3 o' o, b4 o8 D6 K7 x一、简介) q- |+ L! h& k7 ]/ }
! u2 L3 `( i- O% y, V3 I) D& m) s基于matlab环境开发的图像处理系统,实现图像的读取,显示,拖动,缩放,旋转,指定位置显示,并在图像处理窗口中实现了选择音乐播放的功能。
* b7 M! ?8 A! k! C+ @ v; @ f5 e- Z* O, ?7 N
二、源代码
: d( q$ {" r2 t& }% P6 O
6 U$ A# v0 V. p1 f6 A4 U- function varargout = Imgproc(varargin)
- % IMGPROC MATLAB code for Imgproc.fig
- % IMGPROC, by itself, creates a new IMGPROC or raises the existing
- % singleton*.
- % H = IMGPROC returns the handle to a new IMGPROC or the handle to
- % the existing singleton*.
- % IMGPROC('CALLBACK',hObject,eventData,handles,...) calls the local
- % function named CALLBACK in IMGPROC.M with the given input arguments.
- % IMGPROC('Property','Value',...) creates a new IMGPROC or raises the
- % existing singleton*. Starting from the left, property value pairs are
- % applied to the GUI before Imgproc_OpeningFcn gets called. An
- % unrecognized property name or invalid value makes property application
- % stop. All inputs are passed to Imgproc_OpeningFcn via varargin.
- % *See GUI Options on GUIDE's Tools menu. Choose "GUI allows only one
- % instance to run (singleton)".
- % See also: GUIDE, GUIDATA, GUIHANDLES
- % Edit the above text to modify the response to help Imgproc
- % Last Modified by GUIDE v2.5 04-Jul-2012 23:55:05
- % Begin initialization code - DO NOT EDIT
- gui_Singleton = 1;
- gui_State = struct('gui_Name', mfilename, ...
- 'gui_Singleton', gui_Singleton, ...
- 'gui_OpeningFcn', @Imgproc_OpeningFcn, ...
- 'gui_OutputFcn', @Imgproc_OutputFcn, ...
- 'gui_LayoutFcn', [] , ...
- 'gui_Callback', []);
- if nargin && ischar(varargin{1})
- gui_State.gui_Callback = str2func(varargin{1});
- end
9 ?8 b0 p. ]. {
2 M8 I5 T$ G+ v ^' U1 ~7 D: s) H+ l; v. G, O( ~ l
三、运行结果
9 C9 X' Y9 ?5 s; K9 M/ u e1 D; \& i* a k N- b% e
* m4 T! {) |( T: {7 L2 M+ l |
