查看: 848|回复: 3
PCB设计中专业英译术语之基材
发表于 2021-7-5 10:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
0 M/ S/ B8 o8 ~2 K: o" C
  PCB设计中专业英译术语之基材:5 \* x+ y& X8 Q: W* b# A, i
  1. 基材:base material
( k8 V8 L! n. ?. z7 l% M  2. 层压板:laminate
, ?' Z5 w& \5 t: q' Z, f8 j( t  3. 覆金属箔基材:metal-clad bade material
# {  {% t6 f3 q+ s4 \4 Q/ o# X* p  4. 覆铜箔层压板:copper-clad laminate (CCL)
  _. ^# M5 J; m: C+ {- _+ _  5. 单面覆铜箔层压板:single-sided copper-clad laminate
" j: [& J6 S8 U) V  6. 双面覆铜箔层压板:double-sided copper-clad laminate
, W4 Y9 K& k7 ~6 C; x2 E' b  7. 复合层压板:composite laminate
+ o' F4 H5 h6 B  8. 薄层压板:thin laminate/ b# Y* V) O& c
  9. 金属芯覆铜箔层压板:metal core copper-clad laminate! \1 L$ D/ I" z( i8 t
  10. 金属基覆铜层压板:metal base copper-clad laminate' S+ x$ n$ e* ^7 C6 f
  11. 挠性覆铜箔绝缘薄膜:flexible copper-clad dielectric film
& O$ H  e+ r: w+ H9 o/ l2 |- T  12. 基体材料:basis material
: m8 z. a0 T" O/ i2 B. l( ~  13. 预浸材料:prepreg
. ~) |' z! n4 p: Z/ ]3 ~  14. 粘结片:bonding sheet
+ _- d5 W* W; ^  15. 预浸粘结片:preimpregnated bonding sheer
7 I, C/ Q8 s/ Q7 i. I+ K: x; I  16. 环氧玻璃基板:epoxy glass substrate
: T4 E# v5 F& w  17. 加成法用层压板:laminate for additive process
2 Z2 w" L3 O3 ~1 ?5 @2 v  18. 预制内层覆箔板:mass lamination panel3 v' P' s- i/ r) ]
  19. 内层芯板:core material- r3 V* C3 W" z) K
  20. 催化板材:catalyzed board ,coated catalyzed laminate) Z! k, E* a$ g
  21. 涂胶催化层压板:adhesive-coated catalyzed laminate0 _0 K. K8 n/ d8 E9 y; P$ i
  22. 涂胶无催层压板:adhesive-coated uncatalyzed laminate+ n, i- {/ M1 ], ^
  23. 粘结层:bonding layer- y& P2 D3 }# B* v2 @* H% k2 E/ c
  24. 粘结膜:film adhesive
( [0 d/ j; X; ]/ K! t" s  25. 涂胶粘剂绝缘薄膜:adhesive coated dielectric film) L6 ?( c6 }9 ~8 c( i7 [( l
  26. 无支撑胶粘剂膜:unsupported adhesive film# w1 u: N9 W- D2 f% q. V% Q
  27. 覆盖层:cover layer (cover lay)7 M/ T" }. E3 @9 j3 a* Y$ W
  28. 增强板材:stiffener material! C8 c, W! v: o8 ~* i
  29. 铜箔面:copper-clad suRFace5 i# E: T6 w. b0 \% Y
  30. 去铜箔面:foil removal surface! x' E9 c4 c; G6 S
  31. 层压板面:unclad laminate surface* F7 H: b; S. z# u7 u
  32. 基膜面:base film surface
) z( ]. a& s, H7 m* L  33. 胶粘剂面:adhesive faec4 H' x6 l# m; W+ V) ~
  34. 原始光洁面:plate finish. c& \" z4 u6 D' m0 I# N$ }
  35. 粗面:matt finish
, ^7 S( @& e5 |6 O9 ~  36. 纵向:length wise direction% H! t8 |+ p+ O
  37. 模向:cross wise direction* b# s. I: ]+ ^+ T
  38. 剪切板:cut to size panel
3 T7 h/ U) l  a- f5 R  39. 酚醛纸质覆铜箔板:phenolic cellulose paper copper-clad laminates(phenolic/paper CCL)
$ ?* j7 q: p9 B; t  40. 环氧纸质覆铜箔板:epoxide cellulose paper copper-clad laminates (epoxy/paper CCL)5 e- R; e- I) t5 C  q
  41. 环氧玻璃布基覆铜箔板:epoxide woven glass fabric copper-clad laminates! M8 ~' G* P  S8 e
  42. 环氧玻璃布纸复合覆铜箔板:epoxide cellulose paper core, glass cloth surfaces copper-clad laminates9 L# ?! C, ]- e; r4 Q" d' L8 P5 P3 D
  43. 环氧玻璃布玻璃纤维复合覆铜箔板:epoxide non woven/woven glass reinforced copper-clad laminates
2 ~3 ~' p9 N9 P& Q9 w& C  44. 聚酯玻璃布覆铜箔板:ployester woven glass fabric copper-clad laminates# E( b% q! v$ @" R; e
  45. 聚酰亚胺玻璃布覆铜箔板:polyimide woven glass fabric copper-clad laminates
6 U2 q. w  C  T, Z" ]) Q  N  46. 双马来酰亚胺三嗪环氧玻璃布覆铜箔板:bismaleimide/triazine/epoxide woven glass fabric copper-clad lamimates
3 }5 b8 ]" }# H. c  47. 环氧合成纤维布覆铜箔板:epoxide synthetic fiber fabric copper-clad laminates8 @! w( i* H1 f3 m; b, V/ M2 C
  48. 聚四乙烯玻璃纤维覆铜箔板:teflon/fiber glass copper-clad laminates
6 e( k% n4 K! u1 l  49. 超薄型层压板:ultra thin laminate' e. }0 @% v- ]" f* m5 ?6 f
  50. 陶瓷基覆铜箔板:ceramics base copper-clad laminates" }7 I* B' u8 Z5 {4 J: r1 A. U* W
  51. 紫外线阻挡型覆铜箔板:UV blocking copper-clad laminates
发表于 2021-7-5 11:23 | 只看该作者
6666666666666666
发表于 2021-7-5 11:29 | 只看该作者
66666666666666
发表于 2021-7-5 12:14 | 只看该作者
6666666666
GMT+8, 2025-10-10 04:26 , Processed in 0.140625 second(s), 23 queries , Gzip On.
