大家好 我是orcad 新手 我这里有个电路 仿真不出来 总提示错误
2 T4 ]& D3 w. d+ c
5 s+ J- I- x2 ]7 g**** RESUMING 12-1.cir ****( B8 |8 M2 ~5 |' f/ m
.END
8 Z4 s/ X# ]2 P7 V. L: @ERROR -- Less than 2 connections at node N19324% l. c; r" ^' \# V; B9 g
ERROR -- Less than 2 connections at node N19421* _, m# b8 E# M3 P
ERROR -- Less than 2 connections at node N18550+ T6 I" y: n |0 K
ERROR -- Less than 2 connections at node N18825 E$ p0 I. r$ o5 G% g- p
ERROR -- Node N15285 is floating
+ g# x S" b3 J }, J$ oERROR -- Node N14723 is floating
8 e* n9 p' q% h# i9 U; c3 mERROR -- Node N14712 is floating
( e4 ^9 v/ d( t2 m( NERROR -- Node N19324 is floating$ [% K$ M; A2 I" k( J0 l2 _# T3 [
ERROR -- Node N14756 is floating
1 |# d; e7 n! t3 e$ L/ o+ b6 mERROR -- Node N14891 is floating0 M" h% }! C4 B3 R8 R' G8 p
ERROR -- Node N15211 is floating
' `# b8 m0 B: z$ e9 OERROR -- Node N19421 is floating
- G3 a8 |* e7 W# hERROR -- Node N18550 is floating) k, o( e9 W& o/ {$ \. B
ERROR -- Node N18825 is floating. ]- g5 s( ]4 ?1 p- v: T) ~. l
' c0 R' E6 L- M1 [# ~9 ]1 k我的MOSFET 和 DIODE 没有设置什么 不知道是不是因为这个 不知道如何设置 : p0 Z: C% k* v0 z! U
看网上有说要设这Edit Pspise Model 可是我的这个 Edit Pspise Model 点不了" v/ L8 H% j0 C9 e5 y+ D% T" P8 @, A @. b
, f. B, n. u' m: [# g' t* X
恳请哪位大神能帮忙解决一下~~~
$ f& r0 L6 M7 _- r$ W5 R |
