| 37962 | ECO changes a dot to a comma with the concatenation of parameters if Windows regional settings are set to German where a decimal point is set to a comma. (BC:12774 ) |
| 39368 | Parameter Set values and Differential Pair Routing rules values did not correspond to the Impedance Profile values. |
| 43475 | ECO did not remove a duplicated component from the PCB. |
| 43720 | The parameter is not rotated after selecting it on the schematic then pressing the Spacebar. (BC:15238 ) |
| 44056 | Regression caused leading spaces to not be trimmed in certain projects. (BC:15416 ) |
| 44087 | The Tools > Update From Libraries command does not allow parameter changes to be reviewed. (BC:15068 ) |
| 44250 | Using the Place NoERC command from the ERC marker right-click menu does not work correctly. |
| 44830 | Added the 'Show Automatic Sheet Numbering' option to the System - Projects Panel page of the Preferences dialog and the General settings of the Projects panel. |
| 44839 | An ECO does not pass the component classes to the PCB. |
| 45097 | Slow peRF ormance when panning while actively placing an object. (BC:16091 ) |
| 41189 | The Component Cross Reference Report in an outjob does not auto update when changes are made to the PCB. |
| 42887 | When using the Component Class Generator in the Object Class Explorer dialog, Non-Members are not added to Members. (BC:5219 ) |
| 43820 | Online and batch DRC displays violations for Differential Pairs Routing for 'Actual Width' versus 'Target Width'. |
| 44336 | Added a warning about the presence of shelved polygons before generating outputs. (BC:7214 ) |
| 44345 | Enhanced the performance speed of the PCB panel when selecting Nets, DiffPairs and xSignals. |
| 44444 | The Via name is blank when the via type is updated to a microvia. |
| 44714 | Silk to Solder Mask Clearance DRC does not respect 'Solder Mask From The Hole Edge' option for vias. (BC:11551 ) |
| 44733 |  |
| 44744 | Added the 'Show <component name> in <space name>' command to the right-click menu of the Component Actions sub-menu. |
| 44809 | In the Component Rule Check, Keepout primitives in footprints are treated as unconnected with 'Unconnected Copper' warnings. |
| 44831 | The Layer Stack Visualizer is missing from the Tools menu in the Layer Stack Manager editor. (BC:15724 ) |
| 44836 | Error occurred when using the File > Fabrication Outputs > IPC-2581 command. |
| 44851 | Added an option in the Advanced Settings dialog that allows disabling of the auto-renaming of polygons. |
| 44869 | Error occurred when saving a document if there was a component clearance violation. |
| 44888 | PCB 3D Print crops every 3D object that is outside the board boundary. (BC:203 ) |
| 45054 | There was a performance delay when moving several components with parameters when the Properties panel is open. |
| 45089 | After saving the Layer Stack Manager to the PCB, stiffener layers are changed to core layers. (BC:16099 ) |
| 45256 | Added the PCB.Component.AnyLayerPlacement option to the Advanced Settings dialog that restores the ability to place PCB components on any layer. (BC:16253 ) |
| 45426 | Polygon repouring did not work correctly in hatched polygons in rigid-flex designs. (BC:16192 ) |
| 45439 | The Board Outline Clearance design rule option was not respected in certain solder mask and paste mask layers. |
| 45462 | Solder mask and paste mask layers were not present in gerber files when rigid flex was used. (BC:16349 ) |
| 45473 | Only unique solder masks and paste masks will be generated on separate layers, while standard solder masks and paste masks will be generated on the same. |
| 45477 | Only unique solder masks will be generated in order to separate ODB++ layers. |
| 45483 | After changing the diameter of a via, the clearance violation is not detected with online or batch DRC. |
| 41439 | Layer settings, colors and grids were not properly transferred for newly created Footprints when using a Template (BC:13639 ) |
| 44239 | If a custom filename was used in an outjob file, the filename did not always follow the filename settings. |
| 44597 | The local project folder path is not updated when a project is renamed and reopened. |
| 44639 | The error "Server did not recognize the value of HTTP Header" was displayed after clicking "Use local file name" if the project was renamed. |
| 44843 | Investigate BOM generation performance when design components are from SQL DBLib. |
| 44945 | It was not possible to select a BOM template from a folder in the Reports Manager when connected to a server. (BC:15932 ) |
| 44999 | Added a 'Remove from project' decision dialog that allows you to choose how to remove a document. (BC:15822 ) |
| 45039 | All rows in a BomDoc are collapsed when the document is opened after starting altium  Designer. |
