# z5 N0 u* v, N4 q一、简介
3 h6 F) [5 X. W* L- \/ O* T3 ^( H课题介绍- ^0 d* P' A5 a+ \7 M
本设计为基于MATLAB的人民币识别系统。带有一个GUI界面。先利用radon进行倾斜校正,根据不同纸币,选择不同维度的参数识别纸币金额,有通过RGB分量识别100元;
5 G% T6 A+ O9 P- y
+ S, {6 O8 U( I, r+ e通过面额图像的宽度识别1元、5元;通过构建矩形结构体识别10元 ;通过RGB分量识别 20元 与 50元。
* c9 r6 t- }% O1 Z a3 A
( [7 [2 y& O" V3 O3 X& E2 m% g) s
1 e, [/ P; n# B) b% y) s8 F4 P) ^" m$ W
. A+ g( E/ }4 [6 W- Z; o9 b0 O
二、源代码
) X0 P1 M0 }2 `$ H- o y" X
, h# S8 x/ |/ t) ^% O- function varargout = main(varargin)
- % MAIN MATLAB code for main.fig
- % MAIN, by itself, creates a new MAIN or raises the existing
- % singleton*.
- % H = MAIN returns the handle to a new MAIN or the handle to
- % the existing singleton*.
- % MAIN('CALLBACK',hObject,eventData,handles,...) calls the local
- % function named CALLBACK in MAIN.M with the given input arguments.
- % MAIN('Property','Value',...) creates a new MAIN or raises the
- % existing singleton*. Starting from the left, property value pairs are
- % applied to the GUI before main_OpeningFcn gets called. An
- % unrecognized property name or invalid value makes property application
- % stop. All inputs are passed to main_OpeningFcn via varargin.
- % *See GUI Options on GUIDE's Tools menu. Choose "GUI allows only one
- % instance to run (singleton)".
- % See also: GUIDE, GUIDATA, GUIHANDLES
- % Edit the above text to modify the response to help main
- % Last Modified by GUIDE v2.5 29-May-2020 00:04:07
- % Begin initialization code - DO NOT EDIT
- gui_Singleton = 1;
- gui_State = struct('gui_Name', mfilename, ...
- 'gui_Singleton', gui_Singleton, ...
- 'gui_OpeningFcn', @main_OpeningFcn, ...
- 'gui_OutputFcn', @main_OutputFcn, ...
- 'gui_LayoutFcn', [] , ...
- 'gui_Callback', []);
- if nargin && ischar(varargin{1})
- gui_State.gui_Callback = str2func(varargin{1});
- end
- if nargout
- [varargout{1:nargout}] = gui_maiNFCn(gui_State, varargin{:});
- else
- gui_mainfcn(gui_State, varargin{:});
- end
- % End initialization code - DO NOT EDIT
- % --- Executes just before main is made visible.
- function main_OpeningFcn(hObject, eventdata, handles, varargin)
- % This function has no output args, see OutputFcn.
- % hObject handle to figure
- % eventdata reserved - to be defined in a future version of MATLAB
- % handles structure with handles and user data (see GUIDATA)
- % varargin command line arguments to main (see VARARGIN)
- % Choose default command line output for main
- handles.output = hObject;
- % Update handles structure
- guidata(hObject, handles);
- % UIWAIT makes main wait for user response (see UIRESUME)
- % uiwait(handles.figure1);
- % --- Outputs from this function are returned to the command line.
- function varargout = main_OutputFcn(hObject, eventdata, handles)
- % varargout cell array for returning output args (see VARARGOUT);
- % Get default command line output from handles structure
- varargout{1} = handles.output;
- % --- Executes on button press in pushbutton1.
- function pushbutton1_Callback(hObject, eventdata, handles)
- % hObject handle to pushbutton1 (see GCBO)
- %% 图像读取
- [filename, pathname] = uigetfile({'*.jpg;*.tif;*.png;*.gif','All Image Files';...
