7 k( r& D7 ~8 u$ V* {: p1 ?
合作协同进化(Cooperative Coevolution)是求解大规模优化算法一个有效的方法。将大规模问题分解为一组组较小的子问题。而合作协同进化的关键是分解策略。
9 p9 _2 F# y- R# t* e; }( G
' w6 Z3 z+ N6 Y8 ANSGA2算法是一种多目标遗传算法。此文章是随机固定分组的合作协同进化利用NSGA2来优化。
( X. R- |0 D' {4 B
1 F% q) X" x/ _$ w, G比如有12个决策变量,我们固定随机优化3个决策变量,那么就将决策变量分成了4组。
9 @4 O1 U e9 [2 F+ t; @0 l6 n* b$ m+ [9 ]3 A3 P3 B, j
MATLAB主函数代码:
& f! W& ~& A- w* m% n& c1 K" v6 a4 {9 ?1 w: x% j" J6 d" w
- clc;
- clear;
- global pop
- pop = 500; %种群数量
- gen = 2; %迭代次数
- global M
- M = 2; %目标数量
- Dim=22; %搜索空间维数(未知数个数)
- sub_dim= 2 ;
- global min_range
- global max_range
- min_range = zeros(1, Dim); %下界
- max_range = ones(1,Dim); %上界
- divide_datasets();
- global answer
- answer=cell(M,3);
- Dim_index = ones(1,1)*(1[color=rgb(0, 111, 224) !important]: Dim+4);
- chromosome = initialize_variables(pop, M, Dim, min_range, max_range, Dim_index);
- chromosome = non_domination_sort_mod(chromosome, M, Dim);
- result = 1;
- while gen ~= 0
- subgroup = rnd_divide(Dim, sub_dim);
- for i=1:length(subgroup)
- subgroup{i}(sub_dim+1)=Dim+1;
- subgroup{i}(sub_dim+2)=Dim+2;
- subgroup{i}(sub_dim+3)=Dim+3;
- subgroup{i}(sub_dim+4)=Dim+4;
- [temp_chromosome] = nsga2(chromosome(:,subgroup{i}), sub_dim, subgroup{i});
- chromosome(:,subgroup{i}(1:sub_dim)) = temp_chromosome(:,1:sub_dim);
- end
- chromosome = nsga2(chromosome, Dim, Dim_index);
- gen =gen - 1;
- progress = 1-gen/10
- end
- plot(chromosome(:,Dim + 1),chromosome(:,Dim + 2),'*');
- xlabel('f_1'); ylabel('f_2');
- title('Pareto Optimal Front');, M$ y4 q3 d. }! [$ R% e# o d6 Y
* D6 R+ R1 s8 D( Y+ t8 z5 @& B6 `2 f2 `
随机分组代码:
5 b: g5 d& p1 v3 k/ P' j% D% T, F a5 t
- % random grouping
- function group = rnd_divide(dim, subdim)
- dim_rand = randperm(dim);
- group = {};
- for i = 1:subdim:dim
- index = dim_rand(i:i+subdim-1);
- group = {group{1:end} index};
- end
- end' `: f( H/ k5 G( ^
