TA的每日心情 | 开心 2022-5-9 15:00 |
签到天数: 28 天 [LV.4]偶尔看看III
Features2 s& `' z+ m. ^9 [/ x! o
& ~+ k( N7 b7 U2 B* g4 [6 e5 ^* H) q! v
Wide Input Voltage Range from 4V to 36V
- X: D# |+ g+ U+ l" l / J, I9 x* a- i# o! E4 w" T
Programmable VOUT Range from 0.8V to 24V% L g K' Y4 o: @% W+ b
# J, a v9 z( D
Peak Current Mode Control& S& s+ v6 R5 q7 q
6 c' g% }& s2 B @4 A
Integrated 6V/3A Peak Gate Drive
' w' F: Y2 Z- x; q $ z: X) t/ ~+ x& ^2 B# |6 @0 Z2 O" W
Adjustable Cycle-by-Cycle Current Limit by ILIM6 ~, ^* P+ k4 Y" i O# G7 y
( B, y" E2 \! g: i
Adjustable Frequency: 100kHz~1MHz- J# C* d- D$ H; L: ^2 L
0 d' N7 Q1 X+ u1 V
External Soft-Start Limits the Input Inrush Current
: s/ C7 L4 B4 D# J! v5 j& b1 T2 l ( K* g. X! }' U2 s( H
Internal PMOS Driver for Bypass Mode
/ ?, E" {2 V, f9 R5 M- g- f N6 I1 s) Q& n
Selectable FCCM or DCM with Pulse Skipping ]) n3 D% o9 N% ~
; R) ~, [( y$ ~1 k" }5 MCable Impedance Compensation
/ e6 ?2 R5 t3 Y , S' A2 h0 n( R
Low Dropout Operation with Maximum Duty . w4 j2 [# C+ W
Cycle at 99.5%% P5 F& h4 M T: e$ z
3 H; X! q5 ?4 R2 Z7 e: j, A
I2C Programmable Output Range from 3.0V to
' P6 p0 n8 _$ w* c; _6 {21V in 200mV Per Step. @' q& ^. r$ P# R/ g2 |! I
) s/ j0 S" x% oInput Under-Voltage Lockout
1 i' u3 z1 s+ ?2 | 1 \4 ]( J4 p3 @ J. F/ e7 D
Output OCP, SCP, OVP
C$ ?/ z/ g* ]+ ]2 d( B ( R% N9 a! d% U% I( F
Thermal Shutdown6 ]; b. q' a( D _4 E8 z* ?
) J' s! T. j9 x; s
QFN-20 Package, 3mm×3mm×0.75mm
3 a2 O# c2 k* B6 F7 JDescription7 g6 j/ p2 K% V2 j" [' f. K: t
The ZCC7200 is a synchronous buck controller mainly
5 U0 T& I! k$ q$ |0 H: P+ q7 e" sfor widely varying input step-down regulator9 z B* c6 J; X& G* N1 M4 X: S
applications. The control method is based upon
' g0 _/ Y4 z* `# e% T6 {5 {% P% ]current mode control that enables maximum
4 j1 f5 E" Z3 @) upeRFormance under transient conditions. The output 2 o a: |* z3 w
voltage can be either programmed by the FB pin or
: V& R" K. O+ w2 P" Zconfigured by the I2C interface from 3.0V to 21V in , A; h* \ }3 k# O
200mV per step. It operates as a Buck mode while
5 ]: v0 ]7 n# nthe input voltage is sufficiently greater than the
4 A! m4 I- k; [$ ]2 n# I$ w. iregulated output voltage and transitions to the bypass; y9 N3 F: ~+ s# Z1 g3 o
mode as the input voltage very approaches the output2 R0 ~$ _! K7 Y5 `
voltage. It also features an adjustable soft-start
" j% u# Q- }9 p! g1 ^function and offers protection features including input . K [$ W9 Y% T, s( D
UVLO, cycle-by-cycle current limit, output overload
' ?! |: G6 s/ \9 N2 w* ?protection (OLP) or OVP and thermal shutdown. In
) G' h4 q, _" `1 Z4 h3 Taddition, it features selectable Forced Continuous
s; Q k, Y6 m3 l# ~6 pConduction Mode (FCCM) or Discontinuous
" j1 [5 _9 V! |+ B1 qConduction Mode (DCM) operation for light load.* A; ?" ^/ _- E! a
The ZCC7200 integrates an I2C compatible interface 1 P- x0 ?' B: E0 _
for bypass mode selecting, output voltage setting, etc.
8 i: a4 |. K1 b7 j! B- WThe ZCC7200 is available in compact QFN3x3-20
6 ~/ {, D( X# [% l N: _) q) w& a$ [# i9 d- Q/ o2 ^
I2C口同步降压100W输出-ZCC7200(2).pdf
(1.85 MB, 下载次数: 0)
; @0 [2 i3 m" o9 [4 v/ ?* T
+ B3 o- B0 S" ~* J! m9 N' i R) E |
