%%下面是画图的函数( z+ @+ L4 m1 e5 g2 s4 H$ T0 P; X
x0=[pi/3;pi/4;-pi/3;-pi/5;
" ]% y. o' i3 K! e! O 0;0;0;0;0 U) v- Y$ ?5 W
0;0;0;0;: _4 y- S' `- m( @( }5 a# R; ^1 m( l
0;0;0;0;
: F1 f8 i& Q* A 0;0;0;0;) O6 }7 D% c. l5 E, |9 A( ?, w" V, }
0;0]; %%初始条件) i. J6 v j% t
[t,x]=ode45(@example180928,[0:30],x0);%求解微分函数值$ \. h4 f( F& ^3 I
figure(1): I6 J8 L; }( h8 F+ d" @ \3 ]
plot(t,x(:,1),'-.b' ,t,x(:,2),'-m' ,t,x(:,3),'--g' ,t,x(:,4),':k' ,t,x(:,21),'-.r','LineWidth',2.0);
# r9 ?1 g9 ~) X5 A; e3 r%axis([0 20 -2 5]);9 x+ @0 S; l3 |# w9 _! c
set(gca,'FontSize',10,'LineWidth',1.2); set(gcf,'Color','White');
9 ?5 ?" Y6 ?0 Qxlabel('Time (seconds)','FontSize',16.0);6 o7 }/ I: v$ F- X7 ~ I7 i7 b
legend('x_{1}','x_{2}','x_{3}','x_{4}','x_{0}');6 d% ]1 J- i& {6 h7 x% [
title('The trajectories of five agents','FontSize',16.0 );8 ~" h+ C& A) \/ B
%%%%下面是函数定义的程序
4 B8 d8 p& f( [* j0 Wfunction [ dx] = example180928( t,x )
" x5 J) A! r C A=[0 1 0 1;%拓扑
) d- ?* @# e1 E) [% L. M6 y 1 0 1 0;; }# h8 G* s5 q$ }6 |
0 1 0 1;
% ]. ?8 r, ~$ u* p: j# |" u) H 1 0 1 0];$ `, @4 @8 r/ F. @2 i, b# a
H=diag([sum(A(1, ) sum(A(2, ) sum(A(3, ) sum(A(4,:))]);% K, G: w3 v2 b: y! \
L=H-A;& C4 ^' Z/ e) B# @
B=diag([1 0 0 0]);
' ]' D. [# W0 T! c: G%%%实际系统参数
) W ~! j1 j$ P4 U. H: B& sf=zeros(4,1);
7 r$ b; z1 e( Vd=zeros(4,1);
S7 n# F2 @7 _+ u) k" P0 wg=zeros(4,1);
! d# B# O, v# P, s8 n& r2 Y5 {for i=1:4
; G' z* e7 B& }9 D7 u: F li0=1+0.04*i;li1=0.5*li0;mi=0.4*li0;: K* y( {1 X2 N5 f
XIi=(cos(x(i))+li0/li1)^2*li1^2/li0;
' @4 D! b7 ~3 ] f(i)=li1*sin(x(i))*(1+li1/li0*cos(x(i)))*x(i+4)^2/XIi-9.8*sin(x(i))*(1+cos(x(i)))/XIi;( ]; h8 ?' G+ c
g(i)=0.4/(mi*li0*XIi);
" p" F$ y/ B9 f7 W7 g8 o0 T( U d(i)=0.2*i*cos(t);
+ `0 z' [/ p: A9 uend( r. T; T% o2 w D4 ]
d=[d(1); d(2); d(3); d(4)];
$ c! B5 n. K6 v) Vf=[f(1); f(2); f(3); f(4)];. T9 l/ {% ~# W' M0 D6 A" }
gg=diag([g(1) g(2) g(3) g(4)]);
