查看: 5684|回复: 2
ORCAD生成网表时出现属性错误,请大家帮忙看看
发表于 2011-6-12 18:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
orcad生成网表出现如下错误,不知道该怎么解决了,请大家帮忙看看。* e  I; I! a. k( _
#86 Error   [ALG0013] Conflicting values of following Component Definition properties found on F5 and F2 for part "0451005MRL".- {3 }, R+ v3 y. P2 l4 N# Y  a
              VALUE7 L3 l1 [2 T9 D6 P* N/ a  t, |
#87 Error   [ALG0013] Conflicting values of following Component Definition properties found on J20 and J19 for part "HW_20_15_S_D_328_SM_A_TR".* h% Z2 Z% N  V  j$ }3 k
              VALUE
9 r1 F  m9 I; [) C/ E7 }#88 Error   [ALG0013] Conflicting values of following Component Definition properties found on LB2 and LB1 for part "MGGB2012U101HT_LF".$ e' C8 c9 M/ q- s7 ?
              VALUE
" n8 ^/ {; N4 j3 h' T# E#89 Error   [ALG0013] Conflicting values of following Component Definition properties found on LB28 and LB27 for part "MGLB2012_220T_LF".: m0 m2 ]) B2 _+ X: \# v0 [
              VALUE0 T  H  z7 J( R- Q5 x
#90 Error   [ALG0013] Conflicting values of following Component Definition properties found on LB29 and LB27 for part "MGLB2012_220T_LF".
* v3 v4 L& H  M; t$ M* L; D+ O              VALUE
7 J0 a6 m2 ~/ B2 a: g* M- d* v0 f2 E#91 Error   [ALG0013] Conflicting values o/ S$ T7 h% E; c/ E0 s9 s# F
f following Component Definition properties found on LB3 and LB1 for part "MGGB2012U101HT_LF".
2 h6 [( B3 c: e0 H4 q7 z              VALUE
! i. K+ O' A- C+ V. J2 x, g, R; X% W#92 Error   [ALG0013] Conflicting values of following Component Definition properties found on LB4 and LB1 for part "MGGB2012U101HT_LF".- }& a+ @* T+ t
              VALUE
9 z* u" b2 w1 m' ]% o3 N, `#93 Error   [ALG0013] Conflicting values of following Component Definition properties found on R1021 and R1017 for part "RC0603JR_0710K".  E( ~8 j0 h4 i0 t0 [
              VALUE/ g- Q1 W) w! C/ \
#94 Error   [ALG0013] Conflicting values of following Component Definition properties found on R1022 and R1017 for part "RC0603JR_0710K".
0 D% a( o- t% ?7 O+ C( w3 L+ \4 @              VALUE
4 k0 }2 Z* w6 e: q. v#95 Error   [ALG0013] Conflicting values of following Component Definition properties found on R1026 and R1012 for part "RC0603JR_074K7L".4 N' D; h7 q* V' J, v( {
              VALUE6 E1 P3 `& }5 L2 ~) h3 N; y
#96 Error   [ALG0013] Conflicting values of following Component Definition properties found on R14 and R12 for part "RC0603JR_0733R".& M. m8 t* K# x) }- ]% m
              VALUE
$ L# R& ^9 u/ X$ N( M- Y5 R  P: o#97 Error   [ALG0013] Conflicting values of following Component Definition properties found on R15 and R12 for " c1 l- r$ Z, l: A9 Y0 Z
part "RC0603JR_0733R".  l; }2 `2 z, D8 s; Z# F
              VALUE
. G8 W! {/ a& x$ u8 s0 U% g6 A#98 Error   [ALG0013] Conflicting values of following Component Definition properties found on R16 and R12 for part "RC0603JR_0733R".
, E1 d# W: e3 s* D* a/ j: t7 }% ~  y              VALUE+ h9 x" p3 _1 @& i, Q0 s
#99 Error   [ALG0013] Conflicting values of following Component Definition properties found on R165 and R1012 for part "RC0603JR_074K7L".% j( [9 P4 ]5 K- ]; y# U
              VALUE
6 A4 ]! `4 S  s4 M#100 Error   [ALG0013] Conflicting values of following Component Definition properties found on R17 and R12 for part "RC0603JR_0733R".
; |( h4 e* ?6 I9 A3 F1 B3 a' V              VALUE
6 `, Q/ h  U- c$ A% N#101 Error   [ALG0013] Conflicting values of following Component Definition properties found on R170 and R1012 for part "RC0603JR_074K7L".2 C$ B: F0 l: ~0 t; y
              VALUE
* Z( ~" J7 ]* z2 j6 V#102 Error   [ALG0013] Conflicting values of following Component Definition properties found on R18 and R12 for part "RC0603JR_0733R".
/ l9 E+ t) V3 u  P. j              VALUE
. Y7 |/ |  E1 k) Y5 C; h#103 Error   [ALG0013] Conflicting values of following Component Definition properties found on R19 and R12 for part "RC0603JR_0733R".
. E- H) g: _, g              VALUE9 \" u1 Y" G) O4 @2 I
#104 Error   [ALG0013] Conflicting values of following Component Definition properties found on R193 and R192 for part "RK73H2ATTD1781F".) ?; P# N6 ]7 H* G- m
              VALUE0 G* j* V4 f: e" ^2 y6 v1 u
#105 Error   [ALG0013] Conflicting values of following Component Definition properties found on R194 and R192 for part "RK73H2ATTD1781F".6 P9 \7 ~+ z8 B4 _2 n& u
              VALUE
1 Q+ B, L3 R0 R3 l#106 Error   [ALG0013] Conflicting values of following Component Definition properties found on R195 and R192 for part "RK73H2ATTD1781F".
