! q& Q. ^, z, S% D# x- m
一、源代码
* k7 @, l/ c7 ~ A- function varargout = homework2(varargin)
- % HOMEWORK2 M-file for homework2.fig
- % HOMEWORK2, by itself, creates a new HOMEWORK2 or raises the existing
- % singleton*.
- % H = HOMEWORK2 returns the handle to a new HOMEWORK2 or the handle to
- % the existing singleton*.
- % HOMEWORK2('CALLBACK',hObject,eventData,handles,...) calls the local
- % function named CALLBACK in HOMEWORK2.M with the given input arguments.
- % HOMEWORK2('Property','Value',...) creates a new HOMEWORK2 or raises the
- % existing singleton*. Starting from the left, property value pairs are
- % applied to the GUI before homework2_OpeningFcn gets called. An
- % unrecognized property name or invalid value makes property application
- % stop. All inputs are passed to homework2_OpeningFcn via varargin.
- % *See GUI Options on GUIDE's Tools menu. Choose "GUI allows only one
- % instance to run (singleton)".
- % See also: GUIDE, GUIDATA, GUIHANDLES
- % Edit the above text to modify the response to help homework2
- % Last Modified by GUIDE v2.5 20-May-2013 21:21:00
- % Begin initialization code - DO NOT EDIT
- gui_Singleton = 1;
- gui_State = struct('gui_Name', mfilename, ...
- 'gui_Singleton', gui_Singleton, ...
- 'gui_OpeningFcn', @homework2_OpeningFcn, ...
- 'gui_OutputFcn', @homework2_OutputFcn, ...
- 'gui_LayoutFcn', [] , ...
- 'gui_Callback', []);
- if nargin && ischar(varargin{1})
- gui_State.gui_Callback = str2func(varargin{1});
- end
- if nargout
- [varargout{1:nargout}] = gui_maiNFCn(gui_State, varargin{:});
- else
- gui_mainfcn(gui_State, varargin{:});
- end
- % End initialization code - DO NOT EDIT
- % --- Executes just before homework2 is made visible.
- function homework2_OpeningFcn(hObject, eventdata, handles, varargin)
- % This function has no output args, see OutputFcn.
- % hObject handle to figure
- % eventdata reserved - to be defined in a future version of MATLAB
- % handles structure with handles and user data (see GUIDATA)
- % varargin command line arguments to homework2 (see VARARGIN)
- % Choose default command line output for homework2
- handles.output = hObject;
- % Update handles structure
- guidata(hObject, handles);
- % UIWAIT makes homework2 wait for user response (see UIRESUME)
- % uiwait(handles.figure1);
- % --- Outputs from this function are returned to the command line.
- function varargout = homework2_OutputFcn(hObject, eventdata, handles)
- % varargout cell array for returning output args (see VARARGOUT);
- % Get default command line output from handles structure
- varargout{1} = handles.output;
- %载入原始身份证图像的回调函数
- % --- Executes on button press in OriginalImg.
- function OriginalImg_Callback(hObject, eventdata, handles)
- % hObject handle to OriginalImg (see GCBO)
- [FileName,PathName] = uigetfile('*.jpg','Select an image');
- if PathName~=0
- str = [PathName,FileName];
- T=imread(str);
- axes(handles.Img);
- imshow(T);
- end
- %图像自动亮度调整的回调函数
- % --- Executes on button press in autoLight.
- function autoLight_Callback(hObject, eventdata, handles)
- % hObject handle to autoLight (see GCBO)
- T=getimage;
- low_out=0.2; high_out=0.9;
- gamma=1.518;
- hsv=rgb2hsv(T);
- I=hsv(:,:,3);
- minL=min(min(I));
- maxL=max(max(I));
- J=imadjust(I,[minL;maxL],[low_out;high_out],gamma);
- hsv(:,:,3)=J;
- rgb_atuoI=hsv2rgb(hsv);
- axes(handles.Light);
- imshow(rgb_atuoI);
- %图像二值化的回调函数
- % --- Executes on button press in DIP.
