查看: 952|回复: 7
AD19设计的文件可以用Ad16打开吗?
发表于 2021-6-18 14:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
AD19设计的文件可以用Ad16打开吗?; ?& L# C9 v+ Z- m3 m/ S5 p% N
发表于 2021-6-18 15:16 | 只看该作者
高版本可以兼容低版本,但是低版本不能兼容高版本,所以可以打开的
????????  详情 回复 发表于 2021-6-18 16:06
发表于 2021-6-18 16:06 | 只看该作者
ExxNEN 发表于 2021-6-18 15:16! H. ?, Q( O+ a
* F( B$ {' V6 R. B' g
8 ]4 L. s: |- x3 `
发表于 2021-6-19 10:48 | 只看该作者
应该打开文件,因为根据文档 AD19 文件格式没有改变:
$ I: P+ O* e# \: |0 CFile Format (PCB):+ u0 u9 h" k8 j- {
PCB Binary Version 6.0 - select to save the current PCB document in PCB Binary version 6.0 format supported by Altium Designer 6.3.$ u! F" e" B7 |1 ?4 C3 [$ o: _
PCB Binary Version 5.0 - select to save the current PCB document in PCB Binary version 5.0 format supported by Altium Designer.
2 v7 b: d! a; c0 P0 ^0 VPCB Binary Version 4.0 - select to save the current PCB document in PCB Binary version 4.0 format supported by Protel 99SE. The features introduced in Altium Designer will be lost in this format.
& r$ @+ K3 I/ b7 Q/ WPCB Binary Version 3.0 - select to save the current PCB document in PCB Binary version 3.0 format supported by Protel 98 and onwards. The features introduced in Altium Designer will be lost in this format.
% `/ V! M' N& rPCB ASCII Version 5.0 - select to save the current PCB document in PCB ASCII version 5.0 format.+ C6 L, H" ?9 Y' a6 t
发表于 2021-6-24 13:44 | 只看该作者
19可以開16
; ?4 W3 g5 _; e0 W' O16不能開19
GMT+8, 2025-10-26 21:46 , Processed in 0.156250 second(s), 24 queries , Gzip On.
