查看: 368|回复: 0
RT7331-ZCC7331
    2022-5-9 15:00
  • 签到天数: 28 天
    [LV.4]偶尔看看III
    发表于 2021-4-1 13:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    General Description
    4 }$ _9 ^) W$ _: TFeatures
    : k# N8 H* f% S( O) v. [$ s7 {The ZCC7331 is a dimmable constant current LED driver
    * C' B8 L+ l$ h0 ywith active power factor correction. It suppoZCCs high
    " h8 z) X1 G! X# I" u7 Ipower factor across a wide range of line voltages, and' \3 C% w/ Y; z9 F: ~
    it drives the conveZCCer in the Quasi-Resonant (QR)
    / L! B$ Y' ?& k: e3 qmode to achieve the higher efficiency. By using
    ' p! Q2 a5 i. C8 ~  C% {Primary Side Regulation (PSR), the ZCC7331 controls7 z! `+ i" y" G7 y) S
    the output current accurately without a shunt regulator0 n* C  [: g8 c; f1 V9 E
    and an opto-coupler at the secondary side, reducing& I; m' f! n) l, i. G
    the external component count, the cost, and the
    + i0 \! K9 Z( Hvolume of the driver board.* J+ [( q" w$ ]' r: g8 {, @8 o
    Tight LED Current Regulation
    ' t& Z/ ]( |* w5 VSmaZCC CC/CV Mode Control
      Q* z6 A2 h. M# ?# YWide Dimming Range (1% to 100%)" y1 T6 Q# w6 T( q7 D/ P
    Power Factor Correction
    & {; n( P% C# ^# WTHD Optimization (THD < 10%)
    ; a' W8 K  E5 s3 V8 k* o- DQuasi-Resonant (QR) Operation3 b( ^/ B: J; r' W4 J5 h
    Fast StaZCCup
    ! D% `8 O, u4 ?  k1 Q" v: T3 hAdjustable CV level
    / J6 c) g$ L' z& z8 E. tSoft Drive for the Better EMI PeRFormance1 Z; P2 W4 U6 ?! Z+ N. @
    Multiple Protection Features
    $ J% G6 A8 w% }6 [The ZCC7331 is compatible with the analog dimming.* h* ~' A9 v) M  d5 ?- x
    The output current can be modulated by the PWM duty/ M  N" ?, A. l" {
    ratio or the average level of DIM pin.! ~. m% J4 Y/ _. b; y! Y
    LED Open-Circuit Protection * e! `: a' D: D0 V/ Q" u$ L
    LED ShoZCC-Circuit Protection
    7 I( U+ \# J, m+ ^Over Load Protection7 x0 t- p, s) k5 ~$ m% H7 w
    The ZCC7331 embeds comprehensive protection
    / Y* _- l( i0 kfunctions for robust designs, including LED open-circuit
    9 g5 X6 a/ Q9 y6 l7 q+ zprotection, LED shoZCC-circuit protection, output diode
    2 C/ j% t5 Y$ DshoZCC-circuit protection, VDD Under-Voltage Lockout
    " l+ P5 }- e3 \8 @8 ](UVLO), VDD Over-Voltage Protection (VDD OVP),
    8 P3 K2 w" }; {. Gover load protection, input under / over voltage
    . g3 Y7 w" a) n- A% B
      @) N5 P1 a  LInput Under / Over Voltage Protection
    # s: i% g4 @* P
    $ s( G' m6 W( U- I& u2 j7 MOutput Diode ShoZCC-Circuit Protection
    8 ~/ d, _, ~# ?3 q! W% [# G! _, A
    9 n. n2 E! n' h- n$ kVDD Under Voltage Lockout6 _$ v. g0 u7 J  z
    , G  U0 x+ n! mVDD Over Voltage Protection3 n+ |: y& Z! ]+ _( H
    External / Internal OTP & M' L! f: }& D/ C5 ~
    : }- l% Z1 P# s
    protection, external / internal Over-Temperature ) X4 ~3 L0 W6 |
    % `# v) x9 A) pCycle-by-Cycle Current Limitation
    - X* w3 ?2 K+ q+ m5 p$ LProtection (OTP), and cycle-by-cycle current limitation.
    2 m/ f8 r# M6 }# R RT7331-ZCC7331媲美RT7331(1).pdf (3.18 MB, 下载次数: 0)
    / H- B, H# {/ X2 M/ V5 T9 j7 ]- ?* ?3 z5 S2 a! Q3 q
    GMT+8, 2025-10-11 19:11 , Processed in 0.156250 second(s), 28 queries , Gzip On.
