ETSI EN 303 204 V3.0.0 (2020-05) Fixed Short Range Devices (SRD) in data networks; Radio equipment to be used in the 870 MHz to 876 MHz frequency range with power levels ranging up to 500 mW; HARMonised Standard for access to the radio spectrum 数据网络中的固定短程设备(SRD);将在870 MHz至876 MHz频率范围内使用的无线电设备,功率水平最高为500 mW;无线电频谱协调统一标准 ETSI EN 302 307-2 V1.2.1 (2020-05) Digital Video Broadcasting (DVB); Second generation framing structure, channel coding and modulation systems for Broadcasting, Interactive Services, News Gathering and other broadband satellite applications; Part 2: DVB-S2 Extensions (DVB-S2X) 数字视频广播(DVB);用于广播,交互式服务,新闻收集和其他宽带卫星应用的第二代帧结构,信道编码和调制系统;第2部分:DVB-S2扩展(DVB-S2X) ETSI EN 302 208 V3.3.0 (2020-05) Radio Frequency Identification Equipment operating in the band 865 MHz to 868 MHz with power levels up to 2 W and in the band 915 MHz to 921 MHz with power levels up to 4 W; Harmonised Standard for access to radio spectrum 射频识别设备工作在865 MHz至868 MHz频段,功率电平最高为2 W,工作在915 MHz至921 MHz频段,功率电平最高为4 W;无线电频谱协调统一标准 RSS-192 Issue 4 May 2020 Flexible Use Broadband Equipment Operating in the Band 3450-3650 MHz 在3450-3650 MHz频段内运行的灵活使用的宽带设备lEN 55035:2017/A11:2020 Electromagnetic compatibility of multimedia equipment - Immunity requirements ETSI EN 303 204 V3.0.0 (2020-05) Fixed Short Range Devices (SRD) in data networks; Radio equipment to be used in the 870 MHz to 876 MHz frequency range with power levels ranging up to 500 mW; Harmonised Standard for access to the radio spectrum 数据网络中的固定短程设备(SRD);将在870 MHz至876 MHz频率范围内使用的无线电设备,功率水平最高为500 mW;无线电频谱协调统一标准 ETSI EN 302 307-2 V1.2.1 (2020-05) Digital Video Broadcasting (DVB); Second generation framing structure, channel coding and modulation systems for Broadcasting, Interactive Services, News Gathering and other broadband satellite applications; Part 2: DVB-S2 Extensions (DVB-S2X) 数字视频广播(DVB);用于广播,交互式服务,新闻收集和其他宽带卫星应用的第二代帧结构,信道编码和调制系统;第2部分:DVB-S2扩展(DVB-S2X) ETSI EN 302 208 V3.3.0 (2020-05) Radio Frequency Identification Equipment operating in the band 865 MHz to 868 MHz with power levels up to 2 W and in the band 915 MHz to 921 MHz with power levels up to 4 W; Harmonised Standard for access to radio spectrum 射频识别设备工作在865 MHz至868 MHz频段,功率电平最高为2 W,工作在915 MHz至921 MHz频段,功率电平最高为4 W;无线电频谱协调统一标准 RSS-192 Issue 4 May 2020 Flexible Use Broadband Equipment Operating in the Band 3450-3650 MHz 在3450-3650 MHz频段内运行的灵活使用的宽带设备
# d1 A" i% e g9 a9 d$ Q J W9 v |