; Y6 _1 A! M$ I8 ]) I1 n%%%%%%%5%x1变量x,v,参考轨迹5 ]9 S ~+ B$ A* c+ F$ v
q=[x(1) x(2) x(3) x(4)]';%所有智能体的位置' f/ g: e% g0 W3 t
v=[x(5) x(6) x(7) x(8)]';%所有智能体的速度
, _% }: ^3 N5 K9 D5 YWf=[x(9) x(10) x(11) x(12)]';%未知动态
- m* a' p' ~9 b5 r/ U4 qk=[x(13) x(14) x(15) x(16)]';%nussbaum
1 K: B1 s! b) h1 f: `. Q: G! }alpha=[x(17) x(18) x(19) x(20)]';%未知外部扰动误差. N9 b: D! _" H' M$ e
vd=x(22);
: m+ ]% o7 l2 ^$ i/ h6 {9 }%dvd=x(22);
, O: |1 M, i& r% Y$ y3 e%%%%%%%%%%%%%%%%跟踪误差z
/ | |. G; g& [: w% F" W: axi=zeros(4,1);/ }, m6 s6 d+ Q2 q+ [1 z% Z; V$ T
for i=1:4 5 x' U7 a- G" l5 b
S=0;+ q* d- F+ q& `* H5 b! @
for j=1:4
$ e W- L: c$ X8 J& M S=A(i,j)*(x(i)-x(j))+S;
" V/ H0 ]& g$ f: p9 n end5 J6 U+ q. Q B& H
xi(i)=S+B(i,i)*(x(i)-x(21));
/ l2 T+ v$ f oend/ t5 L: ?: w% F$ y; e2 o& ]1 E, l9 r, |
xi=[xi(1); xi(2); xi(3); xi(4)];%\xi* {+ d, C& j! G3 |
$ i7 h, A+ S# A# c8 s- U3 H, }
dxi=zeros(4,1);1 z, y9 I! X8 U* {' R z
for i=1:4
! F0 k q$ l6 F T=0;
) [1 N4 C# H3 U B for j=1:4
! z( O( N* X: K' d T=A(i,j)*(x(i+4)-x(j+4))+T;
+ D8 S/ D+ z$ v2 f end8 Q' ^6 K) U ~' ^: C' s) K: o+ {
dxi(i)=S+B(i,i)*(x(i+4)-x(22));
( x6 B. s9 p/ L2 b& O0 aend; t4 s9 t4 N: y2 Z' Q5 k
dxi=[dxi(1); dxi(2); dxi(3); dxi(4)];%\dxi
) S! l1 v# y+ U" G6 p* P, Z5 x%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%模糊逻辑系统%%%%%%%%%) a' a$ u# V1 q0 j& N. g
s1=zeros(16,1);- t& A) P: s) x3 j' K" o
for i=1:4
) G& |1 W( U; y9 L6 Z( z% G1 c8 { phi1=[exp(-(x(i)-3+1)^2/16);
9 f1 V. l! [$ p- r) p: h3 X h exp(-(x(i)-3+2)^2/16);
2 H7 M4 c2 `. f$ K exp(-(x(i)-3+3)^2/16);
6 ^6 I4 q) g9 M7 j; Y" E+ A exp(-(x(i)-3+4)^2/16)];( \' a: G# I m5 n* O
ph1i=phi1/sum(phi1);0 R! n; t& U6 Z# `5 m% ^4 t& I
s1(4*(i-1)+1:4*i)=ph1i;
" w9 g. @ ]6 y; U/ W/ Hend
L5 f% O, M7 Z+ T5 KSf1=s1(1:4);Sf2=s1(5:8);Sf3=s1(9:12);Sf4=s1(13:16); %%\varphi_{i}" q9 i8 k) j, w# i' K4 p
Sf=[Sf1 Sf2 Sf3 Sf4];
5 M9 P9 h3 z/ v) Y- n%%%%%%参数,
3 c" E# F* n, b5 Q% VBeta=[15 0 0 0 ;
