最近在做有关FPGA的仿真,在ISE中约束管脚和电平后,生成IBIS模型,可是仿真时出问题,拓扑结构能够提取出来,但是仿真时提示"cycle.msm does not exist"tlsim里面内容如下:8 k: _& u& E4 L, @ l
**** Tlsim command line ****
3 S7 W* b* I* U3 |% _ tlsim -e 2.000000e+001 -r 0.200000 -o waveforms.sim -dl delay.dl -dst distortion.dst -log tlsim.log -ocycle cycle.msm main.spc
, c4 E/ v8 F! S2 V$ g2 i2 i: H6 i( \7 @; O/ p: O* h" w
*********************************************************( y/ e: T- f0 ?9 }' W ]
Failed To Compile SubCircuit xUHF==RECEIVER_icn_ckt 1 UHF==RECEIVER_icn_ckt! v5 Z' f0 u% e; i* ^4 D
2 q% C6 b) f0 h* t8 N% P% O1 k6 ~4 \* _6 Q
*********************************************************5 ^7 l$ \) Q$ }/ o
. I+ Y; H5 J8 k" {" K( w; T, e' h*********************************************************
9 s9 g6 w G3 }3 h& z# |* r% g ABORT:The Circuit is Empty
! K K# b, R; V# W8 c/ f& u: ^+ l& \4 r
5 r1 ]" @2 F0 c. F$ [9 v- g: N3 [* O. [ k7 [
+ ?$ g" f+ ~' W' _8 n在audit所仿真的网络时,有错误:
8 [+ y) Y& q- T/ F6 U P) c5 PERROR >> Pin(s) with conflict between PINUSE property5 d9 o0 v9 [7 F' u; z
and signal_model parameter in IbisDevice pin map :% Z2 @$ B. p, [! e# C+ O
Pin Component Pin Use Signal Model Design
8 C) ] ?* ~4 l$ A+ v --- --------- ------- ------------ ------2 W' C6 Y4 J0 V. ^6 _5 D: P
B4 U11 NC SPARTAN6_PINASSIGN_LVDS_33_TB_25 UHF==RECEIVER
+ O; q6 A1 B- K3 j* w
! z, J- H( q; `! K4 M8 I' h: X$ t* e" I
请各位大侠帮忙!!!多谢!!!8 Q1 w- L* G& C
