三极管,全称应为半导体三极管,也称双极型晶体管、晶体三极管,是一种控制电流的半导体器件。其作用是把微弱信号放大成幅度值较大的电信号,也用作无触点开关。
! s2 }) w- C& w9 [' }: C" C常见三极管的型号* l" N F9 A; b' N2 `& N5 K1 F% @4 u5 R6 \
9011: 除是音频低噪音管外.还是长尾可变放大倍数的第一中放专用管. 长尾--即使电流一直延伸到接近0. 仍不会截止.可变放大倍数--电流变小.放大倍数不断变小.好象几乎是日常常用管中唯一一只第一中放专用管6 r& i/ Z- A; s$ g, v7 w1 l
9012: PNP" `! x) s0 q5 k, l, f
9013: NPN, Ic = 500mA, 中功率, 低频, 能推动普通音频输出的中功率放大$ L, Z- o( R a. U( M2 O ^
9014: NPN, Ic = 100mA, MHz, 小功率, 低频, 低噪放大
6 a( [; v- w: g# }# o0 k$ X9015: PNP% i& a: I" Z6 w- V. {# h+ C0 J
9018: NPN, Ic = 50mA, fT = ~ 620 ~ 1100 MHz, 小功率, 高频, 小电流低噪音
! a, D1 _5 p8 ^8050: NPN, Ic = 1000~1500mA, 高频放大, 速度慢一些, 中功率管, 小功率放大电路中配对管, 小电子产品, 高频电路和电话中常见
3 g& [ y+ ~% ~- g8 f8550: PNP, Ic = 1000~1500mA, 高频放大, 速度慢一些, 中功率管3 M7 x3 w5 L* y4 u1 X' j1 S4 o: B
2N3904: NPN,
! [; z5 X& S6 ]$ G r2N3906: PNP, Ic = 200mA, 小功率管, 速度比较快, 延时特别少, 最大通过的电流是在200mA, It is a 200 mA, 40 V, 625 mW transistor with a transition frequency of 300 MHz,[4] with a minimal beta, or current gain, of 100 at a collector current of 10 mA. It is used in a variety of analog amplification and switching applications. The 2N3904 is used very frequently in hobby electronics projects, including home-made ham radios, code-practice oscillators and as an interfacing device for microcontrollers.
) r# n2 s2 j6 R( Q4 M$ T2N2222: NPN, Ic = 500mA, 可与2N2907/2N2907A PNP管做互补对称管使用, common NPN bipolar junction transistor (BJT) used for general purpose low-power amplifying or switching applications. It is designed for low to medium current, low power, medium voltage, and can operate at moderately high speeds. It was originally made in the TO-18 metal can as shown in the picture
_4 U# R$ V2 K& E I( f' |2N2907: PNP,0 A: X, G+ h; j r
2N5551: NPN, Ic = 600mA, VCEO=160V, 高反压三极管, 主要用途是1)做高压开关管, 2)做中功率功放, 3)做视频放大器
8 @. M4 X3 }1 f7 g2N5401: PNP1 w6 g/ |8 V3 I7 H) E$ D
BC184: NPN, VCEO=30V, Ic = 500mA, ICBO=<15nA, 通用小信号放大
, N& q; t* x1 vBC550: NPN, VCEO=45V, Ic = 100mA, ICBO=<15nA, 通用小信号放大, q* h7 y+ m6 O9 Y6 L; F) S
BC560: PNP, VCEO=-45V, Ic = -100mA, ICBO=<15nA, 通用小信号放大7 p* r1 P" M, t+ Q- A3 D5 ~
MMBTA63, LMBTA63, SMBTA63: PNP, Darlington, Ic = -500mA, VCEO=-30V, hFE=5k~10k
1 S! x+ z; j& p7 u# l3 W" [MPSA64, MMBTA64, LMBTA64, SMBTA64: PNP, Darlington, VCEO=-30V, Ic = -100mA, hFE=10k~20k,
/ V9 E0 Y( @ q6 l& SMPSA14, KSP14: NPN, Darlington, Ic在0.1~100mA之间hFE为1万至4万, 80mA处达到最大.hFE随温度上升明显升高, 低噪音微小信号放大7 |6 t* `6 I( L$ r: p7 t
KSP13: NPN, Darlington, Ic = 500mA, VCEO=30V, hFE=5k~10k8 j5 f7 a3 V' ^
MPSA18: NPN, ICBO=<15nA, 低噪音微小信号放大. M1 Y# Z- f5 k7 |& Q
MPSA92: PNP, VCEO=-300V, Ic = -30mA, 高压小信号, 功放
* |: D# G8 S/ q" FMPSA42: NPN, VCEO=300V, Ic = 30mA, 高压小信号, 功放与MPSA92组成对管
9 c A; _" z, V" C2 _FMMT734: PNP, Darlington, Ic = -800mA, VCEO=-100V, hFE=20k~60k, 高负压高电流大放大倍数达林顿管, 室温下Ic在1~100mA间能保持7.5万的hFE. hFE随温度上升明显升高3 h. l3 S$ H/ o4 R# `$ l v$ n' n
FMMT634: NPN, Darlington
9 t6 E( R+ g- Z; mMPSA系列小信号三极管 |
