情况比较复杂,首先PCB图(未走线)是从别人手中接过来的,DECAL库也是从同一个人手中接过来的。其中要做一部份DDR的复用电路,且是不同板之间的复用;首先我在SETUP_LAYER Definition里把两块板子的层定义改为了一模一样(特别说明:第一层为NO PLANE ;第二层地层混合层,第三层电源层混合层,第四层 NO PLANE)。然后,做复用电路,当复用到未走线板时,报告错误如下:: c c8 S/ D. X8 K! }5 G
WARNING: Layer association mismatch (Layer 2)
/ f2 r, v: K D! A- v Silcscreen for Layer 2 in Design: 29 SS Silkscreen Bottom1 F8 E I" A- l n% [
Silcscreen for Layer 2 in Reuse: not assigned (ignored)
4 `. x3 s& p/ U. `: TWARNING: Layer association mismatch (Layer 2)
* v9 L( ]: n4 M. [0 f) h- ?: T0 k Paste Mask layer for Layer 2 in Design: 22 PM Paste Mask Bottom
" T9 r, `: M- X+ K! S- C9 x. J Paste Mask layer for Layer 2 in Reuse: not assigned (ignored)5 D5 ^3 z* Y" \: p g' X
( T& W* n4 m' B6 N; G Solder Mask layer for Layer 2 in Design: 28 SM Solder Mask Bottom; ^- F! r1 r& B$ C
Solder Mask layer for Layer 2 in Reuse: not assigned (ignored); p+ V1 u* g6 L. F/ |
WARNING: Layer association mismatch (Layer 2)3 y5 j: I+ }7 H ` m- J j
Assembly layer for Layer 2 in Design: 30 SM Assembly Drawing Bottom* \0 _ ^+ [' Y$ _4 ?
Assembly layer for Layer 2 in Reuse: not assigned (ignored)* T: S# g2 t4 p( ^* v
WARNING: Stack mismatch (Decal BGA84-32-1509E)
' D/ o, _( _6 b6 O& I Default pin stack for Decal BGA84-32-1509E in design
2 S' w1 S" J$ j2 w( a Default pin stack for Decal BGA84-32-1509E in reuse3 e& }& J( ^, j/ _, T& B9 ]' R( ~1 m
WARNING: Stack mismatch (Decal PROVIA_22_10)) i& q* W9 a. \* t" A" ]+ _
Default pin stack for Decal PROVIA_22_10 in design& V9 Y$ f5 R) @& I& h" }
分析:' y3 h ~5 q8 o; \& K
LAYER 2为混合层
+ T7 S, o( Q% f. V' F. j( Y3 F其设置界面如左边并无association选项,只有当其为NO PLANE时才有associaton图标。可如上报告中为何说我的LAYER 2没关联?真不知道到哪里去设置这一项;
! k- A% S! I, m4 K/ m4 H9 h# K外加我的库是从接手板子的人手里考过来的,为何又报封装不匹配?9 D& h* X9 [3 B" U
这个问题困惑好多天了,一直没解决,忘高手帮忙一解答,万分感谢;
! [4 F# H" s# r# y! Q( u3 _ |
