查看: 834|回复: 3
矩阵维度不一致问题
发表于 2021-5-17 11:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在运行Laplace score的例子0 ]2 I8 w; k$ U/ j
idAOccur = find( A == idA );
, s0 `$ M  r+ v/ |6 X0 _9 i  ?" \这个单独运行没问题
/ {$ w" U7 e) r  e- N1 z/ ?但是处在' t3 p9 D/ a3 m- L4 ]
function qw = qq( A, B )
. `- U& C0 D; N* u1 }if length( A ) ~= length( B)
$ R0 ^* I- h; z! Q8 q2 r    error('length( A ) must == length( B)');; }, _, x" a: d" G. ^) c& A$ W# D
end
- Q1 S. u/ v7 k4 Itotal = length(A);/ H$ F  n% I) {6 R$ }& E
A_ids = unique(A);2 a8 l/ ]9 }# [) _" w
B_ids = unique(B);
& j  k' N0 d( s# Q9 Y- nMI = 0;
2 |. @8 ?0 h7 {for idA = A_ids
/ D: X; [0 B! C( Q) V    for idB = B_ids
' E9 x, L, Q! A9 b         idAOccur = find( A == idA );7 O$ o$ I# u& K" {& X( i9 A  {
, y6 y; |4 \4 E          % eps : the smallest positive number* o; `7 T/ y7 Q! j8 k
    end  p$ C- r% s* T: w1 h9 H" C) p. E
end$ I# c! u# x% u  y2 L; |
qw=MI# |9 q' I+ ?) f- k0 Z$ W
end( A) ^3 X$ A4 l) H
就会出现在这行idAOccur = find( A == idA );的错误,即表现在矩阵维度必须一致上
0 \/ d  f5 E) x! H' ^5 ?
    2022-12-27 15:46
  • 签到天数: 4 天
    [LV.2]偶尔看看I
    发表于 2021-5-17 13:18 | 只看该作者
    A=[1 2 3 4 5 6 7 8 9];3 q& @! ?5 {5 u/ F. @8 O/ P  w
    B=[2 5 4 8 7 9 6 3 4];
    , V; ?; \0 }0 V2 a% Laa=qq( A, B )
    ) w+ \4 L$ y/ l
    # z9 N% g- P" U5 h6 ]function qw = qq( A, B ). H3 P+ X9 i: Z* c& l8 V4 u; F9 \
    # X1 k4 e' M1 F4 h& c6 s    error('length( A ) must == length( B)');5 v6 T6 S' o& z; Z( }. K
    end
    # e: I) n2 d. i: ?# n; J4 Y" xtotal = length(A);5 M8 K& @" C$ S
    A_ids = unique(A);/ n" k7 v: H" o
    B_ids = unique(B);
    ; c; S; t! {) G4 Q# AMI = 0;
    4 P$ T8 l8 D) C9 Yfor idA = A_ids; O% b, T& {0 `: A- Q
        for idB = B_ids
    7 ^) r2 I8 y6 b         idAOccur = find( A == idA );( K  c6 I5 S9 A7 @% O/ n
    ; a. X2 ]2 ?5 q  y          % eps : the smallest positive number5 N$ W0 J) D4 _, G: q) z8 K
        end3 B$ o- G! I1 X$ h( t; G( U4 Z& F
    end1 I* r' D0 ?# u0 W' H
    qw=MI3 k2 X1 b5 C% R' D: w' I
    end
    $ z4 o+ f& h, }3 f7 t* s; L  U7 D2 _运行正常,不知道是不是这样的,没有报错
    慵懒
    2022-12-26 15:28
    发表于 2021-5-17 13:44 | 只看该作者
    我也来看看,涨涨知识
    GMT+8, 2025-10-29 22:15 , Processed in 0.140625 second(s), 23 queries , Gzip On.
