[ComponentDefinitionProps]
3 J# [6 N" H! i% T# f" q' TALT_SYMBOLS=YES
0 ]; t9 P, K4 S$ V: RCLASS=YES8 u/ H9 {, q6 q: C
PART_NUMBER=YES4 O; h! o+ o( p6 g; F' s
TOL=YES
9 r2 R3 G" w4 K7 P9 i9 g" [* \- vVALUE=YES5 c; J0 i$ o! j- n6 V5 B, v
POWER_GROUP=YES
0 A( Z( `. o) l& WSWAP_INFO=YES
/ w! |$ c8 f" G7 v- D. E; r
* E/ d9 x0 m0 `5 z$ ?[ComponentInstanceProps]7 m$ R3 q& X4 j
GROUP=YES
! i! B+ o m$ ]7 Y& R) C& SROOM=YES
6 Q: y/ |& j+ X% p/ V" mVOLTAGE=YES4 A- J7 B- }( W- ?9 F
FSP_LIB_PART_MODEL=YES
3 e/ g" ]6 y; l" |! `, T" eFSP_IS_FPGA=YES% b* ]2 K3 W9 Y+ p0 N+ G' Q/ _
FSP_INSTANCE_NAME=YES1 q1 ]; {+ E* z8 J C. V o- F: C- f
FSP_INSTANCE_ID=YES
: ~, A) u. E D; c1 a( }, }# R3 P8 Q; [" m3 I0 F( E
[netprops]) ? z1 q' e2 Y+ @2 b0 }
ASSIGN_TOPOLOGY=YES
# W9 f" T$ l( k. ]5 H' \* sBUS_NAME=YES7 M5 i7 D+ r7 p6 B3 X
CLOCK_NET=YES
a, I# Y% }" V( r; TDIFFERENTIAL_PAIR=YES' D# _5 f) ^0 K4 m1 @. P
DIFFP_2ND_LENGTH=YES
% L( G( A$ q$ X) x/ [: ^0 B' d- {DIFFP_LENGTH_TOL=YES
' b2 G+ w$ E. Y4 H% d6 w; z7 v6 ~ECL=YES! A$ U& q% F# D; a& B! p
ECL_TEMP=YES. _0 q. T: C9 K6 f U6 x
ELECTRICAL_CONSTRAINT_SET=YES* p9 i; R' z* a' ^2 X) S6 n5 x5 X
EMC_CRITICAL_NET=YES
1 l+ p$ H4 `0 IIMPEDANCE_RULE=YES$ h) a' G" z7 O
MATCHED_DELAY=YES
2 W1 M u+ ]5 ~. k. {MAX_EXPOSED_LENGTH=YES: o L2 ?9 s: v5 H
MAX_FINAL_SETTLE=YES
0 D5 d3 q1 c% m" hMAX_OVERSHOOT=YES
, L6 P' t0 l) V! W, pMAX_VIA_COUNT=YES
j& O$ k; C+ X |' j$ ]MIN_BOND_LENGTH=YES
1 O: U7 b) c3 {+ b+ sMIN_HOLD=YES
0 p5 E( }; X: W% E5 u: J4 `6 jMIN_LINE_WIDTH=YES/ _" x9 |% E- i
MIN_NECK_WIDTH=YES
+ Q2 a6 P4 P8 H# A% U+ JMIN_NOISE_MARGIN=YES
; Y4 d) q1 v0 z* m( }MIN_SETUP=YES5 S# j% J. u0 A! y
NET_PHYSICAL_TYPE=YES
, R) w& s( z& z# G% ZNET_SPACING_TYPE=YES' x) r; F2 Z9 c) P
NO_GLOSS=YES/ M) I0 @) D& L9 a: ~
NO_PIN_ESCAPE=YES S# H) x3 V8 J) c9 \
NO_RAT=YES
8 m2 L8 e; L$ L' o! Y* @; nNO_RIPUP=YES! g4 i! q u& Q+ f7 m$ G' H: n
NO_ROUTE=YES
3 X2 F6 E5 Y- P" M2 ?NO_TEST=YES
' J6 b( k0 ^& ePROBE_NUMBER=YES i2 r1 t8 d6 |& \1 Q" C$ q
PROPAGATION_DELAY=YES' W+ W0 [' E/ s' ~, o$ S
RELATIVE_PROPAGATION_DELAY=YES
* _" l8 ?: h6 W3 VRATSNEST_SCHEDULE=YES6 ]: Y* m4 g& \) |+ m! L' w
ROUTE_PRIORITY=YES
8 g( _4 O9 p" b$ ^8 s% zSHIELD_NET=YES5 n& l+ V$ e% p2 I2 P; `2 n
SHIELD_TYPE=YES
4 o$ p ?2 T0 qSTUB_LENGTH=YES6 s8 l8 B3 E& G3 A8 U0 L6 H& O
SUBNET_NAME=YES
# X a( p; ?/ ]" y. xTS_ALLOWED=YES/ c) d) K. o# a$ L
VOLTAGE=YES
( u9 B% Y' M# N L; P, A) n: rVOLTAGE_LAYER=YES
8 ~" \" S0 R9 N& a' BFSP_NET=YES
0 v: ~- y' V% [FSP_BUS_INDEX=YES
1 N" G- g3 A4 ~- a% Z
k; D% ?( Q7 m[functionprops]
" l! c L. K+ q% |1 ^1 OGROUP=YES
6 X* t5 g: x5 Y8 n1 `! AHARD_LOCATION=YES
6 q& `1 B0 p: Q" O$ c3 }; aNO_SWAP_GATE=YES, T4 Y l/ z7 C: W
NO_SWAP_GATE_EXT=YES; v5 }" G6 m: P) ~
NO_SWAP_PIN=YES
# }2 Y8 ?) O7 f, l8 u+ O( gROOM=YES: Y# n2 U2 s* ]
- n3 K! h# ^; @0 M. e
[pinprops]/ z+ n6 j( ~" D3 m3 O/ I" l
NO_DRC=YES" h0 p& Q8 b9 f, }# x. ?/ p/ |' g
NO_PIN_ESCAPE=YES- g! K! [" a' d% W6 |, ]
NO_SHAPE_CONNECT=YES, N# L* `+ D! U2 b+ t+ C
NO_SWAP_PIN=YES
1 c7 Y$ p/ d, ~: R; B* L' NPIN_ESCAPE=YES |
