查看: 455|回复: 0
500V线性稳压器芯片,替代NCP785-ZCC2785
    2022-5-9 15:00
  • 签到天数: 28 天
    [LV.4]偶尔看看III
    发表于 2021-1-7 14:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    The ZCC2785 is a high−peRFormance linear regulator, offering a very wide
    1 p4 E, `: W' ~- Coperating input voltage range of up to 450 V DC, with an output current of up to; @/ b; N5 ~1 K9 t  h% i
    10 mA.4 `3 T6 t) R% M0 n9 m" W
    Ideal for high input voltage applications such as industrial and home metering,  M" z0 J5 l+ `
    home appliances. The ZCC2785 family offers ±5% initial accuracy, extremely
    9 J- ~" P9 c/ j0 s- e. ^2 lhigh−power supply rejection ratio and ultra−low quiescent current. The
    # M9 W* Y8 s: K! V; B5 R( v, eZCC2785 is optimized for high−voltage line and load transients, making this
    1 U) t" K) w+ J- `2 Y) z, @part ideal for harsh environment applications.6 u2 }  F# [- b6 Y  O* ~7 H
    The ZCC2785 is offered in fixed output voltage options 2.7V,3.3 V, and5.0 V.% c- @' V, n0 U  W9 H$ v
    package offers good thermal performance and help to; b2 n8 A9 s" Y2 t8 c6 n
    minimize the solution size.3 ]! w: I8 j( `1 n; h9 n/ ]/ ~2 \
    Features
    , D0 X# N; b/ F5 O( y: \● Wide Input Voltage Range:
    / u7 l! t6 z" @. ~1 s5 ?DC: Up to 450 V
    . w! `  @& l' `, CAC: 85 V to 260 V (half−wave rectifier and 2.2 μF capacitor)
    - a/ q& a6 [& F  M9 K' O●10 mA Guaranteed Output Current
    4 G1 J4 t/ N. [& E4 ~8 w●Ultra Low Quiescent Current: Typ. 10 μA (VOUT ≤ 5 V). c/ }& i" T7 ]) n
    ●±5% Accuracy Over Full Load, Line and Temperature Variations1 [8 N" \7 a- k9 }
    ●Ultra−high PSRR: 70 dB at 60 Hz, 90 dB at 100 kHz0 E6 `4 B  D# ~/ F, Y- k
    ●Stable with Ceramic Output Capacitor 22 μF MLCC* D4 Y9 {5 B( V. k! H# d- b
    ●Thermal Shutdown and Current Limit Protection. Q/ h# e, n; c1 i- V4 B+ N1 R
    ●Available in Thermally Enhanced ESOP8 Package9 O: W, q9 I1 T+ C0 [1 z; U
    ●This is a Pb−Free Device1 \9 X9 c# c: C  x2 ~8 p4 `' O
    GMT+8, 2025-10-11 09:19 , Processed in 0.125000 second(s), 24 queries , Gzip On.