$ z9 ^6 w# ^! O6 P! X4 J# p5 P 0 15 0 0 ;: A/ x9 g7 ]1 u& s M8 S
0 0 15 0 ;% [, j4 O8 _8 ^; q# l$ K+ C$ ]3 V O m
0 0 0 15];$ i. m* Z W! e t
Mu=[1 0 0 0 ;: |6 t9 p/ M) q
0 1 0 0 ;7 X0 i; Z- w" {' x! [
0 0 1 0 ;
# a4 Y, t6 I$ ~: ]. X$ y3 G! \ 0 0 0 1];
( W" C' Y- t& a7 W" P' CRho=[1 0 0 0 ;
. V5 g1 [$ c% B# l9 A7 d' ] 0 1 0 0 ;
7 k5 b3 Y' y7 e) A6 o 0 0 1 0 ;
4 b7 H$ U; Q7 T7 Z 0 0 0 1];
! s: ^2 d) z& ?2 E2 r$ j z=xi+dxi;! [. O3 s, I8 l" Q8 ?6 _
z=[z(1);z(2);z(3);z(4)];! E8 J8 e4 ]2 y0 M, J |
dWf=Mu*Sf*z;
0 D+ U# x* g4 V- M6 s4 t5 v bf=Sf*Wf;
& l& j$ I% R* j" Q0 ] theta=exp(-0.05*t);
9 \! I0 z; n0 w$ @. z pi=[z(1)*x(17)/(z(1)^2+theta^2)^0.5;
$ \: F1 Z& \. |9 k. J z(2)*x(18)/(z(2)^2+theta^2)^0.5;
) g6 |0 I8 a& N- U/ V0 Q/ ~ z(3)*x(19)/(z(3)^2+theta^2)^0.5;2 ~1 W$ j! Z, B2 H5 X7 U K% o
z(4)*x(20)/(z(4)^2+theta^2)^0.5];5 ]) W& f$ R# B3 V+ A
dalpha=Rho*[z(1)^2/((z(1)^2+theta^2)^0.5);3 I1 o; w9 O7 O$ Z# \
z(2)^2/((z(2)^2+theta^2)^0.5);9 r9 W) R. r8 ?* J
z(3)^2/((z(3)^2+theta^2)^0.5);5 v% p4 I+ e ~
z(4)^2/((z(4)^2+theta^2)^0.5)];0 y% K6 {6 ?# f3 X& a
dk=diag([z(1) z(2) z(3) z(4)])*(Beta*z+bf+pi);
0 U2 P' f" X9 h, uNk1=-exp(0.5*x(13)^2)*(x(13)^2+2)*sin(x(13));Nk2=-exp(0.5*x(14)^2)*(x(14)^2+2)*sin(x(14));4 ?, d+ u' f4 N, t, z& H
Nk3=-exp(0.5*x(15)^2)*(x(15)^2+2)*sin(x(15));Nk4=-exp(0.5*x(16)^2)*(x(16)^2+2)*sin(x(16));8 H/ W" |1 Z* M! |: Z4 R: d
Nk=diag([Nk1 Nk2 Nk3 Nk4]);
+ p' Q4 l; H% p8 z( r+ au=Nk*(Beta*z+bf+pi);+ |* t0 d& K+ O$ `# \7 ?0 M& N' h
%%%%%%%%%%%%%%%%%%动态方程的表达式
, h3 f4 `9 w0 X Z* @' B9 \; h" _" Xdq=v;
7 ~3 P1 J! T( r$ cdv=f+gg*u+d;
: G W8 ]. |. t! M6 Odxd=vd;%%%leader
1 ~1 m7 X5 G3 z/ \. Tdvd=cos(t);
7 W3 ]" }2 U4 }, O* k' }2 a%%%%%%%%%%%%%%%%%%解微分方程: ]# R- g* F- s) W, L
dx=[dq;dv;dWf;dk;dalpha;dxd;dvd];
( v% B7 T% X8 }* }x
0 s$ h& K1 N4 x( d) _end* R( h( j; V: R: k
4 c, r9 Q/ t$ A3 b& H" p) v图像只出坐标轴不显示图像,x的结果到一定时间之后是NAN,不知道要怎么调试参数,求助' T r+ _2 _, j; m2 y" N
2 O) l; J3 B/ s* H |
