TA的每日心情 | 开心 2022-5-9 15:00 |
签到天数: 28 天 [LV.4]偶尔看看III
General Description + T# j2 w6 q/ a! ~
Features
; [' p% Q2 n3 X. K/ ~' ]) U5 |The ZCC7331 is a dimmable constant current LED driver
0 W- y' F1 o8 |$ @; ?; Pwith active power factor correction. It suppoZCCs high
9 g, A: ~9 u" S. N; x1 gpower factor across a wide range of line voltages, and
6 p" Q9 O+ F6 j7 s, eit drives the conveZCCer in the Quasi-Resonant (QR)
+ D: i c: ^" _1 p: Nmode to achieve the higher efficiency. By using# W7 Y8 y( a2 r4 a
Primary Side Regulation (PSR), the ZCC7331 controls
) A: f& I6 ]% othe output current accurately without a shunt regulator
3 }" W, `$ A+ L# eand an opto-coupler at the secondary side, reducing
4 t1 Y0 b5 P Rthe external component count, the cost, and the2 S. u7 O: D( H$ r
volume of the driver board.( J3 e9 S' w2 P7 E. E* P; E
Tight LED Current Regulation
) x7 B0 a$ c7 ~- T
+ g: I! K6 Q& I; q* F0 u0 @1 c# U. ~& @
1 K* [) L0 B0 J o% m' Y5 {' r
1 Y) u$ t# S: f0 w. d! [
# G7 i$ H2 J( B) P$ W; B K8 @' Q$ Q
# }5 {- V" _5 x0 n0 T/ z n
2 e9 P+ }- Z" G0 h
2 C* C8 Z, w* W2 r; o# gSmaZCC CC/CV Mode Control
! ~( m4 [2 D3 h FWide Dimming Range (1% to 100%)( I7 s7 I8 \- i: G2 k
Power Factor Correction" X6 j, W& X% N( P; c. {
THD Optimization (THD < 10%)
* m1 }9 E" A/ z; y* K. {! v: pQuasi-Resonant (QR) Operation
- O, j! g+ C4 C7 KFast StaZCCup& ?7 p% n: l: [% q
Adjustable CV level
# A) z$ K" Q: v0 k# _5 x* eSoft Drive for the Better EMI PeRFormance* Q, G. n, E0 [6 i$ ]0 W; X
Multiple Protection Features: I* R1 [! L- p
The ZCC7331 is compatible with the analog dimming.
- a- A2 [& _+ F0 TThe output current can be modulated by the PWM duty
. c2 f7 [5 j! {1 A9 T9 ^ratio or the average level of DIM pin.
& f/ u/ S: ~# k. u; H/ cLED Open-Circuit Protection
7 T' P6 u) M! P+ F# I. D5 j* D- b( p, e
LED ShoZCC-Circuit Protection- L& F# n6 Y9 v9 G
Over Load Protection2 t) h! p. t5 v
The ZCC7331 embeds comprehensive protection
/ {! G" ?' q! A; E; n' {functions for robust designs, including LED open-circuit# N3 K5 {/ P0 s: x
protection, LED shoZCC-circuit protection, output diode, H+ _/ K5 Q5 m' J2 \6 C9 Q
shoZCC-circuit protection, VDD Under-Voltage Lockout) e5 n/ C0 f% M0 X
(UVLO), VDD Over-Voltage Protection (VDD OVP),
8 _+ D& d6 C6 w+ n5 {) g# Y: d6 [# {over load protection, input under / over voltage$ Q- i5 F3 J2 F- S8 e3 A" O% e
Input Under / Over Voltage Protection
/ ?' l, u, q* {4 { Output Diode ShoZCC-Circuit Protection5 Y/ F' L8 F7 N4 x$ T$ J: ~4 `, O
VDD Under Voltage Lockout
& {1 F/ f3 a/ R* T6 g VDD Over Voltage Protection
% [3 f. ]9 O7 EExternal / Internal OTP
7 W; H7 {5 J( Y0 O t
# }6 H* q0 u. l" f% n n2 ?8 xprotection, external / internal Over-Temperature ; ~3 n, q1 K: ~3 L$ G) P4 R/ o4 P
Cycle-by-Cycle Current Limitation1 b. W; M, v& v# o& h' r' c; f
Protection (OTP), and cycle-by-cycle current limitation.' J3 @) f; ?: V4 g
Applications
! y2 \7 s& [4 d' d+ @7 k+ d u AC-DC LED Lighting Driver( k& N% |7 @1 g" d0 K2 [" V$ H
! ?# R& L0 U7 n) R |
