+ M+ L5 y& s' ^, v$ V& d+ Z$ [! _6 D一、简介% v; ^1 X6 s9 s4 d3 X
, k5 J N' P) d/ \; F9 T0 s图像分割就是把图像分成若干个特定的、具有独特性质的区域并提出感兴趣目标的技术和过程。它是由图像处理到图像分析的关键步骤。现有的图像分割方法主要分以下几类:基于阈值的分割方法、基于区域的分割方法、基于边缘的分割方法以及基于特定理论的分割方法等。从数学角度来看,图像分割是将数字图像划分成互不相交的区域的过程。图像分割的过程也是一个标记过程,即把属于同一区域的像素赋予相同的编号。
3 h- d% S) v( v+ ?4 I3 P; e% W) @/ U" b) I" b) D" W
8 r7 q8 E. t6 I5 }7 Z二、源代码% L+ q' g; c& _6 M% E" y& ~7 W9 j
" D9 d6 e; S4 `. g! G2 r
& w. b) O) G: N9 i
- function varargout = ImageGUI(varargin)
- % IMAGEGUI MATLAB code for ImageGUI.fig
- % IMAGEGUI, by itself, creates a new IMAGEGUI or raises the existing
- % singleton*.
- % H = IMAGEGUI returns the handle to a new IMAGEGUI or the handle to
- % the existing singleton*.
- % IMAGEGUI('CALLBACK',hObject,eventData,handles,...) calls the local
- % function named CALLBACK in IMAGEGUI.M with the given input arguments.
- % IMAGEGUI('Property','Value',...) creates a new IMAGEGUI or raises the
- % existing singleton*. Starting from the left, property value pairs are
- % applied to the GUI before ImageGUI_OpeningFcn gets called. An
- % unrecognized property name or invalid value makes property application
- % stop. All inputs are passed to ImageGUI_OpeningFcn via varargin.
- % *See GUI Options on GUIDE's Tools menu. Choose "GUI allows only one
- % instance to run (singleton)".
- % See also: GUIDE, GUIDATA, GUIHANDLES
- % Edit the above text to modify the response to help ImageGUI
- % Copyright 2011 The MathWorks, Inc.
- % Last Modified by GUIDE v2.5 09-Jun-2015 20:18:33
- % Begin initialization code - DO NOT EDIT
- gui_Singleton = 1;
- gui_State = struct('gui_Name', mfilename, ...
- 'gui_Singleton', gui_Singleton, ...
- 'gui_OpeningFcn', @ImageGUI_OpeningFcn, ...
- 'gui_OutputFcn', @ImageGUI_OutputFcn, ...
- 'gui_LayoutFcn', [] , ...
- 'gui_Callback', []);
- if nargin && ischar(varargin{1})
- gui_State.gui_Callback = str2func(varargin{1});
- end
# y2 d2 ]7 w& |2 _. r2 {2 K 3 ]6 y6 z+ g4 v0 J0 v& E4 o$ H
+ K; m7 G& T9 A4 X5 V
三、运行结果
/ `4 l2 E! S9 M8 A
- y- t. G" w6 _! D& r I
" O/ \7 \$ }1 A7 i0 F- c, z
. Z5 b) [7 m- L M0 f: g
- K% z# A* G0 a( n9 _/ |2 }1 M3 |" f! b. Q
' M% O2 y# b/ f9 X; I& B; b( T3 a |