- function DIP_Callback(hObject, eventdata, handles)
- % hObject handle to DIP (see GCBO)
- I=getimage;
- [m,n,r]=size(I);%图像的像素为width*height
- %%%%%蓝色字体变黑
- myI=double(I);
- for i=1:m
- for j=1:n
- if((myI(i,j,1)>=15)&&(myI(i,j,1)<=130)&&((myI(i,j,2)<=165)&&(myI(i,j,2)>=90))&&((myI(i,j,3)<=220)&&(myI(i,j,3)>=135))) % 蓝色RGB的灰度范围
- I(i,j,1)=40; %红色分量
- I(i,j,2)=40; %绿色分量
- I(i,j,3)=40; %蓝色分量
- end
- end
- end
- %figure, imshow(I);title('变色后的图像');
- width=round(0.9*n);height=round(0.87*m);
- rx=round(0.05*n);cy=round(0.075*m);
- I=subim(I,height,width,rx,cy);
- %figure,imshow(I);
- if sum(size(I)>0)==3 %倘若是彩色图--2维*3,先转换成灰度图
- I=rgb2gray(I);
- end
- %figure,imhist(I);
- x=3;%行数分为x部分
- y=1;%列数分为y部分
- BW=erzhihua(I,x,y);
- [n m l]=size(BW);%图像的像素为m*n
- c = [0.65*m 0.65*m m m];
- r = [0 0.85*n 0.85*n 0];
- BW = roifill(BW,c,r);
- BW=imadjust(BW);%使用imadjust函数对图像进行增强对比度
- % Convert to BW
- threshold = graythresh(BW);
- BW =~im2bw(BW,0.6*threshold);
- [image_h image_w]=size(BW);
- % Remove all object containing fewer than (imagen/80) pixels
- BW = bwareaopen(BW,floor(image_w/80));
- % 滤波
- %h=fspecial('average',1);
- %BW=im2bw(round(filter2(h,BW)));
- %imwrite(d,'4.均值滤波后.jpg');
- axes(handles.Binary);
- imshow(BW);
- %图像分割与识别按钮的回调函数
- % --- Executes on button press in OCR.
- function OCR_Callback(hObject, eventdata, handles)
- % hObject handle to OCR (see GCBO)
- imagen = getimage;
- [image_h image_w]=size(imagen);
- %figure;imshow(imagen);title('INPUT IMAGE')
- % Convert to gray scale
- if size(imagen,3)==3 %RGB image
- imagen=rgb2gray(imagen);
- end
- %Storage matrix word from image
- word=[ ];
- re=imagen;
- %Opens text.txt as file for write
- fid = fopen('ID_card.txt', 'wt');
- % Load templates
- load templates
- global templates
- % Compute the number of letters in template file
- num_letras=size(templates,2);
- figure;
- plot_flag=1;
- while 1
- %Fcn 'lines' separate lines in text
- [fl re]=lines(re);
- imgn=fl;
- [line_h line_w]=size(fl);%记录下切割出来的一行字符的长宽
- %Uncomment line below to see lines one by one
- % imshow(fl);pause(1)
- % Label and count connected components
- [L Ne] = bwlabel(imgn);
- n=1;%记录循环次数
- while(n<=Ne)
- char_flag=0;%为0时,是第一次判断这个连通域
- flag=1;%初始化两个连通域属于同个字符
- while(flag==1)
- if char_flag==0
- [r,c] = find(L==n);
- Width0=max(r)-min(r);%连通域宽度
- Height0=max(c)-min(c);%连通域高度
- Radio0=Width0/Height0;%连通域宽高比
- Square0=Width0*Height0;%连通域面积
- maxr=max(r);
- maxc=max(c);
- minr=min(r);
- minc=min(c);
- end
- if n<Ne
- [r1,c1] = find(L==(n+1));%寻找下一个连通域
- Width1=max(r)-min(r);%连通域宽度
