查看: 616|回复: 1
基于matlab GUI遗传算法优化求解
发表于 2021-4-12 10:13 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
& I* C. e" \5 r1 E: \3 `
一、简介
. @! e! h% |4 s, A- b1 遗传算法简介
- @" t' b0 u4 k* E8 G4 Y; f3 W遗传算法是一种模拟自然进化的优化搜索算法。由于它仅依靠适应度函数就可以搜索最优解,不需要有关问题解空间的知识,并且适应度函数不受连续可微等条件的约束,因此在解决多维、高度非线性的复杂优化问题中得到了广泛应用和深入研究。
% m: L+ Z6 v6 n. L( P遗传算法在模式识别、神经网络、机器学习、工业优化控制、自适应控制、生物科学、社会科学等方面都得到应用。2 _- G& I. y0 ^4 d/ T: o; r( a
# I! Y& o* }% e; t: E; x7 C
" y0 K4 u6 C1 P$ ]2 遗传算法原理8 ^4 R! w5 e' H2 M/ o8 E: k
5 t: O  z! q& b/ m  Z% n% H/ ]' R1 F- S
* A5 N7 b. I, L- G9 ]. M' Y+ F! P, {, L3 {2 C
4 Q/ m7 \3 f# x- d7 f$ Z
. b9 @$ m- T- N' |. ^' u
, I, [" o! K, t% G- P, v- a" [* |: J4 \# ^: v  r$ P. M
( n8 u0 ]4 e6 x
2 j; B7 n" s! G, v
, Y6 F6 o* e: s4 v/ O* _/ B! X; O2 L6 B4 y( d# A! }/ v
) l3 u& [4 q+ E3 P& `# e% L
7 e  \1 k7 b) l( F5 D. }; d" t8 k1 n9 G
7 O, h5 o- }# q( h7 j二、源代码
! x1 I( A0 N" H; F3 y. z8 X% l  ]( j9 f) X) X/ W
  • function varargout = yichuan(varargin)
  • % YICHUAN MATLAB code for yichuan.fig
  • %      YICHUAN, by itself, creates a new YICHUAN or raises the existing
  • %      singleton*.
  • %      H = YICHUAN returns the handle to a new YICHUAN or the handle to
  • %      the existing singleton*.
  • %      YICHUAN('CALLBACK',hObject,eventData,handles,...) calls the local
  • %      function named CALLBACK in YICHUAN.M with the given input arguments.
  • %      YICHUAN('Property','Value',...) creates a new YICHUAN or raises the
  • %      existing singleton*.  Starting from the left, property value pairs are
  • %      applied to the GUI before yichuan_OpeningFcn gets called.  An
  • %      unrecognized property name or invalid value makes property application
  • %      stop.  All inputs are passed to yichuan_OpeningFcn via varargin.
  • %      *See GUI Options on GUIDE's Tools menu.  Choose "GUI allows only one
  • %      instance to run (singleton)".
  • % See also: GUIDE, GUIDATA, GUIHANDLES
  • % Edit the above text to modify the response to help yichuan
  • % Last Modified by GUIDE v2.5 15-Jul-2016 21:52:11
  • % Begin initialization code - DO NOT EDIT
  • gui_Singleton = 1;
  • gui_State = struct('gui_Name',       mfilename, ...
  •                    'gui_Singleton',  gui_Singleton, ...
  •                    'gui_OpeningFcn', @yichuan_OpeningFcn, ...
  •                    'gui_OutputFcn',  @yichuan_OutputFcn, ...
  •                    'gui_LayoutFcn',  [] , ...
  •                    'gui_Callback',   []);
  • if nargin && ischar(varargin{1})
  •     gui_State.gui_Callback = str2func(varargin{1});
  • end
  • if nargout
  •     [varargout{1:nargout}] = gui_maiNFCn(gui_State, varargin{:});
  • else
  •     gui_mainfcn(gui_State, varargin{:});
  • end
  • % End initialization code - DO NOT EDIT
  • % --- Executes just before yichuan is made visible.
  • function yichuan_OpeningFcn(hObject, eventdata, handles, varargin)
  • % This function has no output args, see OutputFcn.
  • % hObject    handle to figure
  • % eventdata  reserved - to be defined in a future version of MATLAB
  • % handles    structure with handles and user data (see GUIDATA)
  • % varargin   command line arguments to yichuan (see VARARGIN)
  • % --- Executes on button press in pushbutton3.
  • function pushbutton3_Callback(hObject, eventdata, handles)
  • % hObject    handle to pushbutton3 (see GCBO)
  • clear all;
  • close all;4 \, V6 r7 V2 e# [; N4 o0 I$ W
! j( D9 R: i9 S. h# J  `
9 ^! T' l) v% }8 t- C& \
* J: Q; ~# P* F1 ~' `三、运行结果# t8 x/ t! e( n/ a
+ H; L& q& R: Y& K9 O+ p; c
9 D6 K" K. r0 {$ k4 ~
1 s5 i. M3 q& j0 [% n& r3 Z( F+ J; D- a& K8 H+ J, [4 U! I: @
    2019-11-29 15:37
    发表于 2021-4-12 13:31 | 只看该作者
    GMT+8, 2025-10-30 13:57 , Processed in 0.156250 second(s), 27 queries , Gzip On.