- '*.*','All Files' });
- l = imread([ pathname,filename]);
- axes(handles.axes1)
- imshow(l);
- title('原始图像')
- l1=rgb2gray(l); %将真彩色图像转换为灰度图像
- bw1=edge(l1,'sobel', 'both'); %采用sobel算子进行边缘检测
- handles.bw1=bw1;
- theta=0:179; %定义theta角度范围
- r=radon(bw1,theta); %对图像进行Radon变换
- %%%%%检测Radon变换矩阵中的峰值所对应的列坐标%%%%
- [m,n]=size(r);
- c=1;
- for i=1:m
- for j=1:n
- if r(1,1)<r(i,j)
- r(1,1)=r(i,j);
- c=j;
- end
- end
- end
- rot=90-c;
- pic=imrotate(l,rot,'crop'); %对图片进行旋转矫正
- handles.pic=pic;
- pic_gray=rgb2gray(pic); %转换为灰度图像
- handles.pic_gray=pic_gray;
- pic_a=imadjust(pic_gray,[0,0.001],[1,0]); %明暗反转
- pic_b=1.3*pic_gray+0.7*pic_a;
- pic_c=imadjust(pic_b,[0.5,1],[0,1]); %明暗反转
- handles.pic_c=pic_c;
- pic_b_edge=edge(pic_c,'sobel'); %采用sobel算子进行边缘检测
- handles.pic_b_edge=pic_b_edge;
- se=[1;1;1]; %线型结构元素
- pic_imerode=imerode(pic_b_edge,se); %腐蚀图像
- handles.pic_imerode=pic_imerode;
- se=strel('rectangle',[60,60]); %矩形结构元素
- pic_imclose=imclose(pic_imerode,se); %图像聚类、填充图像
- handles.pic_imclose=pic_imclose;
- pic_bwareaopen=bwareaopen(pic_imclose,10000); %去除聚团灰度值小于10000的部分
- %%%%%求纸币行起始位置和终止位置%%%%%
- [y,x]=size(pic_bwareaopen);
- I6=double(pic_bwareaopen);
- Y1=zeros(y,1);
- for i=1:y
- for j=1:x
- if(I6(i,j,1)==1)
- Y1(i,1)= Y1(i,1)+1;
- end
- end
- end
- [temp MaxY]=max(Y1);
- %%%%%%求纸币列起始位置和终止位置%%%%%
- PY1=MaxY;
- while ((Y1(PY1,1)>=50)&&(PY1>1))
- PY1=PY1-1;
- end
- PY2=MaxY;
- while ((Y1(PY2,1)>=50)&&(PY2<y))
- PY2=PY2+1;
- end
- IY=pic(PY1:PY2,:,:);
- X1=zeros(1,x);
- for j=1:x
- for i=PY1:PY2
- if(I6(i,j,1)==1)
- X1(1,j)= X1(1,j)+1;
- end
- end
- end
- %%提取并画出背景中的RMB图像%%
- PX1=1;
- while ((X1(1,PX1)<3)&&(PX1<x))
- PX1=PX1+1;
- end
- PX2=x;
- while ((X1(1,PX2)<3)&&(PX2> PX1))
- PX2=PX2-1;
- end
- dw=pic(PY1:PY2,PX1:PX2,:);
- dw_gray=rgb2gray(dw);
- dw_gray=imadjust(dw_gray,[0,1],[1,0]);
- dw_bw=im2bw(dw_gray);
- handles.dw_bw=dw_bw;
- %%分割提取RMB数值图像%%
- [m,n]=size(dw_bw);
- m1=round(m/3);
- m2=round(2*m/3);
- n1=round(n/6);
- n2=round(n/3);
- n3=round(2*n/3);
- n4=round(5*n/6);
- sum1=sum(sum(dw_bw(m1:m2,n1:n2)));
- sum2=sum(sum(dw_bw(m1:m2,n3:n4)));
- if sum1>sum2
- dw=imrotate(dw,180,'crop');
- end
- %%图像处理%%
- x=dw;
- x1=imresize(x,[236,500]);%'缩放图像
- 关闭
- z=imcrop(x1,[270,150,160,65]);%对图像进行剪切,选取有效区域7 R! C! }# V E* p$ m
- I=imcrop(x1,[130,60,130,65]); %对图像进行剪切,选取有效区域
- handles.I=I;
- I1=rgb2gray(I); %转换为灰度图像
- I2=medfilt2(I1); %滤波默认窗口
- I3=imadjust(I2,[0.3,0.5],[0,1],1); %明暗反转
- I4=im2bw(I3);
- handles.I4=I4;
- se=strel('rectangle',[3,3]); %构造结构函数,以长方形构造一个se. D* s5 N, |# O- q9 ^- A4 l6 H$ u
4 g9 @ Z$ g8 ]% ~9 D1 \" M( x( N3 c- w. T4 V
三、运行结果4 x1 s5 ?6 T5 T1 \
# Q( b+ t4 t! W3 B: a
$ A s: B4 j! J6 I* S- k |
