那请问 你的A。B。C长度关系是如何确定的 $ U9 l Z9 g$ N$ x& u. C我在参考中看到 * x% R- Y7 @$ j1 Q" M5 X- q
ADDR_CTRL A to B/A to C Skew Length Mismatch 100 Mils+ i5 }0 z K/ X! P8 n Z1 H
ADDR_CTRL B to C Skew Length Mismatch 100 Mils 9 U5 ?. ]- z ]+ ~5 H k而在之前 / W t& t/ i( ?4 BDDR2 CK and ADDR_CTRL Routing5 S+ s( O3 ?; D5 U0 F& o
Figure 6 shows the topology of the routing for the CK and ADDR_CTRL net classes. The route is a balanced T as it is intended that the length of segments B and C be equal. In addition, the length of A should be maximized. 6 B {* m& d% ^3 E我感觉应该是Y型拓扑,而且每个分支都相同 & }6 C, g- b* H3 R# G请问你是如何做的?
