查看: 860|回复: 4
基于matlab GUI二值化+灰白质医学影像分割
    2019-11-20 15:22
    发表于 2021-6-29 13:49 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
    & l+ @  p  L* a8 y一、简介: Y" A' s6 ]: J6 }6 ?& Y
    - P$ ]8 t9 c, _5 m$ i$ r基于matlab GUI界面医学影像分割
    / \/ R0 F7 P  ]
    / f9 f( Z* w7 F" l3 [二、源代码- W, g* a4 H( c. D0 S
    5 i5 M" Y" P& y, i) S
    " N) X) V/ [+ R( U7 B. t2 d
    • function varargout = brain_ysw(varargin)
    • % BRAIN_YSW MATLAB code for brain_ysw.fig
    • %      BRAIN_YSW, by itself, creates a new BRAIN_YSW or raises the existing
    • %      singleton*.
    • %      H = BRAIN_YSW returns the handle to a new BRAIN_YSW or the handle to
    • %      the existing singleton*.
    • %      BRAIN_YSW('CALLBACK',hObject,eventData,handles,...) calls the local
    • %      function named CALLBACK in BRAIN_YSW.M with the given input arguments.
    • %      BRAIN_YSW('Property','Value',...) creates a new BRAIN_YSW or raises the
    • %      existing singleton*.  Starting from the left, property value pairs are
    • %      applied to the GUI before brain_ysw_OpeningFcn gets called.  An
    • %      unrecognized property name or invalid value makes property application
    • %      stop.  All inputs are passed to brain_ysw_OpeningFcn via varargin.
    • %      *See GUI Options on GUIDE's Tools menu.  Choose "GUI allows only one
    • %      instance to run (singleton)".
    • % See also: GUIDE, GUIDATA, GUIHANDLES
    • % Edit the above text to modify the response to help brain_ysw
    • % Last Modified by GUIDE v2.5 10-Jun-2015 13:34:14
    • % Begin initialization code - DO NOT EDIT
    • gui_Singleton = 1;
    • gui_State = struct('gui_Name',       mfilename, ...
    •                    'gui_Singleton',  gui_Singleton, ...
    •                    'gui_OpeningFcn', @brain_ysw_OpeningFcn, ...
    •                    'gui_OutputFcn',  @brain_ysw_OutputFcn, ...
    •                    'gui_LayoutFcn',  [] , ...
    •                    'gui_Callback',   []);
    • if nargin && ischar(varargin{1})
    •     gui_State.gui_Callback = str2func(varargin{1});
    • end
    • if nargout
    •     [varargout{1:nargout}] = gui_maiNFCn(gui_State, varargin{:});
    • else
    •     gui_mainfcn(gui_State, varargin{:});
    • end
    • % End initialization code - DO NOT EDIT( j- A6 r- V  L( w: {* C! v
    7 J2 _! A- a1 n1 v2 \
    ' d: c* v' o, s4 o& v! \5 l8 d) s6 a4 s2 l7 ]8 ]6 F2 d
    三、运行结果
    4 r# T0 u  U1 N& D2 w. U: z$ _( H, G' u* i6 `9 c5 X$ b
    6 ~1 u8 e9 e$ ^/ u% ?
    0 l! ~) w& z1 q- e4 |
    ) p& L) j6 N, f9 I: {4 B& C. H
    ( H) c% p* C& g2 a5 W; H8 u
    2 q6 M% F$ d2 [: R* m
    2019-11-29 15:37
    发表于 2021-6-29 15:00 | 只看该作者
    发表于 2021-6-29 15:01 | 只看该作者
    难过
    2019-11-20 15:02
    发表于 2021-6-29 15:02 | 只看该作者
    发表于 2021-7-1 18:47 | 只看该作者
    GMT+8, 2025-10-29 21:32 , Processed in 0.156250 second(s), 26 queries , Gzip On.
