近期在改别人的板时出现pads Part name not found ,多次确认封装、类型都是正确的,百思不得解。
2 d6 R; }$ u3 p5 V8 t
9 V# x0 o8 F2 o2 F多次百度仍没有找到合适的解决方法,今下午再次搜索,发现一个贴8 s; B& [8 X4 o |# n
http://forum.eepw.com.cn/thread/268959/1/
+ P. l3 k# E3 H6 R$ v) V0 J
" k0 W* `* w% [9 I. m3 p果断尝试,发现果然可以,layout层数对导入竟然也有影响,; d& L% {. R- E' d
8 t. g: @6 r) E$ J( e6 _' G![]()
" q5 v& o2 o4 A' s+ F! q3 L4 J7 \/ m" O. C2 _- ?
8 @6 A* ?" Y( M0 ]! ]; O
9 M5 I+ t+ [: H) K$ [- c4 y3 u6 s q; d; }
** ECO In Report **/ j# v3 n, P$ Y7 K4 i$ D
' M; i% Q4 L9 r, r$ u) p1 |' J$ V
) F3 J! i/ A9 a7 l' hWed Mar 04 14:29:47 20154 X5 F o$ R4 [ b) w( \: q5 E
+ `( ~6 C% F# W
! V1 F. k$ u( c' x" W; H I, O
Input File : D:\PVG102-I文件\PVG102_I_V1.0_20150227\PVG102_I_V1.0_20150227.eco
. k# O' g3 b2 P' i+ JCurrent Job : PVG102_I_V1.0_20150227.pcb
Q& y$ V3 F/ ]7 f8 x. ^3 L7 t( D2 i2 p
W4 X2 I9 e. [, O# J( h; G8 M" n
; ]6 \( K: A1 U4 M; w
! g( a: e& X6 u% Y4 l4 A# h. l* }3 X6 Q a
Line 6 , Section *PART*
; i8 T; g3 G; L/ {J61 3P-2.54@3P-2.54
% A9 N' R5 ~. c+ O/ O* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "3P-2.54". Open Layer Setup dialog box and change the layer mode of the design to increased layers.
9 \4 d* W1 c7 ]' c" I4 P( K) ]
, n8 d' G7 B! Y& X0 t7 m9 f2 R! S7 i, r/ e% S0 o+ H4 f! v7 E
Line 7 , Section *PART*
6 `& o2 L) \4 T- [' [J52_ARM SIP2@SIP2
0 v) f6 e6 z% T$ d4 f* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "SIP2". Open Layer Setup dialog box and change the layer mode of the design to increased layers.
5 l. R' D5 e6 v2 A* A2 B d, F9 d5 C4 h6 Z
3 |6 F0 a; P" ]Line 10 , Section *NET*
2 ~% R8 a7 j# H4 K) cJ52_ARM.1 J61.1
: W/ z x. M T$ t7 F0 e5 I* Part name J52_ARM not found1 J+ I0 Z+ _* N
* Part name J61 not found
* v+ r" t6 Z: d* ?0 U. T
! u* q* Q* f2 S- _
* ?- P/ e3 J6 _! M4 yLine 12 , Section *NET*1 c7 j* E; p# E I2 M
J52_ARM.2 J61.2& i% W6 ~& U5 b6 V" A" C
* Part name J52_ARM not found) P8 B+ s) a% A5 C1 E$ A" f
; ? Z( U3 z! [6 `$ [方法 ![]() , ^; k4 S: x% b& j2 D
! {2 D! V% S/ U; Y* z8 d8 \
7 u! H4 Q5 T7 l+ o( T1 @# F即可解决
H& d3 ?) q+ ^+ L- g7 \7 C, x |
