayscaling(RGB, [x1,x2], [y1,y2]) A = varargin{1}; x1 = varargin{2}(1); x2 = varargin{2}(2); y1 = varargin{3}(1); y2 = varargin{3}(2); case 4 A = varargin{1};% imgrayscaling(X, map, [x1,x2], [y1,y2]) map = varargin{2}; x1 = varargin{2}(1); x2 = varargin{2}(2); y1 = varargin{3}(1); y2 = varargin{3}(2); end % 检测输入参数的有效性 % 检查RGB数组 if (ndims(A)==3) && (size(A,3)~=3) msg = sprintf('%s: 真彩×××像应当使用一个M-N-3维度的数组', ... upper(mfilename)); eid = sprintf('Images:%s:trueColorRgbImageMustBeMbyNby3',mfilename); error(eid,'%s',msg); end if ~isempty(map) % 检查调色板 if (size(map,2) ~= 3) || ndims(map)>2 msg1 = sprintf('%s: 输入的调色板应当是一个矩阵', ... upper(mfilename)); msg2 = '并拥有三列'; eid = sprintf('Images:%s:inColormapMustBe2Dwith3Cols',mfilename); error(eid,'%s %s',msg1,msg2); elseif (min(map(:))<0) || (max(map(:))>1) msg1 = sprintf('%s: 调色板中各个分量的强度 ',upper(mfilename)); msg2 = '应当在0和1之间'; eid = sprintf('Images:%s:colormapValsMustBe0to1',mfilename); error(eid,'%s %s',msg1,msg2); end end % 将int16类型的矩阵转换成uint16类型 if isa(A,'int16') A = int16touint16(A); end; a+ N5 P- x1 e( r; P* I9 d* H5 i
8 I" f' y: s! F
" j2 J7 g& T9 r6 ], n s+ F5 M8 N. A3 r! k1 s& k
- J1=imgrayscaling(I,[0.3,0.7],[0.15,0.85]); >> figure ,imshow(J1,[]);
) I3 z P F# q. Y1 r8 o3 P+ X6 F 4 }! h- G K( F6 G9 ^: r" q
, f- I' i+ a% R: {1 R : H7 C. X7 l. m- l) W
. `7 A- R# Q, B/ Q! |) d' k) u( F
(五)- H9 U+ D( J; b6 |( @
9 w- p! |5 C6 H# I8 j8 W
均衡化' m/ t* x0 c* v9 Y2 J4 p+ |9 b
% R, ~, [, b- P* h3 ?. O$ J 直方图均衡化,灰度级越均匀分布,则图像的对比度越高,易进行判读。 B! b# G K: O4 P
. `) C1 u- X* Y. F1 } [J,T]=histeq(I);
% {. x$ p, J ~
: ^8 `9 R. N$ V! l
0 n5 g4 f& N) V) F, c5 H5 v (六)- y+ m+ h/ {" Y6 ~
T/ x8 x6 r2 X0 ~3 B& E
规定化
! z# J( x% A1 m+ L n9 K7 x- t. u) C0 Y8 @8 {: Q/ {. l
相似拟合过程 ,均衡化逆过程。 |
