查看: 7338|回复: 5
求ORCAD DRC错误解决方法
发表于 2010-12-30 09:58 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
新手刚学allegro16.2要搞个大的工程现在orcad中进行DRC检查时出现了1000多个错误如下:WARNING:  [DRC0004]  Possible pin type conflict C616,2 Bidirectional Connected to Power
- D6 b9 s. e1 S( R  u                    DESIGN, 11 FB MEMORY DECAP  (7.10, 3.70)
' i) Q- i4 u8 K6 _WARNING:  [DRC0004]  Possible pin type conflict C839,2 Bidirectional Connected to Power
3 }# j0 n: l+ m4 D, j- H# G2 z9 e                    DESIGN, 11 FB MEMORY DECAP  (7.50, 10.40)
3 o/ `; U# x5 I5 ~/ L' c9 lWARNING:  [DRC0004]  Possible pin type conflict C613,2 Bidirectional Connected to Power- P7 \: R" H' q8 H! ?9 p+ d
                    DESIGN, 11 FB MEMORY DECAP  (7.50, 6.60)
7 p6 R6 ]! N0 ?5 |8 Q7 Z; s% gWARNING:  [DRC0004]  Possible pin type conflict C50,2 Bidirectional Connected to Power* f. b) S! S. o2 |1 ^$ g. x, \. `
                    DESIGN, 11 FB MEMORY DECAP  (7.50, 2.80)
& ~+ z/ |! E# o. s0 }: HWARNING:  [DRC0004]  Possible pin type conflict C804,2 Bidirectional Connected to Power
  D$ z/ }7 }& f1 _+ C) L  x+ M                    DESIGN, 11 FB MEMORY DECAP  (7.70, 11.30)
$ K2 J* ~; Z( m6 u, I$ }; D3 tWARNING:  [DRC0004]  Possible pin type conflict C597,2 Bidirectional Connected to Power
7 |* O; |8 U9 X2 J/ X: |. J. f                    DESIGN, 11 FB MEMORY DECAP  (7.70, 7.50) - Q+ N) T: J6 a: H9 I7 {
Checking for Unconnected Nets2 L3 a3 N5 ~% t8 H2 f
WARNING:  [DRC0007]  Net has no driving source SNN_FBA_RFU_2$ l9 E! \3 B$ r6 l: W& j
                    DESIGN, 05 FBA Partition Memory 1 0f 2  (17.20, 4.90) * S( w/ a: \( `6 v/ \. R5 z) B
WARNING:  [DRC0007]  Net has no driving source SNN_FBA_RFU_1: n( a# v+ i  t, n& d; D6 o
                    DESIGN, 05 FBA Partition Memory 1 0f 2  (17.20, 4.80) 3 Q+ [+ X% Q1 W
WARNING:  [DRC0007]  Net has no driving source SNN_FBA_RFU6
' p) n- l/ X+ d- p, U9 \0 VWARNING:  [DRC0006]  Net has fewer than two connections SNN_GPU_PD<5>( @9 u6 l) U$ _. R$ z
                    DESIGN, 21 PWR and GND Signals  (18.80, 9.80) * `0 Q, {7 z- k
WARNING:  [DRC0006]  Net has fewer than two connections SNN_GPU_NC<2>
9 l( q2 z) D, t# U# t7 I                    DESIGN, 21 PWR and GND Signals  (9.30, 4.60)
4 T( O8 @, k2 m4 i5 z6 |ERROR:  [DRC0027]  Other parts in this package have different values or PCB footprints. /G1Q, F1 z( t5 i) W5 S
                    DESIGN, 21 PWR and GND Signals  (6.40, 4.00) ' p* H5 h! z- f) F; d7 Z. K
ERROR:  [DRC0027]  Other parts in this package have different values or PCB footprints. /G1T
8 B0 w/ D; }+ A- c! g* W                    DESIGN, 22 NVVDD Decoupling  (2.60, 2.00)
& C1 ^5 d) v+ _  k! w5 v& WDRC0004]这个错误最多了(这个好像说是管脚类型冲突什么来的)' J# v* x! i3 t; e% p
导制无法导出网络表  E1 B7 U" T, s. ^2 I- @
请各位高手帮忙指点& N3 Q2 Z: Z9 k1 \: a$ S
 楼主| 发表于 2010-12-30 11:23 | 只看该作者
没人出手啊
. Y! n& [/ u4 i* ^) N  {: k: O2 D* y1 O, N# T
自己顶一下
    2020-4-15 15:20
    发表于 2010-12-30 12:45 | 只看该作者
    本帖最后由 maozheng110 于 2010-12-30 12:47 编辑 ; M+ N' j; w' l# j+ `: P& \
    5 `1 h9 W; ^/ H* I/ F: {5 A
    # v8 r+ H  |+ ~$ N, A" {7 H
    DRC 中设置一下啊 drc matrix8 p' b& i# l  U6 l' ^7 Y2 w
    红圈的地方去掉
    2 @& ?( P' S8 Z4 |% I
     楼主| 发表于 2010-12-30 14:03 | 只看该作者
    谢谢楼上的兄弟DRC0004是没有了。' X! V) G* c6 g9 L4 C6 g
    7 P% _0 Y( [' i但是 [DRC0007] [DRC0006] DRC0027]还是解决不了
    发表于 2011-1-10 16:42 | 只看该作者
    你将所有的连线都删掉,然后再工具栏里选择Snap To grid后,重新连线试一试
    发表于 2011-9-22 20:26 | 只看该作者
    正学习中
    GMT+8, 2025-3-6 22:05 , Processed in 0.078125 second(s), 27 queries , Gzip On.
    网站统计
