查看: 224|回复: 0
ZCC66099同步升压加LDO 替代SGM66099
    2022-5-9 15:00
  • 签到天数: 28 天
    [LV.4]偶尔看看III
    发表于 2021-1-5 17:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    The ZCC66099 is a synchronous step-up converter : f% S. @5 {: A
    with 0.65μA ultra low quiescent current. It is designed 0 T& m2 \. v% _7 C3 A
    for products powered by alkaline battery, NiMH
    : j* Z3 S, ~* {- Z0 brechargeable battery, Li-Mn battery or rechargeable Li-
    8 }( ^) r& x% T* ?- `Ion battery, for which high efficiency under light load 5 C6 v9 P4 U9 G4 F) O
    condition is critical to achieve long battery life operation.
    8 C2 J8 `8 z- t- B' jThe ZCC66099 step-up converter only consumes
    0 q9 F2 A' _& x" k1 E/ Q. p2 F0.65μA quiescent current under light load condition and
    ) p2 @; u" o9 p  T% X& kcan achieve up to 75% efficiency at 10μA load with 5 t8 @, P- e6 f. `7 N
    fixed output voltage version. It can also support up to
    - x6 U& h' Y; g, W* R300mA output current from 3.3V to 5V conversion, and
    ) o  J  C5 @1 r) e7 Z0 \+ Jachieve up to 93% at 200mA load. # ^+ r) Y9 u5 a
    The ZCC66099 also offers both down mode and pass-
    ; O4 Y8 f2 y9 N; _+ x+ S. Qthrough operation for different applications. In down
    0 z! B0 {2 H0 b: c& Vmode, the output voltage can still be regulated at target
    . V7 a& r( L+ x, u6 A4 ovalue even when input voltage is higher than output 7 ^5 d/ ^* G4 w
    voltage. In pass-through mode, the output voltage 8 b0 {  b1 i2 J' p% k
    follows input voltage. The ZCC66099 exits down mode
    # R; j! J; m1 w3 `# `/ i4 y- Uand enters into pass-through mode when VIN > VOUT +
    * T9 M2 }, c: f2 h* U2 `3 d0.3V. : @/ s% \. D# z* t
    The ZCC66099 supports true shutdown function when
    / p/ n" Z/ _. wit is disabled, which disconnects the load from the input * y+ T4 \1 _! a* l% a$ ~
    supply to reduce the current consumption.
    1 m* U$ D% T  o3 y; XThe ZCC66099 offers both adjustable output voltage , A, T1 o. b7 |# D: ]( L; k9 a
    version and fixed output voltage versions. It is available
      P" _4 O, S6 ~8 rin Green WLCSP-1.22×0.83-6B and TDFN-2×2-6AL
    # E7 I" @# ]/ C6 n' ?packages.
    ! {$ R5 C! j5 t- Q& i: c& e) o: Q! T4 r, X
    1 V0 T* p7 s: v7 {6 O' ?# }
    / O9 `( q* a- a! @# `2 `
    GMT+8, 2025-10-11 09:19 , Processed in 0.109375 second(s), 24 queries , Gzip On.
