SYM_NAME | COMP_DEVICE_TYPE | REFDES |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | C2;C3;C4;C5;C7;C9;C15;C16;C19;C23;C28;C29;C30;C35;C36;C37;C38;
& p+ N( q3 P( M0 }C39;C40;C41;C42;C43;C44;C45;C65;C67;C68;C69;C72;C74;C78;C79;
' e, B$ v4 J, ?* |1 d) RC81;C82;C83;C84;C85;C86 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.56M | C10;C18;C47 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | C13;C14 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | C24;C25;C31 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_3 | C34;C46 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.635 | C77 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1MM_1 | C6;C8;C11;C22;C26;C27;C66;C70;C71;C80 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | C12;C21 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.0MM | C17 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.25M | C20 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.95M | C32;C33 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.90M | C75;C76 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | C73 |
CCE6P8X6P8 | CAP_POL_CCE6P8X6P8_DISCRETE_6.1 | C1 |
CON2X8_2P54_TH | HDR_2X8_M_CON2X8_2P54_TH_IO_8.6 | J1;J3;J4 |
CON3_PWR_JACK_TH_PJ051A | DC_POWER_JACK_SHD_CON3_PWR_JACK | J9 |
CON_HDR_4M_100_TH_RA | CONN_HDR_4X1_CON_HDR_4M_100_TH_ | J8;J12 |
CON_MICROAB_10F_25_SM_RA | MICRO_USB_CONN_10PIN_CON_MICROA | J16 |
HDR1X2_5P48X2P69 | CONN_HDR_2X1_HDR1X2_5P48X2P69_I | J15 |
HDR101 | CONN_HDR_1X1_HDR101_IO_8.59MM_2 | JP1 |
HDR103_A | CONN_HDR_3X1_HDR103_A_IO_8.74MM | J13 |
HDR203 | CONN_HDR_3X2_HDR203_IO_8.58MM_2 | J7;J14 |
HSMX-C170 | LED_HSMX-C170_IC_0.8 MM_370-300 | D2 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.05 MM_ | L3;L4 |
IND_1206 | BEAD_IND_1206_DISCRETE_1.3MM_18 | L2 |
LED6_5X6MM | LED_TRI_COLOR_LED6_5X6MM_IC_2.6 | D9 |
LED_0603 | LED_LED_0603_IC_0.85MM_370-7654 | D6 |
LED_0603 | LED_LED_0603_IC_0.8MM_370-75080 | D7 |
LED_0603 | LED_LED_0603_IC_0.8MM_370-76537 | D10 |
LED_0603 | LED_LED_0603_IC_0.8MM_370-75076 | D11 |
LQFP112 | MC9S12XEP100_1_LQFP112_IC_1.6MM | U3 |
POT3_3352T | POT_POT3_3352T_DISCRETE_4.32 MM | R49 |
POWERDI-123_3MMX2MM | DIODE_SCHTKY_POWERDI-123_3MMX2M | D1;D3;D5 |
QFN48_0P5_5P25X5P25_A | MC9S08JM60CGT_0_QFN48_0P5_5P25X | U4 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45 MM_ | R3;R10;R15;R21;R23;R24;R25;R27;R28;R29;R30;R31;R32;R33;R34;. m; o8 S S' w( k7 v, [5 G
R35;R40;R41;R59;R81;R92;R95;R96;R97;R98;R111;R112;R113;R114 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | R17;R54;R55;R56;R57;R58;R62;R63;R64;R65;R66;R68;R71;R72;R74;R75 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | R37 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | R47;R48 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 MM_ | R60 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__3 | R61 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__4 | R67;R69 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__5 | R76 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__6 | R78;R79 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM_47 | R1 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55 MM_ | R2;R8 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_2 | R5;R12 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_1 | R7;R11 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM__1 | R13;R50 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55 M_1 | R20 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM__2 | R36 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55 M_2 | R38;R39 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55 M_3 | R44;R45;R46 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55 M_4 | R70 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55 M_5 | R84 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_4 | R91 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.65MM_4 | R18;R19 |
RC1206_OV | RES_RC1206_OV_DISCRETE_0.6MM_47 | R14;R16 |
SC70_3 | DDTD122LC_SC70_3_IC_1.1MM_480-7 | U9;U13 |
SC70_3 | DDTA113ZCA_3P_SC70_3_IC_1.1MM_4 | U11 |
SH0402 | RES_SHORT-2_SH0402_DISCRETE_0.1 | SH1 |
SH0603 | RES_SHORT-2_SH0603_DISCRETE_0.1 | SH2 |
SO8 | MIC2526_8P_SO8_IC_1.73MM_312-75 | U5 |
SOD123 | ZDIODE_SOD123_IC_1.35MM_480-762 | D4 |
SOIC32_0P65_7P6X11P1_5P2EPAD | MCZ33903BD_SOIC_1_SOIC32_0P65_7 | U2 |
SOT23_5S | SPX3819M5_FIX_5P_SOT23_5S_IC_1. | U1 |
SOT223 | TRAN_PNP_SOT223_SOT223_IC_1.75 | Q1 |
SOT666 | RCLAMP0502A_6P_SOT666_IC_0.6MM_ | U10 |
SOT891_6P_0P35_1P05X1P05 | 74LVCH1T45_0_SOT891_6P_0P35_1P0 | U7;U8;U12 |
SW4_SPST_4P8X3P6_2P5 | EDGE_MOUNT_PB_SW_2_SW4_SPST_4P8 | SW1;SW2;SW3;SW4 |
TESTPOINT_135_070MIL | TEST_POINT_TESTPOINT_135_070MIL | GND1;GND2;GND3;GND4;RST1;TP19 |
TPAD_028 | TESTLOOP_TPAD_028_IO_0.1 MM_211 | TP1;TP2;TP3;TP4;TP5;TP6;TP7;TP8;TP9;TP10;TP11;TP12;TP13;2 @# q$ }% u0 T
TP14;TP15;TP16;TP17;TP18;TP20;TP21;TP22;TP23;TP24;TP25;
* N& ~8 g5 w, ]TP26;TP27;TP28;TP29;TP30;TP31;TP32;TP33;TP34;TP35;TP36;
/ S4 k0 Z* j8 vTP37;TP38;TP39;TP40;TP41;TP42;TP43;TP44;TP45 |
UDFN6_1X1P5MM | NC7SV04_UDFN6_1X1P5MM_IC_0.5MM_ | U6 |
XTAL2_3P3X2P6 | XTAL_CS10_XTAL2_3P3X2P6_IC_1MM_ | Y1 |
XTL2_ECS_CSM7_SM | XTAL_XTL2_ECS_CSM7_SM_IC_4.3MM_ | Y2 |
