查看: 6960|回复: 9
Cadence Allegro 16.3和PADS 9.2冲突解决办法。
    2025-10-21 15:17
  • 签到天数: 287 天
    [LV.8]以坛为家I
    发表于 2011-4-1 16:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    本帖最后由 zcyxh12345 于 2011-4-1 16:40 编辑 + X, D* i; z/ ?9 h7 I
    / c8 j, u, A' x5 O7 U  ?6 j" o
    问题现象:如果同时安装cadence allegro/orcad 16.3和pads 9.2后,
    / G% @3 g; ?: P2 r9 S' c( X运行“Design Entry CIS”都提示找不到msvcr90.dll。或报runtime 错误。
    " B) V1 |- l. U# U6 u' @1 q% L8 a4 I& D解决这种冲突问题的方法如下:这个是环境变量path引起的。
    8 @2 i# P/ P/ C9 R9 R先装PADS 9.2后装Cadence Allegro/Orcad 16.3会导致启动路径默认为mentor的文件路径," d$ r( h; Z! Q. N4 z! n
    将系统环境变量下面的系统变量path中mentor相关的都调整到后面就可以了。, ~9 ~6 E* O( t7 l% d( N' F
    例如修改前PATH内容为:) Z/ b. m, B! s! S; y
    D:\MentorGraphics\9.2PADS\SDD_HOME\common\win32\bin;D:\MentorGraphics\9.2PADS\SDD_HOME\common\win32\lib;%MGC_HOME%/bin;%MGC_HOME%/lib;%MGC_HOMEBS%\bin;%MGC_HOMEBS%\lib;;%CDSROOT%\tools\bin;%CDSROOT%\tools\libutil\bin;%CDSROOT%\tools\fet\bin;%CDSROOT%\tools\pcb\bin;%CDSROOT%\tools\specctra\bin;%CDSROOT%\tools\Pspice;%CDSROOT%\tools\PSpice\Library;%CDSROOT%\tools\Capture;%CDSROOT%\OpenAccess\bin\win32\opt" z& [& W' ^  D2 W7 d' R7 `$ |
    修改后PATH内容为:
    ( y: y" I  s% k& {) f( }3 o5 x%CDSROOT%\tools\bin;%CDSROOT%\tools\libutil\bin;%CDSROOT%\tools\fet\bin;%CDSROOT%\tools\pcb\bin;%CDSROOT%\tools\specctra\bin;%CDSROOT%\tools\PSpice;%CDSROOT%\tools\PSpice\Library;%CDSROOT%\tools\Capture;%CDSROOT%\OpenAccess\bin\win32\opt;D:\MentorGraphics\9.2PADS\SDD_HOME\common\win32\bin;D:\MentorGraphics\9.2PADS\SDD_HOME\common\win32\lib;%MGC_HOME%/bin;%MGC_HOME%/lib;%MGC_HOMEBS%\bin;%MGC_HOMEBS%\lib* q. f( o* C/ f/ x0 C  Y( m  U
    英文解决办法:
    ; ?1 @" O( _$ O! ]* GYou need to edit your "Path" system variable. Go to:" H: b8 x4 o( \5 w- }/ t
    Control Panel\System\Advanced system settings\Advanced\System variables: l; |6 ?  t/ o  b/ E
    Scroll down to a variable "Path" and click "Edit" button. Copy and Paste the value of your Path into the Notepad, and move all of the "c:\Cadence\SPB_16.3\..." (assuming your installation is in the c:\Cadence) entries to the top of the file. Then copy and paste the contents back into the "Path" variable. That should fix the problem., Z6 x% B6 q& N, q
    发表于 2011-4-1 22:12 | 只看该作者
    添加或更改环境变量2 O, k1 B8 Z9 N- Q$ I
    1.        右键单击“我的电脑”,然后单击“属性”。
    ' ~) B% ^0 W/ M" W0 L# l7 \2.        在“高级”选项卡上,单击“环境变量”。 8 p& g7 H, X' L8 A! V1 N
    3.        在“系统变量”列表中找到path。2 `0 ^9 q4 S8 Q; B+ Q
    4.        单击“编辑”可更改当前变量名和值。
    2 ]  e8 m$ v3 e2 T
    发表于 2011-4-9 11:38 | 只看该作者
    反正记着把cadence的全部环境变量内容提到最前面就好了
    2025-10-21 15:17
  • 签到天数: 287 天
    [LV.8]以坛为家I
     楼主| 发表于 2011-4-11 11:17 | 只看该作者
    嗯 ,就是这样。。。
    发表于 2011-4-14 12:23 | 只看该作者
    很好的帖子,哈哈哈!
    发表于 2011-8-5 10:22 | 只看该作者
    我还是有点不懂,我电脑环境变量的前后顺序都是按照变量名首字母排序的,变量名不改,顺序就改不了,请问变量名可以修改吗??
    无聊
    2021-12-20 15:47
  • 签到天数: 15 天
    [LV.4]偶尔看看III
    发表于 2011-8-5 10:41 | 只看该作者
    关注一下。。。。。。。。。。
    发表于 2011-8-5 12:35 | 只看该作者
    请大侠们做个示范好吗,小弟们不能理解,看图示会知道,谢谢
    发表于 2011-8-8 16:14 | 只看该作者
    lisemi 发表于 2011-8-5 10:22 , q) u6 M0 _) N' q2 X( d- y% w
    我还是有点不懂,我电脑环境变量的前后顺序都是按照变量名首字母排序的,变量名不改,顺序就改不了,请问变 ...
    , o2 C0 |1 b* D同问怎么移动,我这也移动不了8 R& O: _: I0 _+ d! q
    发表于 2016-1-2 18:39 | 只看该作者
    2016.1.2 蒙本帖搭救,感激不尽
    GMT+8, 2025-10-26 14:12 , Processed in 0.156250 second(s), 24 queries , Gzip On.