- Height1=max(c)-min(c);%连通域高度
- Radio1=Width1/Height1;%连通域宽高比
- Square1=Width1*Height1;%连通域面积
- Uheight=max(maxc,max(c1))-min(minc,min(c1));%合并后高度
- Uwidth=max(maxr,max(r1))-min(minr,min(r1));%合并后宽度
- Uradio=Uwidth/Uheight;%合并后的宽高比
- Oheigth=Height0+Height1-Uheight;%重叠高度
- Owidth=Width0+Width1-Uwidth;%重叠宽度
- Osquare=Oheigth*Owidth;%重叠面积
- else
- flag=0;%这是这一行最后一个连通域
- end
- ph=5;%边界因子
- pw=7;
- if(flag==1)&&((Owidth>=-(image_w/pw)&&Owidth<=0)||(Oheigth>=-(line_h*0.3)&&Oheigth<=0))%两个连通域较近,但不重叠
- if((Uradio>=0.8)&&(Uradio<=1.2))%认为两个连通域属于同一个字符
- elseif Uheight<line_h*0.4;%连通域的合并之后高度过小的,认为是一个字符的一部分,很可能是边旁部首
- else flag=0;%否则这两个连通域属于不同字符
- end
- elseif(flag==1)&&(Owidth<-(image_w/pw))%两个连通域里相距较远
- flag=0;%两个连通域属于不同字符
- % elseif(flag==1)&&((Owidth>0)||(Oheigth>0))%两连通域重叠
- elseif(flag==1)&&((Owidth>0))%两连通域重叠
- if(((Uradio>=0.78)&&(Uradio<=1.3)))%认为两个连通域属于同一个字符
- elseif(Osquare>=0.4*min(Square0,Square1)&&(Uwidth<image_w/45))
- else
- end
- else flag=0;%两个连通域属于不同字符
- end
- if flag==1%经过上面判断,两个连通域属于同一个字符,进行连通域合并
- Width0=Uwidth;%连通域宽度
- Height0=Uheight;%连通域高度
- maxr=max(maxr,max(r1));
- maxc=max(maxc,max(c1));
- minr=min(minr,min(r1));
- minc=min(minc,min(c1));
- n=n+1;%指向下一个连通域
- char_flag=1;
- end
- end %while(flag==1)的end
- % Extract letter
- n1=imgn(minr:maxr,minc:maxc);
- % Resize letter (same size of template)
- img_r=imresize(n1,[36 23]);
- subplot(10,10,plot_flag),imshow(img_r);title(plot_flag);
- plot_flag=plot_flag+1;
- %Uncomment line below to see letters one by one
- % imshow(img_r);title(n);pause(0.5)
- % Call fcn to convert image to text
- letter=read_letter(img_r,num_letras);
- % Letter concatenation
- word=[word letter];
- n=n+1;
- end % while(n<=Ne)的end
- %fprintf(fid,'%s\n',lower(word));%Write 'word' in text file (lower)
- fprintf(fid,'%s\n',word);%Write 'word' in text file (upper)
- % Clear 'word' variable
- word=[ ];
- %*When the sentences finish, breaks the loop
- if isempty(re) %See variable 're' in Fcn 'lines'
- break
- end
- end
- fclose(fid);
- %Open 'ID_card.txt' file
- winopen('ID_card.txt')
- % --- Executes on button press in Exit.
- function Exit_Callback(hObject, eventdata, handles)
- % hObject handle to Exit (see GCBO)
- clc;
- close all;
- close(gcf);
3 o5 u5 t9 ?4 ~ ' r/ D( j/ S7 I# E6 d8 W
% k' q; ?' q3 S
0 Q+ c1 h7 c( Z/ z V$ _6 V, X* _1 `& _0 d: ?- h- T
二、运行结果
' Y. z# [ a; a% p# Y( d8 m) i e. s: P# A. {; x& V3 T" A# R1 P7 j( c
" P/ o- X+ q$ y' A1 x
0 N( |; T5 n' s: Y R7 m
) U! ]$ r; b/ z/ @2 H) w9 V" e* N% Y" N( j& E
# r7 a6 p6 A8 w/ w5 b4 K