  A/ s) M# B  h. m2 t* R              VALUE$ [* i3 G0 z% l: @2 H" Z: a+ {& c& G
#107 Error   [ALG0013] Conflicting values of following Component Definition properties found on R20 and R12 for part "RC0603JR_0733R".
8 z& N, N7 P2 y) [  V& i              VALUE/ Z3 B+ W/ A# W; h" c# [5 v
#108 Error   [ALG0013] Conflicting values of following Component Definition properties found on R21 and R12 for part "RC0603JR_0733R".3 A+ l1 `1 A! L5 ?7 W5 [
              VALUE
% R" q: L) |$ P3 g#109 Error   [ALG0013] Conflicting values of following Component Definition properties found on R22 and R12 for part "RC0603JR_0733R".
# z, u8 @7 P  c6 t, j! j1 [/ C              VALUE8 S' m  t+ X( ~: M* Q; _
#110 Error   [ALG0013] Conflicting values of following Component Definition properties found on R226 and R1011 for part "RC0603JR_071K".
0 R$ `* C  \" L& Z" |8 `) N              VA
2 t( \$ f$ e* w% |) KLUE
& s- r, V, h) T4 s/ y#111 Error   [ALG0013] Conflicting values of following Component Definition properties found on R227 and R1011 for part "RC0603JR_071K".. o0 N$ F( l) \7 H3 A. Y, O6 J/ w& K
              VALUE
2 R8 v+ J4 ]) C* A  m* @, W#112 Error   [ALG0013] Conflicting values of following Component Definition properties found on R23 and R12 for part "RC0603JR_0733R".% z8 u( X( S# K
              VALUE
/ I8 {+ r8 e- o1 w: i$ [/ p#113 Error   [ALG0013] Conflicting values of following Component Definition properties found on R232 and R12 for part "RC0603JR_0733R".$ N- v- j6 l# [( m- ?6 b" ~+ c
              VALUE
; {' w& ]( d; W* T  k#114 Error   [ALG0013] Conflicting values of following Component Definition properties found on R235 and R1011 for part "RC0603JR_071K".
6 G. n8 m7 m9 u7 P% S) ~/ I              VALUE
) p8 ~6 C$ f8 a$ p7 C2 r+ Z: o#115 Error   [ALG0013] Conflicting values of following Component Definition properties found on R24 and R12 for part "RC0603JR_0733R".
0 A8 |" @7 m$ Y, R: j              VALUE
' A: P$ Q; Y# D6 f4 {* a; l  t#116 Error   [ALG0013] Conflicting values of following Component Definition properties found on R241 and R240 for part "RC0603JR_071KL".+ m$ {7 e+ {3 }5 J  ^& l
              VALUE
6 t7 T4 P) q: f7 W4 s#117 Error   [ALG0013] Conflicting values of following Component Definition properties found on R242 and R240 for part "RC0603JR_071KL".' S2 a, h: j# y9 Z! K3 R; W3 }+ L( Z
              VALUE
1 _' y" R! x' H9 j#118 Error   [ALG0013] Conflicting values of following Component Definition properties found on R243 and R240 for part "RC0603JR_071KL".
, u# r! V! n7 y9 F* j8 \4 N' _              VALUE  R6 s6 E; \+ \4 l* i3 m  k' u- [
#119 Error   [ALG0013] Conflicting values of following Component Definition properties found on R244 and R240 for part "RC0603JR_071KL"." f9 |1 L/ l2 v5 Z$ h$ g
              VALUE! n$ I0 D- Z' o% T6 M
#120 Error   [ALG0013] Conflicting values of following Component Definition properties found on R245 and R240 for part "RC0603JR_071KL".5 k8 n, T; P/ b. G
              VALUE* n  u% \- p! b' c  U
#121 Error   [ALG0013] Conflicting values of following Component Definition properties found on R246 and R240 for part "RC0603JR_071KL".
  @$ c& t* M: F/ V              VALUE
8 G* S( ?" H* F) N#122 Error   [ALG0013] Conflicting values of following Component Definition properties found on R247 and R240 for part "RC0603JR_071KL".% _( m; W* E; C# G
              VALUE
4 w/ \$ R  d/ J6 ]; S3 V3 y9 r#123 Error   [ALG0013] Conflicting values of following Component Definition properties found on R249 and R1008 for part "RC0603JR_070RL".9 ]8 ?0 C5 U" t+ w
5 {, R- d! e2 v3 D& ^             VALUE
1 P: J8 u# a7 z0 R#124 Error   [ALG0013] Conflicting values of following Component Definition properties found on R25 and R12 for part "RC0603JR_0733R".) _/ u& H0 n: u) l
              VALUE
& W( z. ^3 c, g" a! \8 N#125 Error   [ALG0013] Conflicting values of following Component Definition properties found on R250 and R1008 for part "RC0603JR_070RL".
. w' K" x5 A7 f7 f; b              VALUE" }) Z+ v3 U2 x8 F
#126 Error   [ALG0013] Conflicting values of following Component Definition properties found on R251 and R1008 for part "RC0603JR_070RL".: N# h, n* {. T0 K+ p
              VALUE7 T1 t9 R6 m( G. O. N- Y2 u0 i
( ]6 R. q9 q: q  y1 h, G
发表于 2011-9-19 16:38 | 只看该作者
如果这一栏的作用不大,直接删除,要是有用,就可以先把这一栏删除,导出网表再说,然后再找问题和解决办法
发表于 2012-11-8 11:16 | 只看该作者
改吧,试试就知道
GMT+8, 2025-10-27 02:20 , Processed in 0.140625 second(s), 24 queries , Gzip On.
