查看: 406|回复: 0
MS7024(TV Encoder)
发表于 2021-8-3 17:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Input Formatter
; c: O0 b) [1 g/ i6 KFeatures
& l2 D/ `2 D5 S# S Supports 24-bit/16-bit/8-bit digital input: ^9 z+ t9 o6 n) [
 Supports various RGB and YCrCb input data formats- F, v5 {9 l0 G0 `3 [; f
 Supports for input resolutions of 720×480 and 720×576 in interlace or progressive mode4 L) |9 V5 ^4 d" p8 D4 U4 P
 Supports ITU-R BT.601/656 standard input
) K/ H4 ]" j# I  w$ j+ Q4 h Brightness, contrast and saturation adjustable
  C6 E+ i5 Z$ {2 N5 i' P Fully programmed through a serial port
! A1 U6 r0 N8 U+ T+ n1 V  ]. w7 G! G; L
Output Formatter& K- w; X! k; N/ z& p3 d
 High quality 10-bit triple-DAC
6 X" A: l# G( k/ C0 c& V: } Supports analog AV and S-Video output
9 ~0 g# g4 }* b+ B$ R5 M Supports formats NTSC-M, NTSC-J, NTSC-433, PAL-B/D/G/H/I, PAL-M, PAL-N and PAL-600 x% e& `' o& \% ]! S  u
 Supports hot plug detection2 Y8 l0 ^$ ]" D8 w+ G" ?, q/ g' x. w
+ p: K  q2 \3 p4 ]
2-wire I2C Slave InteRFace Package
$ W, `2 @+ w8 m* i( \+ K- f TQFP -48 plastic(7mm×7mm): `, i: J$ K* |8 r6 i9 Q
 PB-free and RoHS compliant5 W- u0 _% ?0 N- c# _' ]
GMT+8, 2025-10-12 11:32 , Processed in 0.125000 second(s), 24 queries , Gzip On.
