# |& J% E! R) T一、简介8 F( b C* C* h6 }3 _
如今,果农为了保证水果销售利益最优化,会根据水果品相、大小分为不同等级,以此进行包装出售。传统的人工以目测检测为主,效率较为低下,人为误测大,不能够很好地评价水果质量。
! Q1 @' j: k2 z( c# c* a% }该博客基于matalb GUI界面的水果分级系统,该系统适用范围以圆形水果为准,比如橘子,龙眼等,以统计水果的直径、色泽等多参数进行评价。该系统带一个GUI界面,通过设置直径与色泽,测试水果的这些参数,从而得出该水果所属的等级。" m. l2 L0 G8 m4 s
; ~ W) Z/ w+ [2 x( }% @$ F
二、源代码
& c7 S. |# [- h+ i( s- function varargout = myself(varargin)
- % MYSELF MATLAB code for myself.fig
- % MYSELF, by itself, creates a new MYSELF or raises the existing
- % singleton*.
- % H = MYSELF returns the handle to a new MYSELF or the handle to
- % the existing singleton*.
- % MYSELF('CALLBACK',hObject,eventData,handles,...) calls the local
- % function named CALLBACK in MYSELF.M with the given input arguments.
- % MYSELF('Property','Value',...) creates a new MYSELF or raises the
- % existing singleton*. Starting from the left, property value pairs are
- % applied to the GUI before myself_OpeningFcn gets called. An
- % unrecognized property name or invalid value makes property application
- % stop. All inputs are passed to myself_OpeningFcn via varargin.
- % *See GUI Options on GUIDE's Tools menu. Choose "GUI allows only one
- % instance to run (singleton)".
- % See also: GUIDE, GUIDATA, GUIHANDLES
- % Edit the above text to modify the response to help myself
- % Last Modified by GUIDE v2.5 14-May-2020 13:04:33
- % Begin initialization code - DO NOT EDIT
- gui_Singleton = 1;
- gui_State = struct('gui_Name', mfilename, ...
- 'gui_Singleton', gui_Singleton, ...
- 'gui_OpeningFcn', @myself_OpeningFcn, ...
- 'gui_OutputFcn', @myself_OutputFcn, ...
- 'gui_LayoutFcn', [] , ...
- 'gui_Callback', []);
- if nargin && ischar(varargin{1})
- gui_State.gui_Callback = str2func(varargin{1});
- end
- if nargout
- [varargout{1:nargout}] = gui_maiNFCn(gui_State, varargin{:});
- else
- gui_mainfcn(gui_State, varargin{:});
- end
- % End initialization code - DO NOT EDIT
- global d1v1 d1v2 d1v3 d2v1 d2v2 d2v3 d3v1 d3v2 d3v3
- % --- Executes just before myself is made visible.
- function myself_OpeningFcn(hObject, eventdata, handles, varargin)
- % This function has no output args, see OutputFcn.
- % hObject handle to figure
- % eventdata reserved - to be defined in a future version of MATLAB
- % handles structure with handles and user data (see GUIDATA)
- % varargin command line arguments to myself (see VARARGIN)
- % im=imread('apple1.jpg');
- % axes(handles.axes1);
- % imshow(im);%在坐标axes1显示原图像/ D0 v# Q h0 D/ t9 h+ ]9 V2 H5 Q
( S' i" V0 G( F7 b6 f' E- ? m+ j
l# I' ?4 \- L5 z
三、运行结果
+ L& x; z. ?; S
( j% O9 e7 h6 O" w* S+ G9 u) v" h0 ]
