查看: 589|回复: 1
基于matlab金鹰算法(MOGEO)的多目标优化求解
    2019-11-19 15:32
    发表于 2021-3-31 15:03 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
    一、源代码
    8 ~# g  i7 g, ?+ n0 D9 A
    / s! J  j4 W) @* O, P- J
    • %  Multi-Objective Golden Eagle Optimizer (MOGEO) source codes version 1.0
    • %  Original paper:        Abdolkarim Mohammadi-Balani, Mahmoud Dehghan Nayeri,
    • %                                        Adel Azar, Mohammadreza Taghizadeh-Yazdi,
    • %                                        Golden Eagle Optimizer: A nature-inspired
    • %                                        metaheuristic algorithm, Computers & Industrial Engineering.
    • % To use this code in your own project
    • % remove the line for 'GetFunctionDetails' function
    • % and define the following parameters:
    • % fun   : function handle to the .m file containing the objective function
    • %                  the .m file you define should accept 'x' as input and return
    • %                  a column vector containing objective function values
    • % nobj  : number of objectives
    • % nvars : number of decision/design variables
    • % lb    : lower bound of decision variables (must be of size 1 x nvars)
    • % ub    : upper bound of decision variables (must be of size 1 x nvars)
    • % MOGEO will return the following:
    • % x     : best solution found
    • % fval  : objective function value of the found solution
    • %% Inputs
    • FunctionNumber = 7; % 1-10
    • options.PopulationSize = 200;
    • options.ArchiveSize    = 100;
    • options.MaxIterations  = 1000;
    • options.FunctionNumber = FunctionNumber;
    • %% Run Multi-Objective Golden Eagle Optimizer
    • [fun,nobj,nvars,lb,ub]   = GetFunctionDetails (FunctionNumber);
    • options.AttackPropensity = [0.5 ,   2];
    • options.CruisePropensity = [1   , 0.5];
    • [x,fval] = MOGEO (fun,nobj,nvars,lb,ub, options);
    • ' G' ]% s- y1 Y3 m3 j0 ~" g
                   ' R$ A# ^, @% n" B7 o  j8 F' O0 y" ~& e0 w
    7 l- d& e, R- i1 s
    + d2 [) f8 A% o, A  r# D
    二、运行结果3 I6 z; s, M) i2 S1 ~
    ; Y) N0 T' t; Q1 E; x( H6 F
    发表于 2021-3-31 16:03 | 只看该作者
    GMT+8, 2025-10-30 13:57 , Processed in 0.171875 second(s), 27 queries , Gzip On.
